installed the dinan kit and the lid doesnt match up perfect with the base anyone have this problem? i got 1 screw in 1 side and the other is slightly off and sits lower so there is a gap on one side of the airbox now. almost like its warped or somthing? ive been driving it like this for a few weeks now because its not a huge gap, and seem to have no issues but every time i see it, just really bugs me
¤Wïzå®Ð €ÿ매 1FSTMNI
Yotie- 06 MCS Dark Silver, Automatic, Convenience Package, HK Stereo, DINAN S2 Package including Dinan Camshaft and stage 6 software, Mini JCW Boost gauge set up. Black JCW Carbon Fiber spoiler, KUDA Garmin Dash mount, Kuda Iphone mount. COMING SOON Breyton GTS-R wheels with Black with red stripe and Aero kit with M7 Grills
I found it very hard to get the box back over the rear clips on the stock box. I spent about 30 min getting it just right, so it would screw-down right. It is a pain....but I got mine to fit perfect. I did find that the rubber gasket/gap filler that goes between the 2 pieces would sometimes pop out of postion when trying to hook on the rear clips. Give it another shot....it should fit....I was about ready to give up too....I had come to the same conclusion....then after a break, it went together fine.
l 2005 MCS l 11-04 Production l owned since new l RMW Tuned l Craven -17% Pulley l Craven Speed STD l Dinan CAI l JCW 380's l H&R 19 MM Swaybar l MSD Ignition l Power Steering Fan Duct l LightInSight l "EURO" MINI Armrest l Euro Parcel Shelf l Brake Light PULSAR(gen2)l Detroit Tuned Tensioner Stop l Blitzsafe/xmradio l Cobra 19IV CB l 4.5' Francis CB25 CB Antenna, mounted on the rear tow rig!!
What do you all think of the Dinan Intake
Sound/Performace
Im stuck between the Dinan and the twice expensive JCW
How often would the filter need to be replaced ?
Thanks in advance for your input
I had a Dinan and switched to a JCW due to the obnoxious throttle whistle at low RPMs that my car has - not all cars do it.
Both are similar performance and similar sound at WOT above 4000 RPM - Dinan is louder at cruising RPMs - you can choose from various filters with either one. I run an Amsoil nanofilter which never needs replacing and breathes very well - I just blow it out with the air hose every several thousand miles.
I'm Paul, The car is Blimey--- BlimeyCabrio's Blog--- 2006 MCSCa w/lotsa mods and Union Jacks
Ten-time Dragon Veteran - Occasional Trackrat - Extreme Twisty Addict - Rhymers Ferry Road Fanatic
Definitely not an easy fit putting the top back on, I've had to jiggle it around a bit till it finally matched up. Luckily, I only check it every 15k for dirt or need of a dusting with an air hose. After 60k it was time to replace it, not cheap and will probably go with another brand element next time. Still love the sound and no drone or whistle issues.
It is difficult to get in and out. Thankfully we don't have to do it often. I had the cowl/software in at 5K miles and warping wasn't a problem, but I can see how it might. I've thought about replacing the gasket with something that is glued on to the airbox next time. The last time I had it off it was a PITA to get seated again.
I don't have a whistling sound and haven't heard of it before. I love hearing the SC whine though.
'06 RG/S MCS with a bunch of stuff...
I love my intake. Just the right amount of sound. But I am not looking forward to replacing the filter. Anybody try the Minspeed ITG filter? Any thoughts?
itg will be my replacement, alot of people said it was kick ass
¤Wïzå®Ð €ÿ매 1FSTMNI
Wash and re-oil the dinan. Have done it twice now with no visible deterioration of the filter.
Not a bad idea.....but still taking a BIG chance. A few tiny holes too small to see....could let in enough dirt to severely shorten an engines life. Is it happening? Who knows? What I know is that washing and re-oiling the filter to save 50-85$ you are taking a big chance....IF it is not designed for it...it did look like a good washable filter...BUT..there could be reasons we are privy too why it is not sold as a washable filter (other than the desire to sell more filters!) it might make me worry personally.....To each his own. Thanks for the K&N number....found it earlier, but I'm sure reposing it will help people in the future!! I have used K&N panels in the past in other cars....The FOAM vs COTTON Gauze filter debate seems to be one filled with much debate. My only concern with the K&N is that it seems to be generally a smaller diameter.....and that it seems would require more frequent cleaning to keep it flowing in an optimum manner.
I love my Dinan. Cheap now, too. I think i'm going to get another brand new lower air box eventually. The fit was so tight it stripped the threads out of the lower box. I have nuts and bolts on them now and it works OK, but not a simple job to clean the filter.
__________________ -Rick
'03 EB/B MCS
Crap, gotta change my name to Not-so-rednwhite-or-darksilvernwhite-but-electricbluenblackcooper.
I have one from Pete @ Minspeed. Works great. Better call him quick since he is closing out his business.
Yeah...I have bought some stuff from him...but he took the announcement down.....did he change his mind?!
I can only hope!!
took the whole box out and saw that the seal that is in there was way too beefy for the to boxes to seal up right, trimmed about 1/3-1/2 the thickness of it and it fits like a glove now, seals right up
¤Wïzå®Ð €ÿ매 1FSTMNI
