MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Swift vs H Sport
by putttn
0 Replies, 13 Views
Advertisement
Thread Tools Search this Thread
  #101
Old 02-18-2010, 04:56 AM
D-MAN D-MAN is offline
Gallery
Quote:
Originally Posted by lhoboy View Post
The front brackets will eventually fatigue fail if the back of the IC is not properly secured with brackets.
Other intercoolers like the GRS do not use rear brackets and guys in the UK have run those for years and never had issues with front bracket failures....
  #102
Old 02-18-2010, 08:48 AM
newbs49 newbs49 is offline
Gallery
You can lead them to wate rbut you can't make them drink.
  #103
Old 02-25-2010, 07:09 PM
JIMINNI's Avatar
JIMINNI JIMINNI is offline
Gallery
Look what showed up in the mail today
  #104
Old 02-25-2010, 08:12 PM
-=gRay rAvEn=-'s Avatar
-=gRay rAvEn=- -=gRay rAvEn=- is offline
Modder-ator
Gallery
Garage
Sweet !
Mine arrived and is in too OEM Bonnet diverter seems to fit AOK, I have the GP one, but riding the fence whether or not I will swap them out. Btw: All new brackets front and back. They were cheap.
Dave
2003 R53 - DS - 135K + Miles
Parts of MINI NOT Modded ( A Shorter List ) Block/Head/HK Stereo.
  #105
Old 02-25-2010, 09:48 PM
JIMINNI's Avatar
Gallery
Quote:
Originally Posted by -=gRay rAvEn=- View Post
Sweet !
Dave
Cool I didn't get the upper diverter as I love the look of my M7 Ram air scoop and didn't see how it could match up? I am going to remove all of the insulation under my hood, so will custom fab something to seal it off
  #106
Old 02-26-2010, 07:02 AM
Modder-ator
Gallery
Garage
Quote:
me 2 but currently running their extreme scoop. I have heard of some removing that material. I am not fully aware of the benefits though. Was your objective heat dissapation or weight loss ?
You probably will have to put something over the IC for sure. These types need something to catch the air and help it make that 90 degree down turn thru the fins.....maybe attaching some foam strips to the bare bonnet will help. Another Home Depot DIY
If Alta or DDM made a IC/diverter cover for these GP versions, I would be all over it......
  #107
Old 02-26-2010, 09:41 AM
JIMINNI's Avatar
Gallery
Both. If you look at the R56 they only have the insulation right at the scoop, which is stupid as is it dosen't really do anything, they should have it right above the turbo as it gets extremley hot.
Yea, I modified my Alta diverter to seal up all the gaps and mate with my scoop. The new GP diverter is plastic so........ Might have to think about this alittle
  #108
Old 02-28-2010, 06:19 PM
JIMINNI's Avatar
Gallery
Well installed the IC this weekend. Having looked at the fitment I decided to use my old OEM upper diverter after extensive modifications First I removed the under hood insulation and cleaned everything, think it looks nice Then began the process of fitting the diverter. Completely removed the front bottom piece and cut the top until I got a good fit. BTW, the black plastic is hard to cut with a rotary dremel, it melts too much and that stuff is HOT! Went to the old jig saw and it worked great! I might use some double sided tape to get a better fit on the top, but it looks pretty good. I still need to fill in the dreaded front gap as I did with my Alta diverter, but haven't decided how yet? Plus as you see in the pics, I am going to fill in the little side gaps with some black silicone. Just out of curiosity I set my Alta diverter on the GP IC, it would almost work with some more modifications. Oh and added the sticker, thats gotta add a couple more HP's Here are some pics:
  #109
Old 02-28-2010, 06:26 PM
JPMM's Avatar
JPMM JPMM is offline
6th Geared
Send a message via ICQ to JPMM
Gallery
Did the same thing ,hot plastic and all! Used heavy tape for the gap, as I havn't come up with anything else.
2009 fJCW BamaCooperS's ole Red
  #110
Old 02-28-2010, 06:31 PM
JIMINNI's Avatar
Gallery
Quote:
I might use some garage door seal, I had some for the front lip mod, which I never did, and it looks like it might work pretty good?
  #111
Old 02-28-2010, 06:48 PM
Modder-ator
Gallery
Garage
Really nice work! The bonnet looks so much better w/o that old rUg up there. Honestly those bonnet blankets look like a crappy rug from some old barn .
Looks like you have a really nice seal with the foam too. And the Home Depot bumper lip strip may just work out. I have some OEM regular rubber bonnet seal stuff too, when I am done painting some MINI parts in the garage I'll give that stuff a look see.
Thanks for the photos and write up.
  #112
Old 02-28-2010, 06:50 PM
JIMINNI's Avatar
Gallery
Thanks And your welcome.
  #113
Old 03-01-2010, 09:01 AM
Gallery
It's to bad Alta never made their diverter for the GP that they said they would. Too bad DDM can't be convinced to make one. I know a few people would buy one.
Nice job on both of your installs.
  #114
Old 03-01-2010, 09:55 AM
JIMINNI's Avatar
Gallery
Thanks! I may try and further cut up my Alta, but I think when I get the front gap done it will be great
  #115
Old 03-01-2010, 10:46 AM
Dr Obnxs's Avatar
Dr Obnxs Dr Obnxs is offline
Vendor
Gallery
Home made weatherstrip..
use some high temp black silicone sealer, goop whatever up as needed, put some saran wrap over it, and close whatever you're sealing. when it's dry you can peel off the seran wrap. It's very stiff but a good way to make some seals for funky corners and the like.
Matt
FES Auto= Worlds Best Shiftlight-Ian Cull Auto-Up-Auto Sportplus - R52 Top Commander
but wait, there's more! InvisiLens - Bav Tech SW - High Current Relay Module-
'02 CR/W S, Bunch of fun mods... '08 NFR/S Clubbie, close to bone-stock...
Dr Obnxs' Musings: a blog about cars, energy, technology and more....
  #116
Old 03-01-2010, 12:11 PM
Modder-ator
Gallery
Garage
Great idea Doc.
  #117
Old 03-01-2010, 12:44 PM
BlimeyCabrio BlimeyCabrio is offline
Gallery
Quote:
Matt
You are one crafty dude. Great suggestion.
Ever try macrame'?
I'm Paul, The car is Blimey--- BlimeyCabrio's Blog--- 2006 MCSCa w/lotsa mods and Union Jacks
Ten-time Dragon Veteran - Occasional Trackrat - Extreme Twisty Addict - Rhymers Ferry Road Fanatic
  #118
Old 03-01-2010, 05:01 PM
Dr Obnxs's Avatar
Vendor
Gallery
While it's a good idea
I can't take credit. I read about it somewhere for fixing old weatherstripping when new stuff wasn't available.
And no macrame here.... No time...
Matt
  #119
Old 03-01-2010, 06:57 PM
JIMINNI's Avatar
Gallery
Matt
Are you talking of the large front gap? Or just small gaps? Don't see how that would work on the front gap?
  #120
Old 03-01-2010, 06:59 PM
JIMINNI's Avatar
Gallery
So drove the car to work and stuff today, I'm not sure but it feels like the throttle response is better? Could this be possible by just changing the IC? Or maybe it's just that I spent a lot of money and I want it to feel better
  #121
Old 03-01-2010, 08:53 PM
Dr Obnxs's Avatar
Vendor
Gallery
It works with
smaller gaps and the like, but it's a good trick to keep in mind. The front gap needs a very different technique.
Butt-dynos are calibrated to respond proportional to the hit to the credit card!
Matt
  #122
Old 03-01-2010, 09:48 PM
JIMINNI's Avatar
Gallery
Working on that now, looks like a thin sheet of metal using the existing screw's on the diverter will work Already have cut a piece and attached it. Will run it for a couple days and am going to the ABF/MINI event in Santa Clara this weekend so will let Lynn look at it and I'm sure he will come up with something better
  #123
Old 03-03-2010, 05:58 PM
MiniMio's Avatar
MiniMio MiniMio is offline
Gallery
So where is the best place to get a GP IC? Looks very nice from the pix. I assume only dealers can get them.
Mio
  #124
Old 03-03-2010, 06:10 PM
JIMINNI's Avatar
Gallery
Quote:
Mio
You can occasionally find a used one in the marketplace, if you want to wait, or call your dealer and just give them the part numbers. These used to be available only to existing GP owners, but some dealers are now selling them to anybody
  #125
Old 03-05-2010, 05:35 AM
drsilvermini drsilvermini is offline
Gallery
hahaha I know how you feel...wow spending $300 on this carbon fiber dash I can feel the weight difference!
<a href=http://i594.photobucket.com/albums/tt24/drksilvermini/0826091713.jpg target=_blank>http://i594.photobucket.com/albums/t...0826091713.jpg</a> Fun Stuff.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
