MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Best FMIC
1 Replies, 17 Views
Go to first new post Hello - Great site!
5 Replies, 58 Views
Advertisement
Thread Tools Search this Thread
Old 10-20-2009, 05:26 PM
epanarese epanarese is offline
Gallery
How to get rid of lash
So my 2003 MCS with 70k miles is very hard to shift smoothly. In fact, after 3,000 miles of driving it, I still don't feel like I have the timing down, especially between 1st and 2nd, 2nd and 3rd. Further, when my foot is off the pedal and I suddenly step on it, I can feel some very serious drivetrain lash.
I got to thinking, do I need to replace my motor mounts? Or should I get one of the TSW dampers? I have an 03 so my motor mounts are actually the rubber ones, not the oil-filled ones. Which part is going to make the biggest difference for me?
Old 10-20-2009, 05:36 PM
AutoXCooper.com's Avatar
AutoXCooper.com AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
Gallery
The TSW Damper will help for sure and with 70K some IE bushings would help too. I'd try the Damper Kit 1st since it will help without as much extra vib that the other poly mounts will give you.
Old 10-21-2009, 08:32 AM
Bigshot Bigshot is offline
Gallery
I disagree......if the mounts are that bad, adding a damper to the mix is only going to put a bandaid on a more severe problem. A set of bushings will cost less than the damper will.
Check out http://www.outmotoring.com/mini-coop..._bushings.html
http://www.outmotoring.com/mini-coop...e_bushing.html
Old 10-21-2009, 08:36 AM
Gallery
Wow so is that the complete kit right there? Upper and lower mounts? That's less expensive than I thought it would be.
Is the trans mount important to replace too?
Can I do the job myself?
Old 10-21-2009, 08:43 AM
checkmate2006 checkmate2006 is offline
Send a message via AIM to checkmate2006
Gallery
Quote:
Sure can
06 MCS SB/S Checkmate
PAPERWEIGHT MOD Crew
Old 10-21-2009, 07:05 PM
KC Jr 54 KC Jr 54 is offline
Gallery
Your upper mount (one bolted to the strut tower) is most likely bad and replacing that should be high on your list. 'Should' only cost you $50 or so from Mini Mania. The older 'main' mounts are also filled with oil, not entirely rubber, but they have less issues. That might be bad as well, but without photos is hard to tell.
All the mounts are very easy to replace, and if you choose to do the tranny inserts (highly suggested) the hardest part will be removing everything to get to the mount itself.
Personally i have the IE inserts in the lower and the tranny, with a dampner on the pass. side. I get some vibration at idle, but the positive fill gain is VERY worth that tiny NVH.
Old 10-21-2009, 07:20 PM
Gallery
Quote:
This was based on the thought that his OEM bushings were not bad.
The IE bushings will do the same thing as the Powerflex and will help but may not be needed IMHO.
Old 10-21-2009, 08:22 PM
WayMotorWorks WayMotorWorks is online now
Vendor
Gallery
Garage
We have the complete Powerflex Engine bush packages for both the early and late cars. These are an afordable set that will def. cut down on the engine rock.
Yes you can probaly install these yourself. They only need hand tools to install and a little time.
MINI OEM and Performance Parts, Service, Racing, ECU Tuning,and Repair
Owner of the Texas Speedwerks Company
Old 10-21-2009, 08:52 PM
gokaht gokaht is offline
Gallery
Grab the mounts - we'll put them in with the pulleys - PS - I have the TSW damper in my 03 - it REALLY helped with shifts and drivetrain movement. I've gotta add the powerflex stuff too. Clutch/flywheel first...
MOTORING ADVISOR @ HERB CHAMBERS MINI OF BOSTON
'03 MCS : 6SPD : JB/B : 82K MI : RMW TUNED (201.1WHP BEFORE NEW BELT, 17%, NEW CAT) : K&N 1550 HAI : CM FX300 : JBR FW : WMW 17% : 380CC : MSD : HOTWIRES : TSW DAMPER : MILLTEK : B&M SSK : TT BOOT : H&R'S : SPARCO MILANOS : CHROMELINE : BOBCATS : TSW CARBONS : STOPTECH SS LINES : BRASS BUSHINGS : VIS CF HOOD
Old 10-25-2009, 05:55 AM
howsoonisnow1985's Avatar
howsoonisnow1985 howsoonisnow1985 is offline
7th Gear
Gallery
Wow, $85 for all bushings needed for 06?
2006 MINI Cooper JCW GP0019
RMW tune & cams*17% pulley*ITG filter*Brisk plugs*H-Sport Comp RSB*KMac camber plates*resonator delete*TSW studs/jack pads*H&R 5mm spacer*CT AX6 pads*Motul RBF600*RedLine*15x7 Motegi TrakLites2*Nitto NT01 205/50-15
BRG/W 2003 MINI Cooper S R.I.P. Sheila
Old 10-26-2009, 08:06 AM
Gallery
Why don't you included the small bushings in the later cars?
Old 10-26-2009, 10:08 AM
herbie hind herbie hind is offline
Gallery
a good calamine lotion or ........never mind
HERBIE HIND
04 mcs hai, 15%, alta full,mm oil cooler, auto meters, modded bpv,konig 16's ,faulkins,tex spd wrks rotors , m7 strut brace . webb head, methanol inj.380cc helix's,giac tune. m7 cc .
Old 10-26-2009, 04:34 PM
Gallery
OK......
Old 10-26-2009, 07:47 PM
Gallery
Could use zip ties to reduce the lash
I know for body work it works great just for fun with an already busted bumper
Old 10-27-2009, 05:26 PM
JPMM's Avatar
JPMM JPMM is offline
6th Geared
Send a message via ICQ to JPMM
Gallery
Quote:
Originally Posted by gokaht View Post
- PS - I have the TSW damper in my 03 - it REALLY helped with shifts and drivetrain movement. .........
me too, get the TSW damper, tighten it up until you like it .It will help the car as it was made to be smooth and because of that the motor will move around(wind up and then let go) on the liquid motor mounts when changing gears and starting off.
2009 fJCW BamaCooperS's ole Red
Old 10-28-2009, 06:51 PM
MrCooperS's Avatar
MrCooperS MrCooperS is offline
Marketplace Moderator
Gallery
Garage
Is that your MINI's halloween zombie costume?
///MINI Cooper S
Old 12-04-2009, 09:20 AM
Gallery
Electris fence wire works pretty well too!! LoL. I really like your bumper.
Old 12-04-2009, 09:47 AM
Curious George's Avatar
Curious George Curious George is offline
Gallery
I dont know why i like this, but i do. Maybe with black or white or blue zip ties.
The Shoebox : 2005 PW/PW MCSa, Sunroof, Xenons, DSC, Heated Seats, Auto-Up Circuit, Alta Panel Filter, Alta V2 17%, BRISK Plugs, Bridgestone G019 Grids.
Old 12-04-2009, 10:41 AM
skippydog skippydog is offline
Gallery
Ohh the doc did a good job! When do the stiches come out?
But yes dont just throw the damper on replace the mounts if they are bad/worn out. Add a damper along with it if you want.
Old 12-04-2009, 01:34 PM
Gallery
I have another bumper for spring and summer.
Old 12-04-2009, 01:51 PM
Aeromax Aeromax is offline
Send a message via AIM to Aeromax
Gallery
I have a poly mount on my lower large engine bushing, and I had one on the trans mount which was great for reducing lash, but the vibration was killing me so I took it off after like 1000 miles. (Still have it if anyone wants to buy it!) I still have to do the upper mount, but I kept reading that the lower mount was the one that took the brunt of engine movement.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
