MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post NM Engineering torque arm...
103 Replies, 9,298 Views
Go to first new post Head Unit Upgrade
11 Replies, 1,714 Views
Advertisement
Thread Tools Search this Thread
Old 03-21-2010, 12:12 PM
Mr Silverblood Mr Silverblood is offline
Gallery
NGK Iridium Installation Question
Hi everyone,
I'm currently working with a mechanic who does not have a lot of experience working with Mini's. So today he's working on my car, and one of the items I was looking to have done was to have the plugs replaced with NGK Iridiums.
He called me while I was out, and explained that the Iridium plug was a bit longer than the stock plug. Not having a ton of experience with the Mini's, he was hesitant to do the install because he was worried about the amount of clearance between the head of the piston and the bottom of the plug.
Obviously if it were too long, that could result in some damage. He also didn't know if the heads of the pistons were rounded either, giving it a little extra height in the cylinder.
So basically, are the NGK Iridium plugs supposed to be longer than the stock plugs? And if they're not, then that probably means a different plug was shipped to me then, correct?
Any help would be great!
Thanks,
-Dave
PS - He'll send me a photo of the stock and Iridium plug side by side a little later today, I'll post it so everyone can see what we're talking about.
2004 MCS (Monstah) - RMW Tuned, Header, Cam & 450cc Injectors / NGK Iridiums / Alta CAI / 17% Pulley / DTB Valve / AEM WM Kit / VEI Boost Gauge / MSD Coilpack / TSW Damper / Volt Cat-Back Exhaust / Alta Oil Catchcan / Helix Short Shifter / Ian Cull's Auto-Up / TSW Springs / M7 Strut Brace / Alta Rear Control Arms / ATE Premium 1 Rotors / Red Stuff Pads / Goodridge Brake Lines / R-Speed 22mm Rear Sway Bar
Old 03-21-2010, 12:29 PM
Gallery
Here's the photo, you can see the Iridium electrode sticks out further than the stock electrode, but not by much. (The stock plug is the dirtier one - lol)
He's basically just being cautious, which is totally fine. I'd rather know it'll be ok, vs having him put it in, and it wrecks the pistons. lol
Old 03-21-2010, 02:26 PM
roaduscarnivorous's Avatar
roaduscarnivorous roaduscarnivorous is offline
Send a message via AIM to roaduscarnivorous
Gallery
wasn't there something, at least a while ago, about these plugs backing off the threads, w/ some even stripping the threads off the engine block? i haven't been keeping up in a while so pardon me if i missed anything, but because of that i always use the stock spec ngk instead of the iridiums
'04 cr/w jcw mcs
-freeway? what the hell's a freeway?
-eight lanes of shimmering cement running from here to pasadena. smooth, safe, fast. traffic jams will be a thing of the past
Old 03-21-2010, 03:10 PM
Gallery
Quote:
Really?
I don't know, but I'd love more input on this.
I did see someone post on another forum about the Iridium's being slightly longer than the stock plug, so they acknowledged that it was longer, but nothing was mentioned about it being a negative either.
I just want to be sure, ya know?
Old 03-21-2010, 04:14 PM
DAVESTER's Avatar
DAVESTER DAVESTER is offline
Gallery
I installed the NGK Iridium plugs in my 04 MCS with no problems. By the way, it was not the NGK plugs that were backing out, I believe it was the Densen plugs--
Deuce is a 2012 S Coupe CR/SLV JCW package, Cold weather ,and Premium packages. Rooser red color line, White turn signals, Piano black dash, Xenons, Black headlights, Black driving lights, Rear fog light
Old 03-21-2010, 04:46 PM
daflake's Avatar
daflake daflake is offline
Gallery
Both have done this and I contribute it down to improper installation. Many people don't tighten it down past the compression washer (it gets tight and then loosens again) before torquing.
Anyway, I have been running NGK for several years now. I highly recommend them. They are going to be a little longer, it is normal and won't cause any problems.
Old 03-21-2010, 04:49 PM
Gallery
Quote:
Thanks for the input Dave!
I had read from someone else that they put Iridiums in their 04 also with no issues. Also, a friend of mine double checked the numbers on the Iridium box vs a web site that sells them for MCS's between 02 and 06, and sure enough they matched.
DaFlake, thanks for the input as well. I think that'll probably do it, as you've confirmed the added length as being ok, with no problems to the engine. (meaning your personal experience with them)
I'll let me mechanic know, he'll be pleased to hear that.
Thanks again!
Old 03-21-2010, 05:09 PM
daflake's Avatar
Gallery
Is this Pete or have you moved? (I doubt it but have to ask)
Old 03-21-2010, 05:11 PM
Gallery
Pete is no longer my mechanic.
Old 03-21-2010, 05:40 PM
daflake's Avatar
Gallery
Quote:
Fair enough...
Old 03-22-2010, 09:37 AM
apexer apexer is offline
Gallery
Always best to put a little antiseize on the threads and torque to 20 ftlbs.
Actually, because of antiseize, you can get a false torque reading, I torque plugs to 18 ftlbs. Remember....only 1 click on the torque wrench is required. Additional clicks actually exceed the torque setting.
Have been using Denzo plugs and never found one loose but, I do check the torque with every oil change.
04 MCS,CR/W,Anthracite,P-BLeather,15% AltaPulley,+2%AltaCrank,MTH,AltaCAI,IK-22plugs,DT-TB,NologyWires,Alta Oil CC,Magnaflow,EBC Greens,Stoptech SS BrakeLines,Ate fluid,H-Sport Comp.Rear Bar,Kosie K-1 TS Wheels(17X7 in white)w/Star Spec Tires,Momo LeatherShiftKnob,Euro Shelf,Zaino. MMC#150 - CROC#48http://www.thompsonsmithdesign.com/w.../CROC-icon.JPG
Old 03-23-2010, 02:12 PM
JumpingJackFlash's Avatar
JumpingJackFlash JumpingJackFlash is offline
Send a message via ICQ to JumpingJackFlash Send a message via Yahoo to JumpingJackFlash
Gallery
Garage
Plug length is based on temperature range. The fact the electrode sticks out a little farther should not have an impact on being too close to the piston. The combustion chamber shape/size should be able to accomodate, not to mention Cooper S pistons are dished for reduced initial compression (8.3:1) to be combined with using boost.
'06 MCS, AB/DS, #1/#2/#3, RMW Tuned, 15%, DDM CAI, GP IC w/DDM GP div., DT BPV, Brisk silver plugs, Invidia exh., M7 Ext. Scoop, GReddy AFR/boost gauges, M7/Cobalt F/R st. bars, H&R 25mm comp. R swaybar, BBS RK rims, Kicker speakers/amp/sub, Rock-Fos 1F cap, Westin driving lights, Angel Eyes lights, Gear Jammin' LED tail lights
http://www.cybertekit.net/mini/signature2.jpg
Old 03-23-2010, 07:20 PM
Gallery
Good info to know, Flash. Thanks for that!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
