Alta CAI, Turbo Inlet and Noisemaker Delete Install.
Hello. Long time lurker, first time poster. I just finished installing an Alta CAI, Alta Turbo Inlet Hose and a Defenders of Speed Noisemaker Delete. Everything went fairly well, but I do have a few questions...
#1 - The turbo inlet hose instructions mention a vacuum leak could occur if the crank case breather hose becomes loose. Would a vacuum leak trigger a check engine light/code? I didn't get any CEL's (other than a warning to set the clock), but is this something I should keep an eye out for?
#2 - I had to remove the brake booster vacuum hose from where it clips onto the fresh air pipe, because the fresh air pipe sits a lot higher when it's attached to the Alta air box shroud, compared to where it attached to the stock airbox. I was afraid to leave it clipped on because of possibly smashing it with the hood, because it set pretty high up. Anyway, just like the paranoia in quesition #1, is it OK to leave this unclipped? Or should I try to find a way to secure it?
#3 - After the install I drove around for about 30 miles or so. When I'm accelerating and really laying into it I begin to hear a second and higher pitched whistle at about 4,000RPM on up. This is in addition to the regular intake sound. I can hear both distinctly. Any idea what that could be? Is it normal?
#4 - Has anyone had to trim the length of their turbo inlet tube down a bit? Specifically where the MAF sensor housing attaches? With the MAF housing and elbow attached to the turbo inlet tube, it overshoots where it should attach to the Alta air box shroud by a good inch or so. And it was hitting it at an angle. I was able to wrestle it into place while my wife secured the elbow clamp onto the shroud. However, after doing this the turbo inlet tube now rubs against the coolant tank. It seems that trimming the inlet tube would alleviate this.
And those are my questions so far. On a side note, the DOS Noisemaker Delete is quite nice. I can definitely tell a difference with the noisemaker gone, especially on the highway.
A vacuum leak could through a code but, as long as you make sure its tight you should be fine. Whistling could be the turbo spooling but without hearing it I couldn't tell you. The other stuff I am not sure about. I didn't have to do that at all.
If it's a large leak it definitely would. Small leaks won't necessarily throw a could because the ecu will adjust for a lean mixture. You would not notice a rough idle if there was a leak.
Need maintenance or mods installed? Taillights tinted? I'm an ASE Master Tech. tintman718@gmail.com
[Alta FMIC, Alta Hot & Cold Tubes, Ragazzon DP (heat-wrapped), BSH Boost Port, eBay Catch Can, Custom Air-Ride Suspension w/ Airlift Easystreet Management, Custom Stealth Hitch, Momo Shift Knob, LO-JAck, Viper Alarm]
I took these this morning after taking the elbow tube off the shroud. The more I stare at it the more it looks like the inlet tube needs to be trimmed down, and possibly even trimming the elbow tube at an angle so it meets up with the shroud evenly. Again just wondering if anyone has encountered this or has done the trimming.
My turbo inlet rubs on my coolant bottle too. Don't get worried about it. It would take a LOT of miles for it to get a hole from rubbing there.
You will find that when you purchase Alta's cold side boost tube that it will get cuts/holes in it relatively fast. For that reason, many of us recommend the Exhaust Depot boost tubes or Samco. Samco boost tubes are available from www.detroittuned.com
Okay... mine also rubs the coolant bottle quite a bit as well. I have about 20,000 miles on my inlet hose, and I think I am seeing some of the metal reinforcements (maybe?) of the inlet hose. Is this a bad sign, or completely normal for a part like this.
But yes, it's true that ALTA parts definitely have some fit and finish issues, hehe.
2008 PW/B MCSa - Delivered 08/16/2008
Installed: ALTA Front-Mount Intercooler, Defenders of Speed Air Intake, ALTA Hot Side Boost Tube, NM Engineering Cold Side Boost Tube, ALTA Full Turboback Exhaust
I would be interested in what numbers you are putting down at the wheels after those mods. You have done everything I have plus the Alta Exhaust. I am considering a high flow exhaust system and wondering what difference it will make to the figures.
I installed an alta turbo inlet hose and old-style Atla CAI today... Everything fits REALLY tight. I bought everything used so I suppose its possible that the previous owners of these parts did not trim them down. My main concern is that my engine seemed to get very hot after I took it for a run with the parts installed. Also the small hard plastic hose that runs on top of the inlet hose seems to sit very high now, compared to how it used to. Maybe im just being a worry wart...
