MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Show us your mods!
by ADAM244
19 Replies, 1,180 Views
Advertisement
Thread Tools Search this Thread
Old 11-02-2009, 01:45 PM
Dwight Walhood Dwight Walhood is offline
Gallery
m7 Oil Catch Can Info?
Anybody know if the m7 canister is baffled inside to catch oil and vapors? Just put on their Super AGS and now that there's room, I'm looking real hard at one. My intake from turbo to cold side IC tube is a mess and need to clean it up once and for all. I know it won't completely eliminate the DFI intake valve carbon fouling problem, but it will help slow it down if designed properly. Thanks
BEELZEBUB-DSOC #506th
'08 MCSm, DS/B, LSD. 17X7 Konig's, NM/RacDyn F/R STB's, H-Sport 25.5mm RSB & Camber Arms, NM Springs, SS Lines, End Links & Torque Arm Bushing, Koni Yellows, EBC Brakes. RMW TUNE, Helix FMIC w/TD, DoS CAI, Audi DV, Alta 3" Cat-Bac, Alta Hard Inlet Tube, NM Boost Tubes & SSA, 42DD/BSH OCC System, RECARO.
Old 11-03-2009, 10:22 AM
scottab36's Avatar
scottab36 scottab36 is offline
I've done too many mods..
Gallery
By looking at mine I did not see any baffles in it. That wold make sense to have baffles. Maybe put a very porous material in it, like a rough scrubbing pad to catch the oil mist so it drains to the bottom. I will look into this.
http://www.northamericanmotoring.com/gallery/data/500/medium/DSC_9231sol.jpg
Some people say that I will never get the money out of my MINI that I have put into it. I say, "I get my money's worth everytime I hit the ignition button".
Mods: RMW tuned with many mods... 213.9WHP / 227ftlbs Wheel Torque
Old 11-03-2009, 02:53 PM
Gallery
Peter H. on Catch Can Baffles
Quote:
Got Peter of m7 on the phone and asked the same question. He said no baffles are installed, and for two pretty good reasons. The first is cost and keeping the unit price down. The second is more important. Any filtering material must be rock solid stable to prevent any kind of particles going into the turbo and combustion chamber! Makes sense to me. He runs one on his MCS and said he's had no oil fouling problems since. Ordered mine right after I hung up!
BTW, Ford has put some kind of "outside the engine" media filter on the PCV tube for it's DFI motors to solve the intake-valve carbon fouling problem. Hey, there's some room on that side for a small filter and the PCV tube is easy to get at. I'm going to start looking around for something that could work. Anybody got any ideas?
PS: See this months Road & Track Tech Correspondence article.
Old 11-03-2009, 10:02 PM
eg0911 eg0911 is offline
Gallery
i love the idea and think mini from the factory should have catch cans....does anyone know if mini wouldn't warranty work on the motor if there was a catch can?
Old 11-03-2009, 10:35 PM
Gallery
Quote:
Good Luck! My dealer tried to void the warranty on the cig. lighter (!!) saying I had put an aftermarket accessory plug in and broken it! Heatedly showed him the page in the owners man. that says nothing about using it for anything but the OEM lighter. They replaced it! It was broken on factory install. An independent source said that any mod that doesn't cause a CEL, effect the ECU or mess up smog systems is OK. Wish I could feel certain about this!
Old 11-09-2009, 06:22 AM
Gilboyto Gilboyto is offline
Gallery
Either way they still have to prove to you that it was an aftermarket part that caused failure. MINI here local to me has given me no problems what-so-ever in regards to my aftermarket engine mods.
For example...I got a CEL on and it was running extremely poor. I mean it would shake my car on shut down like it was a 1970 boat car. Took it in...my O2 sensor was damaged and needed to be replaced (the top one near the turbo). I went in with my turboback installed and in, and asked no questions on replacing it for free for me.
| 09 DS MCS w/ LSD | JCW Recaro| RMW | H&R | TSW | CCW | Falken |
Old 11-18-2009, 07:24 PM
Gallery
42 Draft Designs OCC
Found something much better than m7's catch can. They were out of stock anyhow. 42 Draft Design's can is triple baffled and uses the OEM diameter PCV tubing in and out,not a neck down from 3/4 inch (19mm) to 3/8". It's a universal kit and does not include mounting hardware. Got all that stuff at NAPA for $12. Cost? $115 for the "Stealth" kit. Got it this PM and may put it on tonight. I'll let you know how it goes. BTW, if you still have the OEM air intake tube (I don't), mounting could be a real bear!!
<42draftdesigns.com>
Old 11-28-2009, 11:29 PM
kukaepe's Avatar
kukaepe kukaepe is offline
Gallery
Dwight: Could you post photos of your installation and any information regarding the volume of oil accumulated over time. Thanks in advance.
Old 11-29-2009, 09:42 AM
Gallery
S.W.A.G.
Quote:
The "bear" bit me first! My first attempt didn't have enough hood clearance and will have to make a bracket to lower it ~1.5". Will also need to find some flexible, non-binding hose to get around the turbo intake tube. I'm curious too about oil accumulation. Will apply the SWAG Method (Scientific Wild Ass Guess) to determine . Gone last week for the Turkey Slaughter and will get at it as soon as my arteries flush out. Pics and gory details for sure! Gotta show off ya know.
Old 11-29-2009, 05:28 PM
PA-MCS's Avatar
PA-MCS PA-MCS is offline
Gallery
check my gallery for my catch can install
2005 MCS Electric///Blue White Top & Bonnet Stripes/Alta V2 15% pulley/ Alta V2 CAI/Alta Air Diverter/Stratmosphere cat-back/ Detroit Tuned BV/M7 OCC/ Marshall Boost gauge/17x7.5 Rota Rb White w/ polished lip/Hankook Ventus 215/45-17/Screaming Demon coil/cabrio braces/brisk plugs/skid plate
Old 11-29-2009, 10:50 PM
dunphyj's Avatar
dunphyj dunphyj is offline
Send a message via AIM to dunphyj Send a message via Skype™ to dunphyj
Gallery
i think the catch can is a great idea... it just sux for those who DON"T have M7 intakes and still have the stock snorkel...
JP (the man) & Blue Bomber (the MINI)
LazerBlue R56 2007 What you see is whats installed... after all, with MINIs, "it ain't no 10 second race"... it's about bending the rules and ruling the bends!
Old 12-09-2009, 08:02 PM
gregsmini gregsmini is offline
Gallery
Yes, I agree for those of us who do not have a CAI. I want to install an oil catch can, but I am looking for suggestions for a CAI. Anyone?
"Sunny" - Mellow Yellow 2008 MCS | Convenience Package | Cold Weather Package | Premium Package | Sport Package | 6 Speed Manual Trans | Limited Slip Diff | Chrome Line Int & Ext | Continental 215/45/17 DWS Extreme Contact Non-Run Flats l BSH Catch Can l Marshall Oil Pressure and Coolant Temperature Gauges l Ordered 6.14.08 | Home 7.16.08
Old 12-12-2009, 08:19 PM
Gallery
Quote:
I went with the m7 Super AGS, but not until I figured out how to get cooler outside air to it. The open scoop and possibly even the heat shield (see sig.) give outside air a straight shot at the very large filter and deflect some of the turbo heat. IATs have dropped from 20-30deg over ambient to 2-3 deg over. Turbo is now starting to spool-up at ~1200rpm. A key thing to remember is that every 1deg drop in IAT equals 1-1.5HP. My butt dyno can really feel the extra torque and above 4K things start happening much faster. Only thing I can't figure out is why I haven't filled the bay with bugs, birds and small dogs. It's staying pretty clean! BTW, when I started these mods 6mon. ago, all I was trying to do was keep the scoop from melting yet again!
Old 12-12-2009, 08:51 PM
willsblackmini08's Avatar
willsblackmini08 willsblackmini08 is offline
Send a message via AIM to willsblackmini08
Gallery
So the oil catch can is a decent mod to get?
2008 MCS AB/AB /Cold Weather/Moonroof/ Comfort Acess Key/Murdered/Quad Driving Lights/Rear Seat Delete/M7 Rear Chassis Brace/M7 Strut Tower Brace/ALTA CAI/Joey mod
MMC # 589 Facebook Flickr HVMINI
Old 12-12-2009, 09:18 PM
Gallery
Quote:
For the long term health and performance of your engine, YES! The PCV system so oiled down my intake that I couldn't keep the turbo intake tube on, and all that oil mist heads straight to the turbo and IC. Dreading the thought of having to pull the IC to flush the oil fouling . Even the OCC and the IC flush won't solve the entire PCV trouble. The other PCV tube is what's causing the carbon build-up on the intake valves. Got no clue (yet) on how to cure that one. Anybody got any ideas?
Old 12-12-2009, 10:48 PM
Davidoyo Davidoyo is offline
Gallery
Quote:
Let me know when you finish the install because I am interested in the results.
09 MCS Dark Silver(Black Mamba)-Premium,Sport&Convenience,Black web spoke wheels.Performance Mods:RMW Dyno Tuned|Helix FMIC|Hotchkis 19mm sway bar|NM discharge pipe,torque arm bushings&tie-bar|Custom 2.5"Magnaflow Exhaust|BFG KDW 215/40/17|Visual Mods:|Hoen H8 fogs&led city lights|M7 grills|Other Mods: BSH OCC&direct dual boost tap|Marshall Boost&Water Temp.Gauges
Old 12-13-2009, 07:56 AM
Gallery
I need to purchase a catch can soon. Its funny, my old VW buddy doesnt believe me how much of a difference these make on direct inject motors....he seems under-educated lol.
As far as 42 draft designs...I definitely recommend them! I have purchased several parts from them on my big turbo VW Corrado in the past, and had nothing but perfect parts coming to me!
Old 12-14-2009, 09:21 PM
Gallery
Quote:
Ain't finished yet, but here's the progress so far. Made a bracket to mount to the fender well flange. Next is the hose plumbing. Want to go over the turbo intake tube to make oil filter changes a little easier. Gonna be tight! Will post when finished, but probably not till after all the rein-deer poo has disappeared.
Old 12-15-2009, 12:32 AM
LiLReD1's Avatar
LiLReD1 LiLReD1 is offline
Send a message via Yahoo to LiLReD1
Gallery
I put a catch can on everything I own. If you've ever seen an intake manifold on a car with 100,000 miles on it, you'd want one to.
And if I may say Dwight... HOOAH to the 101st!
Installed: m7 Super AGS - m7 T/IC boost tube - ALTA FMIC - AccessPORT -reso delete - H&R RSS coil overs - ALTA rear lower control arms - m7 oil catch can - m7 heat shield - m7 CF Vortex 2 hood scoop - 17x7 gold Konig Feathers w/ 205/40-17's
Waiting to be installed: ALTA s/shifter
Old 12-15-2009, 01:20 AM
Gallery
Looks like it's coming along nicely . I might want to do something similar to what you are doing because I can't buy the M7 oil catch as I still have the stock intake and don't plan to change it until my warranty is up(don't want to get crap from the dealer). I mean I only have about 3500 miles on my MINI, but all this talk of engine sludge got me thinking about something like this. If what you are doing works, let me know the exact parts and stuff like that you used because I am not too engine savvy and could never come up with something like this.
Old 12-15-2009, 08:27 AM
Gallery
How'd you figure that out? Yup, I be Currahee. And BTW, if you're gonna be one, be a Big Red One!!
PS: Lamped your front plate.
Old 12-16-2009, 04:52 PM
LiLReD1's Avatar
Gallery
Yer badge on the left of yer window!
Hooah for the 1st ID!
LiLReD1's Avatar
Gallery
Sorry for the jack... back to yer regularly schedule post.
Old 01-22-2012, 04:04 PM
stripes03's Avatar
stripes03 stripes03 is offline
Gallery
where can i buy a m7 oil catch can
2003 MCS Indy Blue with 18''blue accent rims 15% Alta SC pulley
Old 01-22-2012, 04:11 PM
Gallery
Do you have an R56?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
