Drivetrain How to remove aftermarket Crank Pulley
Old 08-23-2014, 11:56 AM
IIIIIII's Avatar
IIIIIII
IIIIIII is offline
The previous owner of my car had installed a 2% m7 crank pulley, and I want to install an ATI but I cannot figure out how to remove the damn pulley.
Any help on this would be great.
Old 08-29-2014, 02:11 PM
nkfry's Avatar
nkfry
nkfry is offline
Does the current M7 pulley have 3 tapped holes in a triangular pattern around the bolt flange? If so, you'll need the MINI crank pulley removal tool. If it doesn't have those tapped holes you will need a 3 jaw puller, but you will want to make sure the fingers on it are shallow enough to fit between the pulley and timing cover.
We rent the crank pulley puller out, as well as other required tools you'll need to do the job, as well as stock the ATI dampers.
http://www.detroittuned.com/crank-pulley-tool-rental/
http://www.detroittuned.com/mini-gen...r-tool-rental/
http://www.detroittuned.com/ati-super-damper/
Good luck, if you need anything feel free to PM me, or give us a call at the shop. 586-792-6464
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
ebowling
90
08-04-2019 09:15 AM
Toolman
01-20-2016 06:50 AM
mackedmini
08-20-2015 02:35 AM
keck.j
08-18-2015 08:18 PM
Lt. Dan
08-10-2015 12:46 PM
Quick Reply: Drivetrain How to remove aftermarket Crank Pulley
