MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post I did it!!!
4 Replies, 61 Views
Go to first new post Best FMIC
0 Replies, 1 Views
Advertisement
Thread Tools Search this Thread
  #26
Old 04-07-2009, 06:03 AM
newbs49 newbs49 is offline
Gallery
That should not be a problem either. There are plenty of cars running around with 15% and no 380's. Yes a tune would help, but your not in any danger. Plus your running JCW software from your sig.
If you have a dyno in the area get someone's remote tune.
  #27
Old 04-07-2009, 05:24 PM
JPMM's Avatar
JPMM JPMM is offline
6th Geared
Send a message via ICQ to JPMM
Gallery
Thanks for the info. Now , I was thinking about a JCW rear wing , but maybe I should increase the sc drive and boost instead
Glueing or wrenching ,,, ummm?
2009 fJCW BamaCooperS's ole Red
  #28
Old 04-07-2009, 05:43 PM
Gallery
Get yourself a good header and exhaust to let that baby breathe.
  #29
Old 04-07-2009, 06:40 PM
mini_racer's Avatar
mini_racer mini_racer is offline
Gallery
Certainly a header will help with breathing and provide some performance. However, the JCW exhaust is really not that restrictive.
While there are plenty cat back systems that will arguably sound better than a JCW system, I am not so sure they will provide a significant improvement in breathing or therefore performance.
  #30
Old 05-11-2009, 07:14 PM
JPMM's Avatar
6th Geared
Gallery
Getting a 15% but now I'll need the JCW pulley remover
  #31
Old 05-11-2009, 07:17 PM
JPMM's Avatar
6th Geared
Gallery
big cost diffs
Thats a good idea but..... a couple of hundred $$$ versus a couple thou?(only guessing on the cost of the new improved s. charger)
Quote:
Originally Posted by enologuy View Post
I have thought of this as well. However, since I now have over 65K on my car, I am going to wait until the new SC being developed by RMW is available at the end of the year. It will make the 15% pulley obsolete.
  #32
Old 05-11-2009, 10:10 PM
M3NTAL M3NTAL is offline
Gallery
There is no such item (that I know of)
  #33
Old 05-11-2009, 10:20 PM
JPMM's Avatar
6th Geared
Gallery
Quote:
well the one that can be used on the 11% JCW (MiniMadness?)
  #34
Old 05-11-2009, 11:42 PM
mini_racer's Avatar
Gallery
I bought my 15% redux pulley from Madness and they hooked me up with a puller for the JCW pulley.
  #35
Old 05-11-2009, 11:54 PM
Gallery
Well that is interesting news then!
  #36
Old 05-12-2009, 07:49 AM
TRuTH's Avatar
TRuTH TRuTH is offline
Gallery
I am thinking of putting a 15% pulley on my wife's '04 with about 60k miles on it, does this increase the wear on the motor and do i need to worry about something breaking faster than normal. She just uses it as a daily driver and will never see the track or autoX course. We also have a ALTA CAI, and are getting a cat back exhaust in the next few weeks. Thanks for the input in advance.
  #37
Old 05-12-2009, 08:54 AM
davisflyer's Avatar
davisflyer davisflyer is offline
Gallery
I pm'd Jan at RMW and asked him if he thought it was worth going from the JCW pulley to a 15% pulley and this was his advise:
"I wouldn't swap the pulley unless you want to run methanol on the track".
So I gather for street driving, it's really not worth the difference. Get a cam instead!
2006 CR/B MCS JCW, RMW (Newman) Cam and RMW Street Header, JCW Suspension, H&R 19mm rear anti-sway bar, IE fixed camber plates, Mason Engineering lower strut brace, Continental ExtremeContact DW Tires, Red interior, Chrome, HK, RMW Tune, 223 WHP / 200 WTQ
  #38
Old 05-12-2009, 05:50 PM
mini_racer's Avatar
Gallery
Well for my JCW car, I have the 15% pulley and the RMW cam. For the street, the 15% was more important as it moved the power down the rpm range. For the track, the cam really helps as it has great value above ~4.5k rpm, and that's where you play on the track.
  #39
Old 05-13-2009, 08:04 AM
davisflyer's Avatar
Gallery
I never have had a problem with low end torque on the JCW. Definitely feel it on the stock MCS, but it's never been a problem for me. I guess for me, it's simply not worth the expense and trouble of installing the 15% pulley for a small gain...
  #40
Old 05-15-2009, 02:21 AM
howsoonisnow1985's Avatar
howsoonisnow1985 howsoonisnow1985 is offline
7th Gear
Gallery
Jonspeed 17% Pulley
Quote:
Originally Posted by Keano View Post
Interesting - that was the sorta increases I was expecting from the change... if low/mid range is improvedthen that is really what Im after
Is it not worth just going for a 16%/17% pulley instead? More pronounced difference perhaps - any down sides to the 16%?
BTW I did order the 17% Jonspeed Stamped Steel Pulley (OEM like) $102 shipped.
2006 MINI Cooper JCW GP0019
RMW tune & cams*17% pulley*ITG filter*Brisk plugs*H-Sport Comp RSB*KMac camber plates*resonator delete*TSW studs/jack pads*H&R 5mm spacer*CT AX6 pads*Motul RBF600*RedLine*15x7 Motegi TrakLites2*Nitto NT01 205/50-15
BRG/W 2003 MINI Cooper S R.I.P. Sheila
  #41
Old 06-18-2009, 01:14 PM
JPMM's Avatar
6th Geared
Gallery
Got the 15% pulley install. In a nutshell; the car runs through the lower gears more easily, you can short shift it and the flat spot in power is gone . The high RPM stuff is definitely more fun. I think the difference in the heat soak/timing pull etc is more pronounced though, even with the mighty GP IC.
  #42
Old 06-19-2009, 04:09 AM
Keano's Avatar
Keano Keano is offline
Gallery
Had my car in to check how its doing and get a base dyno run to see if its healthy and to check to see if I needed a new charger (if I needed a new charger i was going to get a 15% pulley at the same time ;) ). Well its boosting well and with just a GP IC it was making 221.6bhp so Im dont think its going to be worth getting the pulley but will instead increase the power through other parts - starting with a new manifold :D
Basically I dont think the small gain over the JCW pulley will be worth the expense...
UK - R56 Cooper s, Stealthcat DP, MeisterR coilovers, SPC arms, fJCW backbox, BBS RC323 (ET35 7.5Jx17) and 205/40/17tyres. 190bhp 210lbft
  #43
Old 06-19-2009, 07:49 AM
JPMM's Avatar
6th Geared
Gallery
Maybe I should have been more clear, I changed the JCW pulley to a 15%er and I believe it was a good mod for the money. . I can't do anything more than big money hot rod stuff or a custom tune somewhere way out of the area so I'm really at the point of diminishing returns . Installed the M7 Extreme scoop a couple of days ago to help with heat.
  #44
Old 06-19-2009, 08:02 AM
mini_racer's Avatar
Gallery
Upgrading to a 15% over my OEM 11.45% JCW pulley was well worth it to me/my car. The improvement was significant.
As far as a new manifold is concerned, if you are talking:
1. Intake, then don't bother as on a forced inducion engine porting/polishing the intake manifold, or improving it's flow will have an insignificant effect on performance. You certainly will not be able to feel anything.
2. Exhaust header, well you will definitely pick up a few HP on the top end with a lower back pressure exhaust header.
  #45
Old 10-15-2009, 01:20 PM
Luys's Avatar
Luys Luys is offline
Gallery
Yesterday I have installed the 15% over my JCW pulley. I feel better acceleration in the low-mid. The boost was 13.5 PSI and now 15 PSI. It is good upgrade for daily use car. About HP gain 5-7 I will see on the dyno. I have already RMW cam and meth with JCW pkg.
Mini Cooper S JCW 06'
  #46
Old 10-16-2009, 10:47 AM
Gallery
If you dyno the car again, ley us know your new numbers please.
  #47
Old 10-18-2009, 05:57 PM
7th Gear
Gallery
[quote=Luys;2898662]Yesterday I have installed the 15% over my JCW pulley. I feel better acceleration in the low-mid. The boost was 13.5 PSI and now 15 PSI. It is good upgrade for daily use car. About HP gain 5-7 I will see on the dyno. I have already RMW cam and meth with JCW pkg.[/quote
Yes, dyno please
Quote:
Originally Posted by WWW View Post
Mini 5280 recently had a Dayno Party . To find results go to Club and Reginonal forums, United States West, Mini 5280 and Look at ABOUT 15 message down and open Mini 5280 Dayno Day, 2nd message down is Old 81 posted the results. Click on Line above Mini 5280 Dayno Day and it will show all the results. 1 car was stock and the rest have been modify and the modifications are on the right colum.
OK where is this?
  #48
Old 11-04-2009, 10:26 AM
Keano's Avatar
Gallery
Sorry was talking about the exhaust manifold (header) and have now done this mod - was very disappointed with the gains though: 1bhp and 5lbft....
However since then Ive made a few more changes... Ive now got a a newman camshaft and custom tune done and am running 238bhp (not sure on the whp think it was just over the 200whp mark).
I was assuming that I would have got around 5-9bhp from the header (;) ) so was hoping to be over the 240bhp mark... so have decided to change the pulley to get me up closer to where I want to be
Have now bought a new 'charger - so I can keep my jcw charger with jcw pulley in tact - and intend to go for a 16% pulley. I have the GP intercooler so temps shouldnt be too much of a problem so when the new charger and pulley gets done I will report back
Any guesses on gains?? Im hoping for in the region of 5-12bhp and 5-12lbft - my JCW charger is boosting to 1bar currently so isnt doing bad for 67k miles !!
  #49
Old 11-04-2009, 12:25 PM
mini_racer's Avatar
Gallery
Going from the JCW pulley to a 16% will get you in the 5-7hp range, not a huge increase, but it is significant. It is especially important that the performance boost is lower in the rpm range, so you can really feel it.
You will like it, I promise.
  #50
Old 11-04-2009, 12:30 PM
mini_racer's Avatar
Gallery
double post delete
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
