MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post My lifted mini is done!
by Moby911
39 Replies, 900 Views
Advertisement
Thread Tools Search this Thread
Old 10-26-2009, 09:37 AM
btwdriver btwdriver is offline
Gallery
Alta exhaust resonator delete?
Has anyone removed the resonator from their Alta exhaust? The reason I ask, is I can't seem to get the exhaust positioned right so that the resonator doesn't sit against the heat shield of the car, making it extremely loud inside.
I was wondering if it would be extremely loud outside if I were to just put a straight pipe in place of the resonator section.
Thoughts?
'07 MCS LB/B, One or two stock parts left...
Old 10-26-2009, 12:52 PM
ThumperMCS ThumperMCS is offline
Send a message via AIM to ThumperMCS
Gallery
Might drone a little bit...
But the Alta exhaust is pretty quiet, so maybe it'd help to open up the exhaust a bit!
2006 MINI Cooper S JCW GP--GP#1599
-Stock...I think??
2008 MINI Cooper S R56--Astro Black/White--Gone
-JCW Turbo | Aquamist HFS-3 Meth injection | RMW AP Tune | Helix FMIC | DDM CAI | Riss Racing Catless DP+Invidia Exhaust
Old 10-26-2009, 01:01 PM
tintman718 tintman718 is offline
Gallery
Is the Alta muffler straight-through or chambered?
Need maintenance or mods installed? Taillights tinted? I'm an ASE Master Tech.
tintman718@gmail.com
[Alta FMIC, Alta Hot & Cold Tubes, Ragazzon DP (heat-wrapped), BSH Boost Port, eBay Catch Can, Custom Air-Ride Suspension w/ Airlift Easystreet Management, Custom Stealth Hitch, Momo Shift Knob, LO-JAck, Viper Alarm]
Old 10-26-2009, 01:33 PM
glnr13 glnr13 is offline
Send a message via AIM to glnr13
Gallery
I know the mufflers are different between the r53 and r56 but for what it's worth I removed my resonator because mine was banging on the middle heat shield and was dying. I loved the sound but the drone on the highway between 65 and 80 mph is insanely annoying inside the cabin. 2 weeks after removal I put in a magnaflow resonator that was a little skinnier but longer than the Alta res. sorry, I don't remember the part number.
also, I had an Alta header with hi flow cat.
http://www.northamericanmotoring.com/gallery/data/500/newsig07.jpg
Old 10-26-2009, 01:46 PM
Gallery
Are other people having issues with the resonator touching the heat shield or should I just spend some more time trying to get it aligned properly?
Old 10-26-2009, 04:05 PM
tfuhst's Avatar
tfuhst tfuhst is offline
Gallery
Mines been doing the same i tried fixing it by placing some thick foam where it was hitting most on the heat shield but it just muffles the sound but its there but not as bad.
R.I.P 2009 MCS Pepper White (totaled) 1-6-10
Old 10-26-2009, 04:52 PM
LiLReD1's Avatar
LiLReD1 LiLReD1 is offline
Send a message via Yahoo to LiLReD1
Gallery
I took the reso off of my R55 JCW, and it sounds a lot better! No resonation what so ever, just a good healthy exhaust note!
I bought the full ALTA exhaust, turbo back, and was leary about throwing on a system that has another reso on it. Let alone, from what I can tell, the ALTA system is pretty quiet, and I definitely don't want to throw on a $1,500 exhaust system and make it quieter!
But yer saying yer reso hits the heat shield? That's unacceptable to me. I'll either sell the system, or be putting in a straight pipe.
Installed: m7 Super AGS - m7 T/IC boost tube - ALTA FMIC - AccessPORT -reso delete - H&R RSS coil overs - ALTA rear lower control arms - m7 oil catch can - m7 heat shield - m7 CF Vortex 2 hood scoop - 17x7 gold Konig Feathers w/ 205/40-17's
Waiting to be installed: ALTA s/shifter
Old 10-26-2009, 05:04 PM
countryboyshane countryboyshane is offline
Gallery
The resonator is straight through, but OH LORD does it love to flex and bang into the heat shield!
'09 MCS in Hibernation
Studies show 100% of people die, so you might as well have some fun while you're at it.
Old 10-26-2009, 05:13 PM
LiLReD1's Avatar
Gallery
So is the one on the JCW, so I didn't think it'd make much a difference it sound, but it does.
Old 11-09-2009, 01:34 AM
juchong juchong is offline
Gallery
What I did is get some pipe clamps and tightened them down on that metal plate under the car that covers the pipe. I then torqued everything to spec (185 in lbs) and left the clamps on for a day or two. I re-torqued everything, took the clamps off, and it's been working like a champ ever since. No more noise! No more vibrations! I would recommend making sure the downpipe-resonator connection is perfectly aligned (get the two rubber grommets fairly level) before messing with anything down the line. It took me a couple hours of tweaking, but I got it!!
Elizabeth: Mellow Yellow 09 MCS, Auto, Premium, Convenience Packages. DQL-8, PDX-5, Kenwood Excelons, Focal 690 CA 1, Fat Mat Sound Deadening, Alta IC, Catback, CAI, 22mm Sway, Koni Struts (F & R), NM springs, TSW Control Arms, Forge BOV, AccessPort, NCS Expert Mods
Old 11-09-2009, 03:29 AM
etalj etalj is offline
Gallery
Sound clips!
BTW, was everything still aligned when you got it back?
Factory built 08/08 MINI JCW: JCW Aerokit, M7 C-Wing, Bilstein PSS10, Vorshlag camber plates, RennSport Racing Rear Upper and Lower Control Arms, Howerton Engineering HFS-3 w/ Race Tank, Whiteline 20mm RSB, RMW Tune, Dunlop Direzza Star Spec Z1, DoS CAI, Evolve FMIC, BSH OCC + Dual Boost Port, NM SSK, etalj-spec torque arm ;), Goodridge SS Brake Lines, Endless RF-650 fluid, Carbotech XP12s, ALTA PSRS, Powergrid adjustable endlinks, Challenge Decals
Old 11-09-2009, 06:16 AM
Gilboyto Gilboyto is offline
Gallery
My resonator was having this problem as well because of how huge it was. It was banging right at the v-band section onto the head sheild between the res and muffler section.
I ended up having my fab buddy remove that v-band section completely and putting a tiny angle when welding so that it doesnt get near it.
I have no rubbing issues what so ever anymore.
| 09 DS MCS w/ LSD | JCW Recaro| RMW | H&R | TSW | CCW | Falken |
Old 11-09-2009, 06:20 AM
malteseracer malteseracer is offline
Gallery
This is a different solution than what you ask, but consider this:
Mine never hit, so I'm not sure why yours would but have a guy throw it up on a lift and see if you can move it forward/backward and get it to stop. You could also throw some spacers on the shield for some vertical clearance if the pipe also hits.
2009 R56 PW/PW "Jeremy"...6 Speed, Sport, Cold, Hi-Fi, Piano Black, Stubby Antenna, Alta Intake, Alta Hot Side Boost Tube, Functional hood Scoop, Alta Exhaust, Alta Rear Endlinks, Scangauge II, Cooper Side Scuttles, 22mm Alta Rear Sway Bar, KW Variant 1 Coilovers, CravenSpeed Adjustable Short Shifter, NM-Engineering Torque Arm Insert, S.P.E.C. Stage 2.5 Clutch and Pressure Plate.
Old 11-09-2009, 06:24 AM
Gallery
That is a good idea as well. Ive heard both that some people have clearance issues and some do not. I attmempted to loosen every v-band the exhaust had and re-twist and re-fit the exhaust, but every time I tightened it up, the v-band on the back of the resonator would immediately hit the car..at the section that would touch chassis of course. lol
Old 11-09-2009, 07:00 AM
Gallery
Maybe you cut too far to the back of the car, assuming this is a cat-back. There is a lot of wiggle room in the fittings that bolt to the rest of the exhaust, but maybe another inch forward you could make it fit properly.
Old 11-09-2009, 08:33 AM
Gallery
People with catbacks...this could be a way to fix that issue. I had to custom fab it though since I have the turboback and still had this issue :-\. Worth the exhaust note though!
Old 11-09-2009, 09:30 AM
Porthos's Avatar
Porthos Porthos is online now
Gallery
Wiggle it around. But you could place some kind of heat resistent padding in between the exhaust and the heat shield. But I don't know if I would take it out cause it might make it raspy and ricey.But on the other hand it might sound awesome. Take it out with and have a test pipe fabbed up so that you can interchange them. Also make sure all the bolts and nuts and clamps are tight enough it might have loosened up and needs to be tightened back down.
I drive €.
Old 11-10-2009, 02:32 PM
LiLReD1's Avatar
Gallery
Custom fab on a $1500 exhaust system? So anyone wanna buy my unused ALTA turbo-back for a Clubbie?
Old 11-10-2009, 02:43 PM
Gallery
Im just good like that ;). Mine was far from an ordinary fit...It was a constant battle of loosening every single v-band clamp for wiggle room from the downpipe back for nearly a week.
But, the good news is...it still fits any Cooper S perfectly, no issues what so ever with rubbing or even close anymore, and my buddy TIG welded the section (its only about 4" long) with stainless so its a one of a kind, rare mini exhaust now
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
