P0302 - Cylinder 2 Misfire - North American Motoring
Thread Tools Search this Thread
Old 06-09-2009, 11:02 AM
FL_blue_MINI's Avatar
FL_blue_MINI FL_blue_MINI is offline
Okay guys and gals,
I have had it up to here (Place image of person holding hand above head here) with the misfire thing...
About a month and a half or two ago I got a misfire code P0302. I was driving down the highway and the MINI went into limp mode. Thinking maybe its just a freak occurrence, I turned the car off and when I started it back up, it was fine. At that time I was at WOT in 6th about 4000RPM.
Now I have tested it and it will happen in 5th and 6th gear only, ~at 4100RPM, doesn't matter if its WOT or not. So, now I stay away from the higher speeds.
I looked at the plugs that were there at the time, and they looked "OK" OEM, I swapped #2 with #1 and then #2 with #4, and no avail. Since then I have replaced them, wires, and coil. I am tired of just throwing money at it to try and solve this. I also took off the intercooler and throttle body, cleaning both of all oil/dirt/grime.
Any ideas?
Addison
Old 06-09-2009, 11:12 AM
When you swapped the #2 and #1 plugs, did you get the same code and Limp mode?
Questions:
- what plugs did you replace them with?
- did you clear the codes after the parts were replaced?
- did you check your injectors? swap it out with #1 and see if you get the misfiring code in cylinder 1...
mike
Old 06-09-2009, 11:16 AM
Quote:
Questions:
mike
1. I honestly don't remember. I want to say Denso Iridiums.
2. I did clear the codes, I have the Scangauge II.
3. I did not check my injectors. I will try that tonight. Is there anything special I need to do to remove them?
Would there still be a random-ish problem like this if the injector was bad? Wouldn't the problem be consistant? Or am I wrong in that assumption?
Addison
Old 06-09-2009, 12:54 PM
checkmate2006 checkmate2006 is offline
wear mechanics gloves for sure
Old 06-09-2009, 01:50 PM
BlimeyCabrio BlimeyCabrio is offline
Old 06-09-2009, 04:16 PM
Thanks guys! so far. I did the switcheroo. We'll see what happens.
Injector 1:
Injector 2: (proposed bad one)
Injector 3:
Injector 4:
I'm going out for a test run. Hopefully the misfire changes to CYL1
Old 06-09-2009, 04:57 PM
quikmni quikmni is offline
I had the same code on a different car. After checking plugs and changing plug wires, I finally traced it to the fuel injector electrical connector not making good contact.
Old 06-09-2009, 04:58 PM
Nope. That didn't do it. Still got the code at 4300RPM on Cyl 2.
Old 06-09-2009, 05:16 PM
Fatherdeth Fatherdeth is offline
Reverse for me. It's cylinder 3 kicking the misfire for me. Are you getting any othe codes too. I've got a P0108 code and I'm going with a bad MAP sensor. Good luck and keep us posted.
Old 06-09-2009, 06:02 PM
Mine was doing it a couple of months back and went away after I cleaned and greased coil and spark plug terminals. But I know you're both past that. Misfires are a bit hinky to diagnose on these cars...
Old 06-09-2009, 07:47 PM
The only other code that I got p1688 which from what I can gather is "Electronic Throttle Control Monitor Level 2/3 Mass Air Flow Calculation"
I'm not sure if they are related or not.
Old 06-09-2009, 08:06 PM
62minimn 62minimn is offline
I had the same code and changed all the same parts and more. Finally flowed the intake manifold and found it flowed 17-20% more on cylinder 2 than any other cylinder.
Old 06-09-2009, 10:20 PM
Quote:
I'm not sure I understand what you mean. How did you test and what does that mean?
Old 06-10-2009, 01:50 PM
Flowed intake manifold
We put the intake manifold on a flow bench, it should that the volume of air that in #2 cylinder was much high than the others. So if the same amount of fuel is applied to each cylinder the ratio of fuel to air is really different in one cylinder. In my case it was more air than fuel which had one cylinder really lean and hot.
Old 06-10-2009, 07:04 PM
Ok, thank you for the explanation. How can we/you/I fix that? Is there a way? Can I test that anyway here?
Old 06-10-2009, 09:30 PM
batrugger's Avatar
batrugger batrugger is offline
You should do a compression test. I went through this same thing on the same cylinder and ended up having a bad valve. A few months later after getting it all fixed up, we were having random misfires and fixed it all and picked up almost 40 more whp by changing both MAP sensors and the wiring harness. It has been running perfectly now for almost a year. So I would say that there are three more possible fixes for you. Good Luck
Old 06-10-2009, 11:04 PM
Quote:
UGH. That sounds expensive....
Old 06-14-2009, 04:56 PM
Well, I just ran a compression test:
CYL1: 155psi/155psi
CYL2: 160psi/156psi
CYL3: 160psi/160psi
CYL4: 161psi/161psi
These are test1/test2. both run "dry".
Old 06-15-2009, 12:35 AM
batrugger's Avatar
Compression is good then. Our number 2 was only hitting 80 and all the others were where you are at. You may want to try replacing the MAP sensors especially if you are throwing that p1688. There are two, one right in front and the other is right next to the throttle body.
Old 06-15-2009, 09:04 AM
Quote:
If you are having the same problem I had the only way to check is to remove the intake manifold and take it to someone with a flow bench. I am not sure if anyone wants to take the time to machine the stock intake to make them even. At the time I had search here and a couple other website and found others that discovered there could be a large difference between the parts, they had suggested maybe Mini had more than one factory making the parts and there were differences in the molds. I ended up going with a aftermarket intake. Just for your information my car has been tuned on a Mustang dyno, at 195hp I burned a valve seal, 210hp I blow a hole in the head. During the tune if we had the A/F about stock the tubes on the exhaust would begin to glow, so the A/F was set to the rich side to avoid this happening. Since everything was measured from the tail pipe we did not know that is was one cylinder running so different. After putting the hole in the head we starting measuring everything and that is when we found the the problem. I did have my rev limiter up to 7800 and both problems happened at high revs. Not sure if this helps you are not.
Old 06-15-2009, 02:00 PM
Well, I don't know what to do.
Today I got two more, different codes, P0123 and P0222.
P0222 Throttle/pedal position sensor/switch 'B' circuit low
P0123 Throttle/pedal position sensor/switch 'A' circuit High
Old 06-15-2009, 02:05 PM
bean's Avatar
bean bean is offline
take it to Vista and ask to have greg work on your car....
Old 07-12-2009, 07:37 PM
suysal7734 suysal7734 is offline
Hi guys i changed almost everything, plugs, coils, injectors, fuel pump and still getting the P0203 misfire code.
Any advice for next step????
I notice today when fuel in the tank is less than half i get P0302 more often, i fill the tank and i drive it 75 miles without P0302
Please anyone with great idea shoot me a email at [email protected], i am sick and tired throwing money to this problem, i am at the stage where i will drive the car to one steep clif and let it go
Old 07-12-2009, 09:13 PM
I don't know what to tell you... I ended up swapping Injectors 2 & 4 again and used some 3-in-1 oil on the O-ring, I don't get the code anymore. So, I am thinking it was a bad seal.
Old 07-13-2009, 02:36 PM
UKSUV UKSUV is offline
Ever since I pulled my engine for my 6 speed swap I have been getting misfire codes at random. Whenever the car feels like it. All throttle settings. And the misfire codes would be different. So you ask yourself. What is in common? Well...the pack for one. Changed the plugs, pack and wires. Still happened. And its not an injector because I have multiple cylinder misfire to along with individual cylinders. I know its a loose ground or the main injector harness connector because of the engine pull....I just dont really care to fix it right now. Well...I havent had my car for like 4 months...but thats a different story.
Thread Thread Starter Forum Replies Last Post
P0302 this morning randeez Stock Problems/Issues 18 10-05-2015 10:23 AM
Wilwood Dynapro 6 Big Brake Kit Black Drilled Slotted - Mini Cooper & S Mini Mania Tires, Wheels & Brakes 0 10-01-2015 11:38 AM
Wilwood Dynapro 6 Big Brake Kit Black Slotted - Mini Cooper & S Mini Mania Tires, Wheels & Brakes 0 10-01-2015 11:17 AM
Carrillo pistons and rods available at Sneed4Speed SneedSpeed Vendor Announcements 0 10-01-2015 04:01 AM
Confirming a blown head gasket silence2-38554 Stock Problems/Issues 2 09-28-2015 01:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
