Drivetrain The Official ALTA AccessPORT Thread
#2080
It looks like you purchased your AccessPORT used. Even when an AccessPORT is uninstalled from a car, it will show the maps that applied to their car when you plug the AccessPORT into your car using the AccessPORT Manager. The TPS maps are only available if your car is a manual.
When an AccessPORT is brand new, it won't show any maps when it's plugged into a computer. If your car is stage 1 and run 91 octane, then run a normal stage 1 map for 91 octane.
Porthos, could you resend your info and description of your problem? Sorry for not getting back to you.
#2081
#2082
#2085
No new news, don't expect any new news at the earliest the beginning of 2012.
#2086
#2089
on
Has anybody noticed any issues with oil consumption while tuned?
I'm only asking because It seems right around the time I installed the AP, I started noticing my oil levels magically dropping and pretty quickly... I don't drive the heck out of my car, but I like to enjoy it from time to time...
I have since uninstalled the tune last week and noticed my oil levels are totally fine again, not dropping....
Now I'm not wanting to be quick to blame the tune for anything because I have had some work done around the valve gaskets earlier in the year by BMW, as well as the Chain Tensioner fix, all three variations... I've read that oil consumption can be affected by that fix, however I never really noticed anything until I installed the AP.
An area of concern;
Car now has 103,500 km's on it. (63,311 miles)
Just last week before I uninstalled the AP my buddy was driving behind me and noticed a small puff of blue out of the exhaust as I accelerated away from a stop (very mild acceleration as well, not hard or fast at all). We eventually popped the hood and I pointed out to him that over the last month or so I had started to notice that the head gasket, and all the bolts were oily looking... all the way around the top... By this time as well I was having to put about 1L of oil in the car I'd say every week to week and a half or less.... I don't know about you guys, but that kinda scares me... that's ridiculous oil consumption... Maybe its normal for these engines?
Anyway I have not noticed any blue smoke or any oil smell before or since my buddy spotted the puff last week, and there are also no leaks, never any oil spots when it sits, nothing to indicate any issue accept for the magically disappearing oil levels and the oily looking head gasket.
Now like I mentioned, some work was done around the head area by BMW back in march, and maybe it has to do with them, but I have a sneaking suspicion, and trust me I don't want to believe this, that the boost levels I was seeing (17-19psi) with the tune, were wreaking havoc with the head gasket, and potentially the rest of the engine... somehow, somewhere, a bit of oil got burned, so either by the valves, the turbo seal, somehow it found its way into the combustion side of things... we have also noticed "blow-by" when we removed the turbo inlet tube... I'm no mechanic so I'm just trying to describe what I've noticed...
I'm just info digging, has anybody noticed oil levels differing with the AP installed? And I was Stage 1 tune, custom intake, res and 2nd cat removed... thats it.... mild at best....
An area of concern;
#2090
#2091
#2092
An area of concern;
An area of concern;
Do a compression test and leakdown test...it will tell you more than trying to sit here and guess what the problem is.
The blowby is normal...but blue smoke out the back is not, nor is oil around the headgasket. The AP is not the cause of the oil loss, the increased boost is probably amplifying an underlying problem.
#2093
Move on please, nothing to see here.
#2095
#2096
on
I just replaced my spark plugs yesterday, pulled the old ones out and they were toasted... there was a very small amount of burned oil residue (crusted brown) on the tips of the plugs to indicate that smoke my buddy saw was probably blue... but like I mentioned originally I haven't seen any more before or since then... Car seems totally fine... Its extremely odd...
Bottom line, my original question was just if anybody had noticed anything strange with oil levels and consumption since being tuned?
Honestly I wouldn't put anything odd like this past these cars, I've had two of them now, and although they are fun as heck to drive, they are beyond quirky and just plain weird sometimes...
Anyway, keep the thoughts coming if you guys have any? I appreciate it.
#2097
The AccessPORT for the 2011 car will use the same AccessPORT with updated software, so you will be good!
#2098
You know what, I find it absurd myself.... but it is what it is.... I can't explain it... The level isn't dropping now with the stock tune.
Compression test and leakdown test like I said!
#2099
I have a 2010 R55 turbo with an AP running stage 1 w/ FMIC. I have been considering getting the JCW package as well lately. I am curious if the AP maps would work on the regular S with the JCW tune? I know the factory JCW model uses a larger turbo, and I've been told by the dealership that the JCW upgrade does not include the turbo. Would there be any fuel delivery problems or timing issues when combining the AP with the JCW upgrade?
#2100
You'd be taking a step backwards...
It would make 0 sense to get the JCW kit when you are already running an AP+FMIC+JCW CAI. What is it that you think you're going to get with it?
