Drivetrain Dash Command data log graphs
Old 09-01-2015, 02:45 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Originally Posted by sub3622
Cerenkov, i saw that thread a while back, actually its really good but i think that company is having problems internally, that is why i am holding back, for now. What about you? Do you have an OCC? Which one?
I don't have one right now. My car only has 24,000 miles and last time I peeked at the valves around 18,000 miles they were fairly clean. Also the car consumes zero oil. It seems that maybe the later model N18 engines are not nearly as bad as the earlier model N14 engines in this regard.
  #202
Old 09-10-2015, 09:50 PM
Tigger2011's Avatar
Tigger2011
Tigger2011 is offline
Alliance Member
Hmm... looks like I spoke too soon. First fJCW I've data logged (Vlad) Stage 2+ Map A. Top of second gear at shift so ignore the AFR, it was 11.2. I'm thinking that more than just the MAP sensors may have been up rated.
  #203
Old 01-02-2018, 03:40 PM
tzo's Avatar
tzo
tzo is offline
Add gauges
[QUOTE=cerenkov;3852418]The max pointer (triangle) is under "Marker PID"
Here are some screen shots:
[/QUOTE
I ve just bought dashcommand and i need some help toset the right gauges.I d like to add boost gauge and AFR but i dont know how to do it.Any help please?
  #204
Old 08-25-2018, 03:58 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Max PIDs per second?
how many PIDs per second are folks getting, and what hardware/software are you using?
so far the best data rate I’ve managed is 19–21 PIDs/sec using a Scantool.net OBDLink SX USB device and OBDwiz or ScanXL in Windows. (Doesn’t seem to matter whether it’s running in VMware or Boot Camp; the Mac’s IO isn’t the bottleneck.)
has anyone gotten a better rate than 20/sec? If so, how?
PelicanParts.com
05-21-2023 04:51 AM
PelicanParts.com
Accessory Products
10-01-2015 01:23 PM
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:13 PM
Quick Reply: Drivetrain Dash Command data log graphs
