MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
new mini owner
19 Replies, 209 Views
Advertisement
Thread Tools Search this Thread
Old 09-05-2010, 04:48 AM
chorline chorline is offline
Send a message via AIM to chorline
Gallery
Average Stock Clutch / Flywheel Lifespan?
Hey All. My non-LSD'd R53 is really getting on my nerves at the AutoX track. That being said I am looking to purchase a OSG LSD but I also understand that the installation of a LSD is basically the same for replacing the clutch and flywheel. My question is.. what is the average lifespan of a stock clutch / flywheel on a R53? My car is a 2005 with 44K miles and is primarily driven at the AutoX track (about a 2mile loop) 2-4 days out of the month (the rest is a few days of casual highway driving). I haven't noticed any gear slipping, additional noises, etc but don't want to get this LSD installed and 2 months later notice that the clutch needs to be replaced. At the last tune the car was doing about 210whp so I'm curious what the average lifespan of the clutch would be? If I'm right on the limits I may just bite the bullet and do it but if I can wait to do the clutch and flywheel until the spring and just get the LSD done now to fully enjoy the rest of the AutoX and Track season in New England that would be a bonus. Thanks in advance!
'05 R53 Pepper White, 16x7 Gram Lights 57Maximum, RMW Tuned, Schrick Cam, 15% Pulley, 440 Injectors, NGK Plugs, MM V2 Exhaust, MM Header, MM Engine Bushings, MM Front Control Arm Bushings, MM CAI, BC BR Coilovers, MM Lower Strut Brace, OMP Lower Stress Bar, OMP Upper Stress Bar, Hotchkis Rear Sway Bar, Carbotech XP8 Pads, Powerslot Slotted Rotors, MSD Coil, MSD Cables, OM Tow Hitch, MM Oil Catch Can, Schroth Harness, Full 50% Cross Weight Alignment... and a Big Stripe
Old 09-05-2010, 03:40 PM
msjulie33 msjulie33 is offline
Gallery
tranny out==big chunk of labor to replace clutch, like most of it so it's the parts that remain to decide but why pull the tranny twice...
decent shop should be able to comment on the condition of the friction disc and throw out bearing etc but if you like to slide that clutch hard on start, or pop it - consider tougher bits. my $.01
that power diff (from stock) isn't the issue on your clutch life, but how you use the clutch to get the power to the ground
Old 09-05-2010, 08:37 PM
Some Guy's Avatar
Some Guy Some Guy is offline
Gallery
33k miles, 3 seasons of AutoX, glazed pressure plate and flywheel, but plenty of friction material left. I measured the clutch thickness as .29in, compared with .33in someone quoted for a newish one. The clutch is considered full warn when it is basically right on the rivets, I was way off that.
I put in a torsen diff but left the stock clutch. Even the throwout bearing was like new, smooth as butter.
'05 HB/B MCS.
With: LED lit scoop - DIY AUX cable - Angel Eye running lights - M7 STB - Air horn - Rally Lights -SVT Focus LSD - Poly Control arm bushings - IE fixed plates
UCONN FSAE Engine Systems Head '10-present
UCONN FSAE dyno testing and tuning lead '09-10: www.uconnracing.com
Follow UCONN FSAE on twitter: http://twitter.com/UCONNFSAE
Old 09-06-2010, 03:35 AM
Gallery
thanks guys. I'll have the shop take a look when they put in the diff in but it sounds like I may be able to hold off for another 6-12 months. Thanks again for your time.
Old 09-07-2010, 05:16 PM
2Miniacs's Avatar
2Miniacs 2Miniacs is offline
Gallery
Given the amount of effort to get the tranny off (speaking from personal experience) I would recommend replacing the clutch/pressure plate/flywheel/throwout bearing while the tranny is already out. If the stock set still has some life left then you could always keep it for down the road when/if the replacement set wears out.....
10 PW/B MCS
Old 09-07-2010, 08:46 PM
WayMotorWorks WayMotorWorks is offline
Vendor
Gallery
Garage
If they have the trans out go ahead and replace it. The cost to pull the trans again is so much that it doesn't make sense to wait.
MINI OEM and Performance Parts, Service, Racing, ECU Tuning,and Repair
Owner of the Texas Speedwerks Company
Old 09-07-2010, 09:11 PM
CrazyIvan's Avatar
CrazyIvan CrazyIvan is offline
Send a message via Yahoo to CrazyIvan
Gallery
Quote:
Listen to this guy. No need to pay for 10-12 hours of labor again in six months to a year. Also for an extra 10 bucks replace the nylon bushings that release fork rod slide on.
Ramius 02 MCS, 05 trans with Torsen LSD, Act C/FW ,Alta intake, 15% S/c pulley,2% M7 Crank pulley, Bmp header, Magnaflow CB, Alta IC,PSRS,end links, rear control arms. Eibach front and rear sway bars and Megan Coil overs and Swift Springs.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
