MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post My lifted mini is done!
by Moby911
39 Replies, 900 Views
Advertisement
Thread Tools Search this Thread
Old 10-15-2009, 05:26 PM
p00n p00n is offline
Gallery
Limiter in first and second gear
Heya dear fellows,
i got a MCS r56 eu spec 12/06
with a full exhaust , jcw filter and a forge IC installed.
I did a ecu tune and the only thing we cant figure out is in first and second gear as the car accelarates and goes to the rpm that it reaches its top power , suddely you feel the power to be cut off a bit , but as you change gear it starts to accelerate hard due to the high torque again. Only in first and second gear i got this problem mostly. So is the a limiter for torque or something and can it be removed?
Best regards and thanks for your answer
Old 10-15-2009, 08:40 PM
FugitiveAI FugitiveAI is offline
Gallery
the car with stock ECU does this as well, but I wonder if the tune may have accentuated this. Are you disabling both DSC and ATC? I don't think the ATC would give such a feeling as it really only backs throttle enough to reduce wheel spin but that also could be overreacting with the tune. I think monitoring air/fuel ratios while on a dyno could be helpful. I wish I could be of more help. Best of luck with this!
2007 MCS DS/B (Sold)
1998 M3
Old 10-16-2009, 09:15 AM
Bigshot Bigshot is offline
Gallery
Are you hitting the rpm limiter?
Old 10-16-2009, 09:55 AM
Gallery
nope , got 2k 1,5k revs before the limiter
its as if the torque drops >.>
Old 10-16-2009, 07:31 PM
ThumperMCS ThumperMCS is online now
Send a message via AIM to ThumperMCS
Gallery
Yes there is a limiter. I have no idea about the specifics on it though, but it's very evident in my car. On my US spec car, its only in 1st though.
You can see it in the boost as well, it only boosts ~11psi max in 1st, shift into 2nd and the car takes off and boost is ~18psi. So, there is something that limits the boost it would seem. My car is tuned, so its more evident than it was when stock. When I race my friends stock R56, we are always dead even through first, then I shift into 2nd and I become car lengths ahead.
The limiter is there to prevent excessive wheel spin when people are starting from a stop. So, when you have some moron who has never driven a high torque FWD car, they don't go flying into traffic from torque steer when they start off from a start. Little bit of cover your ass on MINI's part. I'm sure it's easily defeatable as long as the map is found for it. But to be honest...with 240 ft-lbs to the wheels, I kinda like having a limiter in 1st...even if it is a little boring. Cuz with it all on tap in 1st, I'd be doing nothing but roasting tires.
2006 MINI Cooper S JCW GP--GP#1599
-Stock...I think??
2008 MINI Cooper S R56--Astro Black/White--Gone
-JCW Turbo | Aquamist HFS-3 Meth injection | RMW AP Tune | Helix FMIC | DDM CAI | Riss Racing Catless DP+Invidia Exhaust
Old 10-17-2009, 07:13 PM
vmk82 vmk82 is offline
Send a message via AIM to vmk82
Gallery
every turbo car has it and its necessary
look at your first gear, gear ratio
your wheels and motor would not be happy if first wasn't limited
EXT/INT: M7 vortex scoop gloss black, bimmian HID interior lights,Stubby antenna,6000k h13's, currently Blizzak LM-25's, abut to plasti dip
PERF: DDM Works CAI RIS, Exhaust Depot 2.5" Downpipe, Invidia Q300, ED Hardpipes ans HKS SSQV JAN TUNED v 1.5 catback, Alta Turbo Inlet Tube
Wishlist:Helix FMIC, Tein coils,
Old 10-18-2009, 01:29 PM
eg0911 eg0911 is offline
Gallery
Mine doesn't seem to be limited. It pulls hard all the way to redline in 1st.
Old 10-18-2009, 02:55 PM
MotorMouth MotorMouth is offline
Gallery
Quote:
Of course it pulls hard - it's first gear. Without the limiter you wouldn't be pulling. You'd be SPINNING
Laser Blue/White MCS delivered 3/8/07. Off lease 5/17/09.
Tigger - 2009 JCW delivered 4/27/09, FMIC, boost gauge, Striped and tinted
Alta AccessPORT tune - 267wtq & 219whp
MINI #3 - 2011 White Silver/Black MCS. Delivered 5/11/11. All glass tinted;bobcat pads;OZ Ultra Leggeras;205/50/16 Starspecs
Old 10-18-2009, 04:20 PM
Gallery
it doesnt spin if the surface is clean, like at the drag strip. i have 17/225/45's on my car and they are mx's they have plenty of traction with full power in first. The main difference i have had with the unichip is 1st doesnt seem limited like it was before
Old 10-18-2009, 04:47 PM
Gallery
Then you don't have enough power. See? there is a limiter.
Old 10-18-2009, 04:50 PM
Gallery
Mine doesn't seem to be limited. .
iThe main difference i have had with the unichip is 1st doesnt seem limited like it was before
you just contradicted yourself. It WAS limited before you overrode the stock parameters with the unichip. It's possible that it is still limited - the limits could be higher now.
I could spin my 16" runflats in third gear with the unichip. So of course you should spin in first with ANY tire you can fit. (I had daily CELs for a long time also but that's a different story)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
