Drivetrain The Official ALTA AccessPORT Thread
Old 06-01-2012, 04:13 PM
ALTA_Chris's Avatar
ALTA_Chris
ALTA_Chris is offline
Originally Posted by dez
My AP does the same thing. tops out at 63.4
I wrote about the issue a few times when i first go it. But never got it figured out...
I remember working on this a few months back. I thought we got it figured out. I'm emailing COBB to see if we can get it fixed.
Originally Posted by mastawyrm
Alright then. I'd like to try out some different configurations though, my own work that is, not prebuilt kits. What symptoms am I looking for to tell me whether everything flows well enough?
Frankly, the stage 2 and stage 3 maps will just not be compatible with the stock exhaust. They were made on a car with a turbo back, and weren't intended to be ran on anything else. Running the incorrect map could lead to turbo failure, CELs, and drivability issues.
  #2577
Old 06-01-2012, 04:42 PM
jrettew's Avatar
jrettew
jrettew is offline
Thanks Chris. Let me know if I can provide anything (logs, reflash test..) to help.
  #2578
Old 06-03-2012, 04:58 PM
mastawyrm's Avatar
mastawyrm
mastawyrm is offline
OK I changed it. Now it goes turbo->2.5" pipe->2.5" glasspack->2.5" pipe->stock clubman dual mufflers. Will that do? :P I know the stock stuff is only like 2" or maybe a little less but the only stock stuff I have now is after the split so that should add together to make well over 3" right?
  #2579
Old 06-03-2012, 05:34 PM
arnk0006's Avatar
arnk0006
arnk0006 is offline
Can I got stage 2 with alta fmic NM boost tubes alta bov spring alta CAI alta inlet and alta fmic?
  #2580
Old 06-03-2012, 05:50 PM
DneprDave's Avatar
DneprDave
DneprDave is offline
It is all about the exhaust. Go back over this thread, scan for Alta's replies.
Stage two requires a 2 1/2" catless turbo back or a high flow cat and a 3" cat back.
Dave
  #2581
Old 06-06-2012, 06:27 AM
pbpinftworth's Avatar
pbpinftworth
pbpinftworth is offline
Has anyone else had problems "uninstalling" the AccessPort from the ECU? I was told by Alta_Chris to uninstall to see the additional maps (after updating firmware, etc on computer). The AccessPort just sat there in "Identifying Car" field for over 30 minutes. I tried stopping and starting the car as well as simple removal of the key and putting it back into "start" mode. No luck on anything. I'm just trying to get S2, S3 maps onto my access port.
  #2582
Old 06-06-2012, 08:04 AM
ALTA_Chris's Avatar
ALTA_Chris
Sorry you're still having problems! If it's stuck on the "identifying vehicle" for more than a few seconds, unplug it and plug it back in. It's rare, but sometimes the AP can get hung up on that window.
  #2583
Old 06-07-2012, 06:02 PM
monstar28's Avatar
monstar28
monstar28 is offline
I just received my accessport and I have a K&N intake on the way. Is there a custom map for that or do I still you the stage 1 for 91 octane?
  #2584
Old 06-08-2012, 08:06 AM
ALTA_Chris's Avatar
ALTA_Chris
Hello, the AccessPORT comes preloaded with a stage 1 91 octane map. The K&N intake has given some problems in the past, which can't be tuned for. I recommend running it with the preloaded stage 1 91 map.
  #2585
Old 06-08-2012, 03:34 PM
ALTAPerformance's Avatar
ALTAPerformance
ALTAPerformance is offline
Hi Guys and Gals,
GEAT Deal Here ....
Updated 06/11/2012
  #2586
Old 06-09-2012, 07:19 PM
mcmmotorsports's Avatar
mcmmotorsports
mcmmotorsports is offline
Called, left message, fingers crossed.
  #2587
Old 06-21-2012, 12:27 PM
jbourne's Avatar
jbourne
jbourne is offline
What relationship, if any, do the stg1 maps have to the DMTL pump? When installed, car throws DMTL failure code (*consistently*). When deinstalled, everything is fine. Weird!
  #2588
Old 06-21-2012, 03:06 PM
DneprDave's Avatar
DneprDave
What does DMTL mean?
Dave
  #2589
Old 06-21-2012, 04:12 PM
MINIutia's Avatar
MINIutia
MINIutia is offline
Diagnostic Module Tank Leakage, often seen as DM-TL.
The pump that pressurizes the fuel tank to check for leaks for emissions compliance.
  #2590
Old 06-21-2012, 04:13 PM
Maugre's Avatar
Maugre
Maugre is offline
Diagnostic Module Tank Leakage. It has to do with emissions, like if your fuel filler cap is loose.
  #2591
Old 06-21-2012, 04:24 PM
Spice Orange JCW's Avatar
Spice Orange JCW
Spice Orange JCW is offline
Does stage 1 get rid of the rev limiter? Today I accelerated fast in first gear and before I knew its was at 7000 and had no rev limiter.
  #2592
Old 06-21-2012, 04:25 PM
jbourne's Avatar
jbourne
jbourne is offline
Dave
Yup. And for the life of me I can't think what relationship it could have.
  #2593
Old 06-21-2012, 04:57 PM
ALTA_Chris's Avatar
ALTA_Chris
jbourne,
If you could give us the exact code you're getting, that will help. Thanks!
  #2594
Old 06-21-2012, 04:59 PM
ALTA_Chris's Avatar
ALTA_Chris
The rev limiter is there, at least in the normal maps preloaded in the AccessPORT. But it's raised a few hundred RPMs from stock.
  #2595
Old 06-21-2012, 09:33 PM
dez's Avatar
dez
dez is offline
Excuse me if this has already been answered... I tried to search thru the thread but as we all know its a long one.
So I want to go to Stage 2 or Stage 3... in CA so need a CAT for emissions. What I was able to find searching thru the thread was that I would need a 3" high flow cat back exhaust. Is that accurate?
Does that mean I don't need a a 3" down pipe?
What vendors are making 3" cat back exhausts?
  #2596
Old 06-21-2012, 10:46 PM
-Fen-'s Avatar
-Fen-
-Fen- is offline
Is there a tune for the Coupe S?
I just purchased an R58 S. Do you guys have an available setup for the Coupe S ?
  #2597
Old 06-22-2012, 07:19 AM
Maugre's Avatar
Maugre
Maugre is offline
AFAIK DDMWorks is the only vendor that makes a 3" cat back exhaust.
Alta no longer makes their 3" system on which their stage 2 and 3 maps were designed. Their 3" downpipe had 2 (two) high flow cats.
FWIW Akropovic makes a 2 1/2" high flow downpipe (100 cel) which would probably be your best bet for a downpipe.
A few threads back, someone mentioned that they were running such a system, can't remember if S-2 or S-3, but Alta said the data showed no problems. good luck.
  #2598
Old 06-22-2012, 07:55 AM
dez's Avatar
dez
dez is offline
thanks Maugre
  #2599
Old 06-22-2012, 08:44 AM
ALTA_Chris's Avatar
ALTA_Chris
2.5" catless, or 3" high flow cat system will be good for stage 2. Technically though, running any type of high flow cat is illegal in CA.
The AccessPORT does not work on the R58 S, sorry!
  #2600
Old 06-22-2012, 08:51 AM
dez's Avatar
dez
dez is offline
boo
So there is no way to "legally" go to Stage 2/3 in CA?
And just so I'm clear the only other thing needed for Stage 3 is a FMIC?
Quick Reply: Drivetrain The Official ALTA AccessPORT Thread
