Drivetrain JCW Turbo Swap
Old 11-02-2016, 10:32 AM
Dr. Spade's Avatar
Dr. Spade
Dr. Spade is offline
So for a temp solution I will likely connect that sensor plug in to a breather filter and use a regular 90 degree coupler...
  #77
Old 11-03-2016, 07:41 AM
Dr. Spade's Avatar
Dr. Spade
In an effort to post helpful advice - K&N elbow will not fit. NM will fit (according to Jerry).
AEM site states there's is just for the S. However I do know of JCW guys running that intake.
The K&N intake pipe bottles down a little so I may have trouble sealing that end of the NM elbow and may have to buy their pipe.
  #78
Old 11-03-2016, 10:52 PM
jetsr6's Avatar
jetsr6
jetsr6 is offline
Here is the stock one for the jcw. Less than $140. I was thinking of going this route or the Alta jcw inlet pipe. It's about $235.
http://new.minimania.com/part/G2NME6...dels-2007-2012
  #79
Old 11-04-2016, 05:51 AM
Dr. Spade's Avatar
Dr. Spade
Thanks. I almost went that way but don't have a stock airbox and didn't want to get a complete JCW intake. Or alternative giant cone filter.
NM coupler should arrive tomorrow. Will let you guys know how it fits
  #80
Old 11-06-2016, 11:47 PM
jetsr6's Avatar
jetsr6
jetsr6 is offline
One thing I've noticed is that the jcw exhaust manifold is lighter. I decided while I have everything apart I'm going to do some porting matching and smooth some things out.
  #81
Old 11-07-2016, 06:42 AM
Dr. Spade's Avatar
Dr. Spade
Update on the ebay JCW turbo. Turbo itself seems ok. There's still some odd surging under boost at high load and low RPM in 2nd and 3rd. Otherwise it pulls nicely and stays on longer approaching redline.
But being an ebay turbo, the inlet thickness is twice what a Borg Warner would be. So it needs a 2" coupler. The NM one did not fit.
So right now I have a standard 2" to 2.5" coupler connecting turbo to intake.
What I assume is the IAT sensor is now on a breather filter. The tube goes to my OCC anyway.
So if you get an ebay JCW turbo, get ready to do this.
  #82
Old 11-07-2016, 09:59 AM
jetsr6's Avatar
jetsr6
jetsr6 is offline
Do you by chance have the part number from the turbo that you got and what year JCW did it come from?
  #83
Old 11-08-2016, 10:10 AM
randeez's Avatar
randeez
randeez is offline
Another option if you can be without it for a week or two (or pick up a rebuildable core cheap enough)
I sent a spare "S" turbo to g-pop shop they offered 3 services:
basic rebuild factory spec (349 or 399 don't remember of top of my head)
hd (I think this is their jcw equivalent) w/360 bearing, billet wheel, etc (basic +100)
And hybrid k03/04 $695
  #84
Old 11-08-2016, 10:32 AM
Dr. Spade's Avatar
Dr. Spade
5303-970-0146
Ran a data log today. Peak boost on stock tune with this turbo is 17.2 PSI. Keeps 12.2 to redline.
Stock was 14 and 11 IIRC
  #85
Old 11-10-2016, 11:51 AM
Dr. Spade's Avatar
Dr. Spade
logged AFRs and got scared. mid 14s low 15s at WOT in peak boost
the fluctuation may be due to boost cut on stock tune. I enjoy the driveability but need some tune to not run so lean
  #86
Old 11-14-2016, 07:56 AM
jetsr6's Avatar
jetsr6
jetsr6 is offline
Not sure if anyone has noticed this but I am in the process of swapping in a jcw turbo. It was used and I'm rebuilding it. The waste gate shaft is badly worn so I was going to use my stock waste gate housing and saw this. The jcw manifold and jcw waste gate housing have a different exhaust port angle. So when I attached the jcw manifold to the s waste gate housing there was a step. See photos
  #87
Old 11-14-2016, 08:01 AM
jetsr6's Avatar
jetsr6
jetsr6 is offline
This is the stock s pic of the same thing.
  #88
Old 11-14-2016, 08:07 AM
jetsr6's Avatar
jetsr6
jetsr6 is offline
So if you use the stock mcs manifold with jcw turbo you will have this step. Unless you use the stock mcs manifold and waste gate housing and the rest use jcw turbo. Hope this makes sense. And helps some people.
  #89
Old 11-20-2016, 04:17 AM
jetsr6's Avatar
jetsr6
jetsr6 is offline
Well I had the same codes and surging as Dr. Spade pretty much. I even had a tune put on my DME. I didn't rebuild the JCW turbo as it felt good(not much play) I think I will need to get a custom tune to get this turbo to work correctly.
I got this the first day, I went back and found my temp connector could had been not connected correctly and fix that.
Then reset error codes and had these come back. DME cut back boost to 5-9 PSI and after 4500RPM boost cut to 0 PSI.
I put back stock Turbo reset codes and was spinning tires with 18-20 boost because of tune of corse. So either I need to find someone that can custom tune to a bigger turbo or leave it be I guess. I don't want too.
  #90
Old 11-20-2016, 04:26 AM
jetsr6's Avatar
jetsr6
jetsr6 is offline
I also found that I didn't have the wastegate in the correct position when I measured it. I had it about 1/2 inch to far out. Swapping out the turbo only takes me about an hour to do so I will probably swap it back after Thanksgiving.
  #91
Old 11-21-2016, 06:40 AM
Dr. Spade's Avatar
Dr. Spade
You're very quick then. I'm partly hampered by a poorly done custom 3" exhaust that is one piece from downpipe to tailpipes.
I was able to buy the Accessport Stage 4 tune 10 minutes before Tigger called me. So I'll be swapping the turbo to the Alta 42/56.
I'm currently running the JCW turbo on that Stage 4 tune and it still surges and hits 22PSI. I did adjust the wastegate to open more as it seemed needed.
  #92
Old 11-22-2016, 05:26 AM
jetsr6's Avatar
jetsr6
jetsr6 is offline
I don't have to remove the downpipe. Just disconnect the turbo from the exhaust wastegate housing where the clamp is that's holding the two together. Pretty easy that way.
I think I'll wait until spring to finish the turbo swap. I need rings and pistons.
  #93
Old 11-22-2016, 06:08 AM
Dr. Spade's Avatar
Dr. Spade
I had to take off the exhaust manifold; couldn't access the bolts holding turbo on.
  #94
Old 11-22-2016, 06:40 AM
jetsr6's Avatar
jetsr6
jetsr6 is offline
That definitely takes longer. I will have todo that again once I get a replacement JCW wastegate housing. The used one I got was badly worn. The place I got it from are working on getting me another one. If that don't work I found a place over in England to get a new one from.
  #95
Old 11-23-2016, 03:03 PM
cheezehead's Avatar
cheezehead
cheezehead is offline
this is all very interesting. i just bought a jcw engine and i have a jcw turbo to go with it, but not sure how it will all come together. we shall see next week, as its all going into the shop for an engine swap.
  #96
Old 11-29-2016, 07:55 AM
thebombardier's Avatar
thebombardier
thebombardier is offline
Does anyone here know if the JCW and standard S turbos use the same housings? i.e. I have a spare N18 Cooper S turbo, could I just buy the core of a JCW turbo and swap it in?
  #97
Old 11-29-2016, 08:22 AM
cheezehead's Avatar
cheezehead
from what i was told, you need nothing more than a jcw turbo. it should mount in to all existing S engine. the only differences of the jcw engine are the actual turbo and the short block.
  #98
Old 11-30-2016, 04:17 AM
jetsr6's Avatar
jetsr6
jetsr6 is offline
For the N14
The compressor side is different. But you can undo the clamp between wastegate housing and the cartridge(main part of turbo oil/coolent/bearing) and just replace that end of the turbo and should be fine. I did. I also got a K&N typhoon CAI and it fit the OEM JCW inlet. The other guy on here bought a China jcw turbo and it didn't fit to the K&N.
  #99
Old 12-16-2016, 07:20 AM
Dr. Spade's Avatar
Dr. Spade
So who is Jason in California?
Rather than returning my ebay JCW turbo he's having me just send it to you.
It's fine other than the inlet being too large for normal intake elbows. The wastegate is now adjusted correctly.
  #100
Old 12-18-2016, 12:53 AM
Mini Mania's Avatar
Mini Mania is offline
Turbo
We have a handy application guide here that should help, and a turbo expert on staff. Also, there are definitely things you can and can't do for you California MINI owers.
Check out the video, too! Any questions, please ask!
http://new.minimania.com/Mini_Cooper...lication_Guide
Quick Reply: Drivetrain JCW Turbo Swap
