Drivetrain RMW shorty code P0036
#26
I'll let you know for sure later today, but if you could also send me the updated bung for the O2 sensor, that'd be great.
(I know you asked for my address last week, just hadn't gotten around to sending it to you yet!)
#36
I just picked up the car from Helix after getting the header and cam installed after a few obstacles - see here for details https://www.northamericanmotoring.co...rmw-helix.html
Impressions :
Impressions :
- At idle the car is pretty much the same noise level barely any lope.
- Driving around calmly - there is barely any noise increase.
- Once you are past I'd say 60% throttle it definitely takes on a sounds of it's own. Louder and racier. Car sounds nicer when you rev it.
- Launched - ran through 1st gear, 2nd and 3rd - the car pulls effortlessly throughly the gears. There is a struggle for traction in 1st gear from 3500 rpm through 5000 rpm.
- Definitely producing.
#40
IF that was directed @ me - the answer would be when Jan comes to Helix in Philly once they are set up @ the new shop.
#42
I am not sure - I think Eric is planning a big move of equipment within the next few weeks - I know it is very close to moving time.
#43
dude.
with words like"bung"
....and images that resemble an erectile dysfunction commercial gone wrong.
It's purely awkward......but mainly funny.
#44
Guys, I couldn't understand what is that; the pipe which come from the header?
#46
Do you know if the one you sent me has that attached, I could get up and look but I thought I would just ask, or is that something that needs to be welded on after that you have found out from Testing?
#48
on
Great header. I am loving it.
#50
Just got my header and cam installed yesterday The car runs great, a little loud when you open the taps, but great! I extended both O2 sensor wire harnesses due to the sensor ports are a little furthur aft than on the oem header and I was able to route the wire bundles the origanal way with out them being banjo string tight. No codes so far....now about that tune.
