Drivetrain BMS Clutch Stop
Old 07-10-2013, 12:11 PM
Terry @ BMS's Avatar
Terry @ BMS
Terry @ BMS is offline
BMS Clutch Stop
Hey guys,
I'm sure many are already running other options. But for those that aren't the BMS adjustable clutch stop fits nicely. Makes fast shifting easier and improves the overall feel banging through the gears. Well worth the $10 shipped price tag and 20 second install time.
http://www.burgertuning.com/clutch_stop_BMW.html
Old 07-10-2013, 06:57 PM
k_h_d's Avatar
k_h_d
k_h_d is offline
This is the first I have seen. I think it's a great idea. The clutch travel seems to much and it really only engages in the fist few inches of travel. Is there any harm in using this? What needs to be done to ensure full engagement/disengagement of the clutch but st the stop to as short as possible?
Edit, I just looked and I don't see anything that looks like a stop for the clutch....
That part says it's for BMW's. Well it for the R56?
Old 07-10-2013, 08:07 PM
Terry @ BMS
If you peek under there you'll find a thin rubber stop you pull out. Then you push ours in. I'm running it at full height and clutch engagement is perfect. Your mileage may vary. Let me know which setting works best for you.
dkdzyn (12-05-2017)
Old 07-11-2013, 07:45 AM
minimechusa's Avatar
minimechusa
minimechusa is offline
32,828 miles and I used all 3 spacers with no problems works great travel feels like good and combined with a craven speed short shifter my shift time has gone down again!! Not by much but every second counts!!!
Old 07-11-2013, 06:30 PM
Terry @ BMS
Switched it from 3 shims to 2 shims this morning and actually prefer it a bit. I'd suggest 2 shims.
dkdzyn (12-05-2017)
Old 07-11-2013, 06:56 PM
minimechusa
Ok I'll give it a try
Old 07-11-2013, 07:22 PM
c4ptn0bv10us's Avatar
c4ptn0bv10us
c4ptn0bv10us is offline
Will this fit my 2012 MINI Cooper S Countryman?
Old 07-12-2013, 12:43 PM
Terry @ BMS
We're pretty confident it will but have not tested it yet. Worst case you can return it if it doesn't fit.
Old 07-12-2013, 12:44 PM
minimechusa
I would say yes but look under your dash where your clutch pedal goes to the firewall, there should be a small rubber plug if that's there then yes. You pull the rubber one out and pop the BMS one in place using the rubber shims to get a distance you like. I was using 3 but 2 actually seems to work better
Old 07-12-2013, 04:07 PM
TeddyL's Avatar
TeddyL
TeddyL is offline
Just installed, 2 shims is perfect for me. Love it !
Old 07-17-2013, 07:59 PM
c4ptn0bv10us
I just installed this on my 2012 Countryman S and it fits perfectly.
I did a quick test drive with 3 installed and it definitely removes the extra play in the clutch but 3 didn't feel right to me. It felt like it was too short and that i was jamming it to the floor. I went home and pulled it out (this sucked a bit), changed it to 2, and went for a second test drive. Two feels perfect for me. Im not sure if this is just preference or because I'm a taller driver at 6'2.
Overall I'm very satisfied with my purchase. It arrived very quickly, makes shifting so much smoother, and faster. Thank You!
Old 07-17-2013, 09:47 PM
ltjpunk7's Avatar
ltjpunk7
ltjpunk7 is offline
3 shims working well for me. At first seemed to short, but then I got used it to very quickly.
Old 07-24-2013, 08:49 PM
Roxspin72's Avatar
Roxspin72
Roxspin72 is offline
+ 1
Purchased/Installed/Test drove/ and love it.
Easy to adapt to, and noticeably changes pedal travel.
Spend the $10, no regrets here
Old 07-24-2013, 10:58 PM
Jonny Crisp's Avatar
Jonny Crisp
Jonny Crisp is offline
Installed today. 3 shims good for me. It seems to make heel and to a little smoother/ easier for me with the different clutch pedal travel. My only complaint is the time it took to install...10 seconds is too quick for something that feels this good. I wanna feel like I earned it!
Old 07-25-2013, 03:39 PM
mrmcgee's Avatar
mrmcgee
mrmcgee is offline
Hello Terry
I posted a question about clutch travel in Mini General now have found this. Will this work for 06 R52 Convertible?
Massive clutch travel is driving mad have learned to compensate but not consistent.
Glad to see I am not the only one with this issue
Old 07-25-2013, 03:46 PM
NewCooperFanatic's Avatar
NewCooperFanatic
NewCooperFanatic is offline
Good question, how many millimeters of travel does this actually eliminate with 3 shims?
Old 07-25-2013, 04:02 PM
mrmcgee's Avatar
mrmcgee
mrmcgee is offline
Clutch stop
Just looked at mine and it does have the small rubber pad the clutch assembly so I ordered will let you know how it goes.
Old 07-25-2013, 04:50 PM
ltjpunk7's Avatar
ltjpunk7
ltjpunk7 is offline
The device itself is about 2cm to my recollection. The stop itself is not placed at the very end of the clutch pedal (lever) so it impedes travel slightly more than that. Anecdotally, I'd say it feels like the pedal travels about 1-2 inches less.
Old 07-25-2013, 05:08 PM
NewCooperFanatic
Thanks, that's exactly what I was looking for....little sucker makes a fairly good difference then.
Must get now lol
Old 07-25-2013, 05:56 PM
chrunck's Avatar
chrunck
chrunck is offline
I'll probably order this when the JB+ comes out because for $10, why not.
Old 07-25-2013, 09:15 PM
NewCooperFanatic
Not gonna lie guys, I just made this myself right now lol
Old 07-25-2013, 11:54 PM
KilmerPT's Avatar
KilmerPT
KilmerPT is offline
Installed it this afternoon and liking the mod very much! 2 shims work well for me as well.
Old 07-26-2013, 06:43 AM
ltjpunk7's Avatar
ltjpunk7
ltjpunk7 is offline
On reassessment, it feels closer to 1 inch of travel, rather than 2 inches.
Old 07-26-2013, 07:02 AM
NewCooperFanatic
Ya, I sorta rigged a ghetto version. It surprisingly makes a fair amount of difference. Not sure how long mine will last though. If it does I'll place my order for one. Pretty good pedal feel
Old 07-30-2013, 07:17 AM
mrmcgee's Avatar
mrmcgee
mrmcgee is offline
Clutch Stop
I know I am not supposed to talk to you guys any more since i am first generation but got my stop yesterday and could only use one shim but makes a remarkable difference. However be very careful trying to remove if you need to add or remove shims. At least on an 06 R52.
Thanks for the tip see in first Gen with the GRAY's!!!
Quick Reply: Drivetrain BMS Clutch Stop
