MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post R56 Modified Intake
17 Replies, 801 Views
Go to first new post "Those Waiting for a 2012"...
by Vapok
1,975 Replies, 53,517 Views
Go to first new post OK we all own MINIs but...
by airmini
1,179 Replies, 58,610 Views
Advertisement
Thread Tools Search this Thread
Old 05-12-2008, 10:03 AM
nabeshin's Avatar
nabeshin nabeshin is offline
Functioning Lunatic
Gallery
Garage
baffled oil pan: opinions?
I'll be dropping the oil pan today to replace a leaking gasket and the oil temp sender. I am thinking about having some baffles like the mini madness oil pan welded in while it is out. Would this be worth it? I do not think that I can pull enough sustained Gs to cause oil starvation, but this would only cost about $50 in material and labor for a local shop to weld. It is a pain to drop the pan, so I wouldn't want to do it again later just to have the baffles put in.
Opinions please.
9/29/2002 EB/W MCS Broken - temporarily retired
Original owner since 2002.
Old 05-12-2008, 10:07 AM
agranger's Avatar
agranger agranger is offline
Gallery
I think that Gnatster had a baffled setup with hinges to allow oil to flow in but to close under cornering forces. I think he sells 'em, but I can't remember who makes 'em. Maybe send him a PM?
Old 05-12-2008, 10:10 AM
newbs49 newbs49 is offline
Gallery
I'd look at Jan's gated oil pickup. $175.00, but if you wanted it done guicker I guess the pan weld you can get done is better than nothing.
Old 05-12-2008, 10:15 AM
Revolution Mini Works Revolution Mini Works is offline
Gallery
Quote:
you mean like this?
Old 05-12-2008, 10:17 AM
ChrisMCS04's Avatar
ChrisMCS04 ChrisMCS04 is offline
Peace Keeper
Send a message via AIM to ChrisMCS04
Gallery
That's the one I was thinking of...Nice little piece there Jan
Old 05-12-2008, 10:21 AM
agranger's Avatar
Gallery
Yep... that's the one I saw before as well.
Old 05-12-2008, 11:48 AM
Guest Guest is offline
Gallery
Quote:
Originally Posted by Revolution Mini Works View Post
you mean like this?
That's going to do a lot more than a baffled pan. You're isolating the entire stock of oil to the pickup area (And closing off that area from other sources of oil, the other parts of the baffle) with the madness design.
Having the baffles around the actual pickup allows oil to still freely flow around the pan, but keeps it inside the pickup area.
Old 05-12-2008, 12:56 PM
nabeshin's Avatar
Functioning Lunatic
Gallery
Garage
That looks awesome. You don't have any detailed plans for that, do you?
Old 05-12-2008, 01:02 PM
Gallery
Quote:
Detailed plans? It's available, if you want one give Jan a call .
Old 05-12-2008, 01:14 PM
minimusprime's Avatar
minimusprime minimusprime is offline
Send a message via AIM to minimusprime Send a message via MSN to minimusprime Send a message via Skype™ to minimusprime
Gallery
I should add that it's pretty cheap for a custom piece.
I'm the pink power ranger...
Old 11-05-2009, 12:20 PM
Jazzop Jazzop is offline
Gallery
Are the RMW pickup and the Madness oil pan the only two options out there for the R53? Web searches aren't yielding anything else for me.
Also, does anyone make a windage tray that fits in the oil pan?
I must replace my oil pan (some a-hole at Midas stripped the drain hole threads), so the RMW pickup means that I still have to buy a new oil pan. Thus, I'm leaning toward the Madness pan, but I want to make sure I don't overlook any other options.
Old 11-05-2009, 01:08 PM
not-so-rednwhitecooper not-so-rednwhitecooper is offline
Send a message via AIM to not-so-rednwhitecooper
Gallery
Putting baffles in the pan isn't rocket science. If you know someone that's capable of welding aluminum it would be an easy job.
Why not just make your own windage tray? You are gonna have the pan off, make a template and take it up the the metal shop and have one cut out.
-Rick
'03 EB/B MCS
Crap, gotta change my name to Not-so-rednwhite-or-darksilvernwhite-but-electricbluenblackcooper.
Old 11-05-2009, 02:58 PM
Gallery
Can't afford the downtime on my daily-driver/work car. I also have no local resources or contacts. Ready-made, bolt-in products are my only option right now.
Old 11-05-2009, 03:29 PM
BigShow's Avatar
BigShow BigShow is offline
Gallery
I've run the RMW version and it seemed to work well... just make sure the welds are all good before putting it in as mine had come apart when I took it out
Old 11-05-2009, 10:45 PM
norm03s's Avatar
norm03s norm03s is offline
Gallery
While it's down have a oil sender location tapped in it for a oil temp. gauge.
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
George Carlin
You can follow me if you want but it might hurt.
Old 11-06-2009, 10:16 AM
herbie hind herbie hind is offline
Gallery
any chance that on a loooong rt hand sweeper the volume around the pick-up will be depleted? i understand the gates will close; holding in oil around pick -up . but at what point would that oil be used up ? why not two pick-ups in parallel , one at either end of pan ? pump not strong enough to pull them both?
HERBIE HIND
04 mcs hai, 15%, alta full,mm oil cooler, auto meters, modded bpv,konig 16's ,faulkins,tex spd wrks rotors , m7 strut brace . webb head, methanol inj.380cc helix's,giac tune. m7 cc .
Old 11-06-2009, 11:46 AM
ZippyNH ZippyNH is offline
Gallery
You might be able to retap the threads on the old pan, and use some sealant to enable you to put in one of the drain valves like the fumoto from outmotoring....would not add baffeles, but much cheaper than removind the pan...a pretty big job on a MINI.
I might be weary of welding in baffles...with the waffle shape of the exterior from the casting procdure, it might be very hard to get a good weld without causing some thermal stress that may lead to premature failure....hense the reason maddness sells one premade. Just my.02$.
Good luck....keep us updated!
l 2005 MCS l 11-04 Production l owned since new l RMW Tuned l Craven -17% Pulley l Craven Speed STD l Dinan CAI l JCW 380's l H&R 19 MM Swaybar l MSD Ignition l Power Steering Fan Duct l LightInSight l "EURO" MINI Armrest l Euro Parcel Shelf l Brake Light PULSAR(gen2)l Detroit Tuned Tensioner Stop l Blitzsafe/xmradio l Cobra 19IV CB l 4.5' Francis CB25 CB Antenna, mounted on the rear tow rig!!
Old 11-07-2009, 09:20 AM
//MZero's Avatar
//MZero //MZero is offline
Gallery
I put the RMW baffle in mine when I took it out, I consider it cheap insurane. I too would like a windage tray, but IMO pulling the oil pan really isn't that hard.
Old 12-14-2009, 10:11 PM
dhabutcher's Avatar
dhabutcher dhabutcher is offline
Send a message via MSN to dhabutcher
Gallery
I had my pan off, took me less than a half hour to cut the pieces out,
I had a oil leak so i thought While i am here, photos in my gallery
Old 12-15-2009, 03:50 PM
bean bean is offline
Gallery
there will soon be another option. windage tray and crank scraper. a reputable manufacturer moving into the MINI marketplace.
Old 12-15-2009, 07:52 PM
Ryephile Ryephile is offline
The Technophile
Send a message via AIM to Ryephile Send a message via Yahoo to Ryephile
Gallery
IMO, the RMW is the best option on the market. It's the one I chose to install in my MINI. The Madness welded-in baffles will increase time to failure but won't help sustained g loading [i.e. crazy 270 degree off-camber on-ramps]
Cheers,
Ryan
Old 12-15-2009, 07:58 PM
Gallery
Nice pics Ryan
Old 12-16-2009, 12:24 AM
dhabutcher's Avatar
Gallery
Old 12-16-2009, 11:04 AM
Gallery
Thanks for some good info.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
