Drivetrain 135i Brembos (Same as Mini GP2s) upgrade thread. Dump info in here!
#101
I'm so scared to post, because don't know the maturity level of this community and don't want to hear the stupid search post reply from other memebers to then find out there are 40 other once with two post someone asking a question and #2 saying to do a search.
#104
Starting a new thread specific to your question is the correct way to go - tagging onto a tangentially related thread is always the wrong way to go.
By starting a new thread, it's easier to get answer because folks see exactly what your asking. It's easier to find it later, when someone is searching, because it's about exactly what you asked about.
#105
#106
#108
Bobby,
Why is it a huge let down? Just out of curiosity.
The only part that really needs modification are the brake caliper adapters (mill 3mm off) and widening the caliper mounting holes in the spindle to help the bolts align correctly. I mean, it's a modification, it's not a plug and play...I'm guessing this is where your disappointment lies. I was not expecting the brakes to just fit when I began the project in reality. It can be done, and I did it. Brakes work just fine. If I didn't have any mechanical experience I wouldn't have done it otherwise.
#112
#117
If you are running stock MINI wheels you will need a 17" or higher and run 15mm or higher spacers to clear.
Again the BMW yellows/silvers have a drill hole for the brake line 90 degree at a different angle (same metal nub location) and the calipers are flipped and rotated in direction when we compared the 135i w/ BBK to the JCW Gp2. Thats what we saw.
#119
ok, those are called S- Heavys Clear with the 15mmm spacers based off what we found on the GP2 kit unless you make the caliper bracket stick out more than factory.
#121
Welcome, not any time soon. Maybe not until the holidays. They don't go on sale often at all for NM Eng.
#122
As I see you installed the right caliper to the left side. But the sequence of pistons is wrong in this case, the leading one is big and the trailing one is small. There will be uneven wear of pads. Calipers should be installed on their original sides. The problem could be with bleeding of the brakes, the calipers need to be taken off the brackets and inverted for bleeding. Or it seems to be possible to change the places of nozzles for bleeding.
#124
Yep so you would be forced to run them with the bigger piston contacting the rotor first. Now engineers do things for reasons and they designed the unit to work with the smaller piston in the lead position. Does this impact the function so greatly that it will not function correctly, I am thinking no but just I said I do not intend to run my JCW that has Chevy Cobalt SS Brembos at Le Mans, I would not run a MINI with 135i Brembos there as well. Will/would I drive the hell out of the car on the street, ah yes.
#125
