Drivetrain Schrick camshaft question for people who built this motor.
Hi, I'm currently getting ready to do a full build on my engine. Wanna have a game plan to follow once I figure out what parts I'm gonna use.
Has anyone who has built these engines(N14) used Schrick cams? I had an idea of using the 248 cam on the intake side and the 252 on the exhaust side.
From the sidelines, it appears that most guys work with the tune and turbo upgrades. I've seen a couple of guys rebuild their engines with Carrillo rods and pistons, but haven't heard about cam development on this forum.
It may be wise to speak with your tune company and find out what they can work with.
Plus, you should have a pretty good plan for traction as well.......
Have fun,
Mike
Have fun,
Mike
It's possible to do the cams. People have used the Schrick and there are others in development from other companies. Just need to make sure that you have piston relief as required for the valve lift.
Agreed that it's not been done here much. It's still early days for these engines and most people doing builds are piecing miscellaneous bits together still.
What I'm saying is even the GP2 can get some serious hp and torque without running upgraded cams. Sorry about the confusion.
I was just curious since i have 2 on the shelf that i removed do to tuning issues. I'm currently looking at a couple tuning options but i am specific with them as to what can i or cant i do to the engine relative to the tuning process so a nightmare is not encountered. I am curious about the 248 int. and the 252 exh. being used together. valve relief's wont be an issue since i will be checking the clearance if i choose to use them.
This guy has Schrick cams. I think he is using 248s but I would need to read through his build again:
http://www.minitorque.com/forum/f272...nls-r56-25947/
When I do my build I'm going to use the 248s as well. A while back I read up on the 248 vs 252 and if memory serves me correctly the 248 can be a direct swap and is ok for street use and doesn't make the car idle weird. The 252 is a different story though. I researched this a year ago and haven't really checked since so take my input for what it's worth.
There is some free horsepower just in cam timing. I wish they made slottled cam sprokets for the mini. I use to build drag bikes and i could pick up a stock GSXR bike .3 tenths in the quater buy just degeeing the cams in. Yes you can build your power band for what you are wanting to do . with turbo and nos you want lots of lobe seperation , if you want top end you roll them forward , bottom end back.... some cams would be nice but i heard the ECU freaks out when you put some thump in your junk.......
Sorry folks, racing season had me busy. Down to my last race this weekend for the year then it's back to the mini world. As far as degreeing the cams, good idea. But the cams aren't slotted, so if you have dial indicators you should be able to tweek them and just tighten the bolt up. However, will the ECU notice if you move them 4degrees at most ?
I don't think you will get 4 degrees out of them with just loosening the bolts.
I have not looked to hard at the mini's "sprockets" but from what I see at a glance it would be a complicated piece .
Then what would the ECU / VVT do ......
would be nice to roll them out and get some more lobe separation .
WOW !!! How much things change in a year. I have to get my bigger turbo mapped out by JM turbo still. I think that's there name. I'll check out this camshaft thing again. See what Owen offers compared to the Schricks I have.
Personal opinion --- port the head and match it to BOTH manifolds! You want power, the engines' gotta breathe! Get a turbo to match the ECU boost limit --- 22PSI for the MCS. I've read where the JCW can support 30PSI, but I can't verify that. Avoid the Garrett's --- spooling starts too late. Lotsa good hybrids available.
And, with more boost, you'll need stronger rods / pistons. Mod requirements won't stop ---
Checking your "garage", I see you also believe in the "Sleeper". Stick with it, they are a blast to drive!
Shrick cams
I read this thread and didn't see anything about installing schrick cams since 2013. Who has successfully made the swap and which cam did you use? 10mm lift or 10.7mm lift. what was your experience with your engine after installation and a few K miles of driving?
I am researching my options now.
Thanks so much, DR
Thanks so much, DR
I also am interested.
With cams, one should consider port work to allow the benefits of the cam to take full effect. I'm in contact with a member who is having issues after installing some cams. 10 whp is really not that much for what cams can do based on my experience with older BMW's. Of course one must have a tune for them not matter what.
Will follow up as info is provided.
Schrick Cam
Because I'm so **** I have to do research before I fix anything on that little car.
I have consulted with at least two race engine builders and understand that there is a very precise (yet straightrforward) method of measuring valve to piston distance (with the varaible cam timing in the equation). That's the unknown for me. The parts (pistons, rings, valves, higher spring rate springs and all other internals are available. From Mini and a couple of outside vendors.) I've sourced all of those.
Being here in Denver, my concern was to identify a builder who could take the engine apart, do the machining, and put it back together correctly with ensuring all the clearances were perfect and the assembly was clean and tight.
I know where I might either take the car or send the engine out of state. It's an added expense. And yes you have to tune the car. I have a KO4 turbo in it now and without the tune the engine would be ruined. I'm pretty sure of that.
Stay in touch. DR
Stay in touch. DR
