Drivetrain Post your dyno charts
#51
Also tell us about this Tune/Tuner you are using, please
#52
DR. ECU aka OZ is a Turkish Tuner. He tuned almost all the powerful cars in Turkey.
He does custom ecu programming.
You can see his dyne sheets;
http://www.techturkey.com/forum/dyno-sheets/
For Methanol kit i will upload pictures to my threat.
#53
#54
Here is my dyno results for the baseline with no Tune yet. Pulled in third gear 2000-7000rpm
2005 R53 94,000mi
2600 ft above sea level
- WMW 15% pulley with proper belt
- Electric water pump
- 380cc JCW OEM injectors
- 1 ball exhaust
- Modified CAI
92 Octane with E10.
1st Pull - 53.31 F, 27.19 in-Hg, Humidity 47%, SAE: 1.07, 183hp and 163 ft-lbs
The first pull was the best of all three. I was able to do a total of three pulls.
2005 R53 94,000mi
- 1 ball exhaust
- Modified CAI
92 Octane with E10.
#55
Orlando Area Dyno Day
Here is some of the Dyno Sheets from our Dyno Day:
First mine, an 06 MSCa with 15%, RMW Cam, 380cc Injectors, and AquaMist HFS-3.
Next is an 05 MCS with a Cam, 450cc and Head, Stock Header and JCW exhaust
This one is a heavily Modified 05 with:
RMW Head, cam, race header, "quiet" exhaust
Endyn rollerwave pistons, modified supercharger
My own special home brewed air intake.
M7 16% pulley
The car is a 2006 (Oct 05 build), 6 speed with factory LSD.
The mods are:
RMW dyno tune
RMW street cam
RMW street header
Invidia catback exhaust
Alta 17% pulley
Alta intake
RMW 450cc injectors
JCW spark plugs
M7 16% pulley
The mods are:
RMW dyno tune
RMW street cam
RMW street header
Alta 17% pulley
Alta intake
RMW 450cc injectors
JCW spark plugs
#56
Here is a couple more and I think this one is one of the most interesting; it was a bone stock 06 MCS, that the day before the tuning party got:
RMW Dominator Cam
RMW Header and Cat
450cc Injectors
CAI
15% Pulley
It was making ~150 at the wheels and after the install and tune 212WHP, that 62HP gain.
This one is a 2004 that had a small boost leak:
So as you can see a good bit of us joined the 200+ WHP Club that day.
RMW Dominator Cam
RMW Header and Cat
450cc Injectors
CAI
15% Pulley
#57
RMW Dominator Cam
RMW Header and Cat
450cc Injectors
CAI
15% Pulley
RMW Dominator Cam
RMW Header and Cat
450cc Injectors
CAI
15% Pulley
#59
I am still working on my exhaust setup to install, designing another intake to replace the plastic one after the throttle body, another IC, and a few other goodies.
And I haven't even begun to work on the head and cam.
#60
Even if it was plastic just smooth would be ok.
#61
#62
#67
Yes, during the Tune Party that we did, your combo in cars that could rev to near 8k would lay down 240 to 245WHP.
I will say this it still does not matter to me, the paddle shift is still more fun that the clutch!
Also dont forget we are also losing about 17% in drive train loss, compared to the 10-12% for the manual gear box.
#68
#69
#70
Reciprocating mass is not going to affect your dyno HP numbers. It will, however, affect your acceleration to the finish line in a 1/4 mile run. 10 lbs of unsprung weight (i.e. outside the springs/struts) is worth 100 lbs of sprung weight (i.e. on top of springs/struts), which is the main reason why people run lighter rims and tires when racing. Yes, a lightened flywheel will help the motor to spin up faster, as will an aluminum driveshaft (if you have rear-wheel drive).
Remember, it's not how much HP you make, it's what you do with it. All the HP in the world doesn't mean squat if you can't get your car to hook up.
I provided some links that help explain reciprocating mass:
http://mbworld.org/forums/c63-amg-w2...ore-power.html
http://kennebell.net/KBWebsite/Commo...tVariables.pdf --> Reference #5
http://www.w8ji.com/rotating_mass_acceleration.htm
#71
RMW built 1.6l motor
RMW Dominator Cam
17% pulley
450cc injectors
Clutchmasters lightweight flywheel
ATI Fluidamper
RMW tune, of course
Bone stock exhaust!
It wasn't cool outside. It was in southern California. Close to sea level. Wheel weight doesn't matter, they weren't even on the car during the dyno runs.
RMW Dominator Cam
17% pulley
450cc injectors
ATI Fluidamper
RMW tune, of course
Bone stock exhaust!
#72
#73
#74
Here I come to resurrect a thread!
Hi, I don't have a dyno sheet to share, but instead I'm looking for an idea as to what you guys think my car might be making.
Here's what I've done:
Alta 15% pulley
Alta/Helix CAI
RMW 246 cam
Megan catless racing header with resonator
NGK Iridium plugs
MSD wires
Stock tune for now
Recent top-end rebuild, valve job by hand
My current plan for next steps are MSD coil, then 450 injectors, Invidia cat-back, then to Jan for a tune!
If anyone has this same setup or something very similar, I'd love to hear from you what yours is making and what I should do next!
Alta 15% pulley
Alta/Helix CAI
RMW 246 cam
NGK Iridium plugs
MSD wires
Stock tune for now
