Wanted to post this here to help fellow Mini owners. I purchased the Alta headers (with cat) and exhaust and installed this weekend. The car sounds good but it is too loud for my taste.
Video links: http://www.youtube.com/watch?v=Z8xe1WDwRIw
2005 Mini Cooper S - 15% Pulley - MSD Coil Pack - NGK Iridium Spark Plugs - MSD Spark Plug Wires - Alta headers and exhaust - Air intake - Madness Oil Catch Can - Mini Madness read sway bar - Custom tune by Behe Performance
I'd agree - too loud? I've got the JCW exhaust and I think it's too patsy. I've thought of removing the resonator. Anyone done this and does it "pop" too much? I like the tone, just want a little more vibes.
Wanted to post this here to help fellow Mini owners. I purchased the Alta headers (with cat) and exhaust and installed this weekend. The car sounds good but it is too loud for my taste. I will post a video clip so you can judge by yourself.
You can add dynamat to the car or...just take the header/exhaust off
Texas Cooper
Yes I have, but I also have the Clubman.
__________________ Installed: m7 Super AGS - m7 T/IC boost tube - ALTA FMIC - AccessPORT -reso delete - H&R RSS coil overs - ALTA rear lower control arms - m7 oil catch can - m7 heat shield - m7 CF Vortex 2 hood scoop - 17x7 gold Konig Feathers w/ 205/40-17's Waiting to be installed: ALTA s/shifter
you might be able to have a local muffler shop weld a resonator or a muffler of sorts to help keep the noise down. its good you have a cat on there too that should help.
i had that setup. there really isn't anywhere else to put another resonator to quiet it down.
change it back to the stock and you might find that the alta is still too loud. i personally like the volume and sound of the header with high flow cat but couldn't do it on a daily anymore.
I wanted a better sound than OEM, and I got it. The problem is that I was not expecting it to be so loud. But it is growing on me, problem is that I can see cops after me if I open it up in the street.
i have the obx header and obx exhuast with the stock cat in place and its perfect loud when given the beans and i can curise on the motorway at 80-90mph with no drone at all
Texas Cooper
On my 2006 MCS, I too thought the JCW exhaust was too quiet. I removed the resonator and thought the volume was OK but there was too much snap, crackle, and pop. I removed the JCW and installed a Borla Sport, the volume and tone was great but it droned on the highway too much because I do not have a back seat or rear insulation. I removed the Borla and installed a Milltek cat-back. The tone is good and it is louder than the JCW but quieter than the Borla. It does not drone on the highway. However, I would like it just a little louder but it is a good compromise.
2006 MCS JCW GP #1405: Adj Front Camber Plates, 19mm Rear Sway Bar, MM Front Lower Brace, Milltek Cat-Back, TCE 13" Front/11.75" Rear BBK, 15mm Spacers, Wheel Studs, JCM Modified Intake, MM Filter, Gauges
My R55 JCW doesn't pop anymore than it did stock after I took out the resonator. The sound is pretty much exactly the same on mine, can just hear more of the good 4cyl burble to it at start up, and when the turbo kicks in. I wonder how much different that was with the R56.
The amount of snap, crackle, pop depends on the Generation and the model of Mini. The later Gen 1 MCS's were programmed to pop on deacceleration so the removal of the resonator has a larger impact on the deacceleration pop. My car being a GP with no back seat or rear insulation also made the snappy pop more noticable.
Oh ok, I wasn't thinking R53... my bad. Makes sense now.
Texas Cooper
I did. When I put in a B&M short shifter the dust cover forced the heat shield down and there was firm contact with the resonator. It sounded like a tractor pull inside the car so I had the resonator removed. On an '05 with the standard "burble" and no resonator the POP is rather pronounced. I would describe it as dropping firecrackers in a coffee can. It gets attention when you lift off of the go pedal near pedestrians.
However, when I put in a rear seat delete kit there is no longer anything to muffle the noise that comes through the vents just below the rear hatch and I'm getting tired of the pop. I love the raspiness of the JCW without the resonator, but since I can't get rid of the burble/pop I'm just about to install an aftermarket resonator.
That setup actually isn't that loud...my setup is a lot louder. If you don't like it, I'd try putting the OEM header back on. If that's still too loud...well, then just stick with the stock exhaust.
-Cody
"Gizmo" - 03' IB/B MCS! 77' Kawasaki KZ650
Aftermarket: ALTA CAI, ALTA Catless Header, Magnaflow Exhaust, M7 16% Pulley, M7 OCC, VGS, LOTF Engine Damper
2010 Harley 883 Iron
Maybe you should hear mine, you would probably appreciate how quiet yours really is .... Mynes stepped header/test pipe/Alta 3"-----WAAAYYYY TOO LOUD!!!
Post up video
06 MCS SB/S Checkmate
PAPERWEIGHT MOD Crew
