MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Show us your mods!
by ADAM244
19 Replies, 1,180 Views
Advertisement
Thread Tools Search this Thread
Old 10-29-2009, 05:57 PM
guitfiddler guitfiddler is offline
Gallery
Lots of Alta... Bad dyno???
This is the best of 3 pulls... I have Alta turbo back, FMIC, Hot side boost tube and CAI. It hit about 15.5 psi. No ECU tune. It's Lower than I expected. But were they bad pulls? The curves crossing point was not consistent. Also not at 5,250 rpm like the others i see posted. The one pictured is about 4,700 rpm. Another was at 4,900 rpm. Thoughts? Suggestions?
Automatic if it makes a difference.
Old 10-29-2009, 07:09 PM
mtuning3's Avatar
mtuning3 mtuning3 is offline
Gallery
looks like the turbo starts boosting only at 3500 rpm,the ecu is freaking out at low end,is backing up timing,to much lo end load
back to stock
Old 10-29-2009, 07:29 PM
tintman718 tintman718 is offline
Gallery
Quote:
If you notice, power and torque are not plotted equally.
Need maintenance or mods installed? Taillights tinted? I'm an ASE Master Tech.
tintman718@gmail.com
[Alta FMIC, Alta Hot & Cold Tubes, Ragazzon DP (heat-wrapped), BSH Boost Port, eBay Catch Can, Custom Air-Ride Suspension w/ Airlift Easystreet Management, Custom Stealth Hitch, Momo Shift Knob, LO-JAck, Viper Alarm]
Old 10-29-2009, 08:44 PM
Gallery
So I basically just need a tune...
Old 11-10-2009, 02:42 PM
FugitiveAI FugitiveAI is offline
Gallery
A tune certainly would help! I think if you could see your air/fuel ratios, it would look very lean compared to stock, since your intake and exhaust are wide open. The fuel injectors and ECU mapping aren't keeping up and the ECU is backing off timing down low. Also, you should be seeing boost from 2K-3.5K, with a little dip, then the bigger boost above, but it seems like you have nothing until 3.5K. Maybe you need to be heavier on the gas pedal at the low end of the pull? Also if you hit the floor pretty quickly you get the overboost, which doesn't seem to be happening here. The intercooler may also be playing a part, causing higher loss in boost pressure through the core, though if I remember right Alta claims there is less loss than OEM. There are a few things to diagnose, or you can just add a tune and see how it goes. The stock dyno results I've seen usually show around 155-160HP at the wheels, so there is an improvement here, it just seems a little low.
2007 MCS DS/B (Sold)
1998 M3
Old 11-10-2009, 02:45 PM
chakraj's Avatar
chakraj chakraj is offline
Gallery
hey mtunning3 is that your car in the for sale section?
2008 MCS 6spd Premium, Sport, convenience, Cold weather, LSD...lots and lots of good stuff.
Old 11-11-2009, 11:41 PM
LimonR56 LimonR56 is offline
Gallery
Those are not bad numbers for an AUTO on the MD. Ask your operator to do the following:
- force identical scaling on the two graphs
- do 'Trace Graph' instead of 'power curves'
- plot the AFR along with your graphs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
