MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Drivetrain (Cooper S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 04-20-2008, 12:20 PM
richi0207 richi0207 is offline
Gallery
Alta ECU problem- engine problem?
Sooo after installing the alta ecu I decided to have some fun. At the end of 3rd gear I heard what sounded like a loud pop and the CEL went on and boost was lost completely. I turned off and turned the car back on to reset the turbo. The turbo still works but my car feels very slow now am I the only one whos this happen to?
Mods: K&N Typhoon Kit Intake, Alta FMIC, Alta Boost Tubes,Forge BOV, Alta Boost Gauge, ED Downpipe, ED 2.5" Catback,RMW Tune, Sport Stripes, H&R Springs, Mini Challenge Side Stripes, Checkered Sunroof
P.S. Her name is Charlie =) Laser Blue R56
Old 04-20-2008, 12:24 PM
com3tojo3 com3tojo3 is offline
Gallery
Do you have a boost guage? Perhaps a boost tube came loose, I'd probably start there
Old 04-20-2008, 12:34 PM
Gallery
Thanks for the quick reply I checked on it again didnt checking tubes i will shortly. no smoke out exhaust showing its not an internal problem and turbo doesnt seem to be spooling. Happen to know if theres a common place where the tubes detatch?
Old 04-20-2008, 12:40 PM
Gallery
The lack of power is probably due to a boost leak. The increase in boost pressure from the ECU could have popped a boost tube loose. It's not really a big deal, just find the loose tube and tighten it down. If the tubes are fine it could be something more serious, perhaps a bad diverter valve?
Old 04-20-2008, 12:45 PM
Gallery
Hmm if it happens to be a bad divert valve how would I get that checked without dealing with the dealership?
Old 04-20-2008, 12:49 PM
Gallery
Whered you have your mods installed? Or did you do them yourself? Again, I would start with the boost tubes. Thats probably all it is.
Terry @ BMS Terry @ BMS is offline
Vendor
Gallery
Probably not much help but I recently blew my DV valve out at around 20psi. Do they have a history of failure? I figured I just got unlucky.
www.burgertuning.com
Old 04-20-2008, 12:56 PM
Gallery
I don't think Mini's have a history of diverter valve failures, but ive read about common failures of valves on Audi 2.0T's with software upgrades. The diaphragm inside is rubber and it has a habit of breaking when boost is raised
Old 04-20-2008, 01:15 PM
Kirkland Kirkland is offline
Gallery
remove the pnp and see if all of the problems go away
Old 04-20-2008, 01:46 PM
Gallery
problem solved ( i hope) found out that the exhaust side tube of the intercooler came out. putting it in now and seeing if thats all it was. Thanks =)
Old 04-20-2008, 02:00 PM
Gallery
Im sure thats all it was, just makesure its on extra tight this time
Old 04-20-2008, 04:03 PM
Gallery
Soo, I connected the exhaust side of the intercooler tube back in and everything works fine now but the CEL is still on =(...any possible reasons?
Old 04-20-2008, 04:18 PM
Gallery
it might just need to reset itself, if it persists you might have to remove the alta ecu
Old 04-20-2008, 04:44 PM
Gallery
I went to Advance Auto Parts to get my code and the code that read up was p1135-- Air Fuel Metering....Hmmm does anyone know what this could be?
P.S dont want to go to dealership if its something i can do myself since I have the alta ecu =(
Old 04-20-2008, 06:21 PM
JAceMin's Avatar
JAceMin JAceMin is offline
Send a message via Yahoo to JAceMin
Gallery
you need to clear the by either pulling the battery terminal or check the ECU install instructions I recall some trick they had, unfortunatly I don't have mine with me.
Old 04-20-2008, 07:35 PM
SlowB00st SlowB00st is offline
Gallery
Have them reset the code the MAF cel is caused because the MAF is Preturbo so when the pipe was off the system was broken and what the MAF read was not what the engine was taking-in.
07 Chili Red Cooper S 6spd... Mason Engineering Alum STB, JCW Carbon Scoop and Black Grille Trim, Defi BF b00st and Water Temp Gauges on Alta Pods and b00st Port, Alta Inlet and b00st Tubes, Alta Intercooler, Alta Super Shorty Antenna.
Old 04-20-2008, 09:05 PM
Gallery
Ahh I knew I can count on you guys. Thanks for like the third time haha, GO NAM!
Old 04-20-2008, 09:37 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI ADAMSALTAMINI is offline
Vendor
Send a message via AIM to ADAMSALTAMINI
Gallery
Glad you got it solved. Can be quite a fright!
Reset the code and you should be all good!
Let me know if I can help in the future!
Adam Taft: CEO ALTA Performance™
503.693.1702 Ex. 110
WWW.ALTAPERFORMANCE.COM
WebsiteBlogYoutubeFaceBookE-mailAIM
Old 04-21-2008, 05:08 PM
Gallery
Thanks will reset and see how it goes
Old 04-22-2008, 08:23 PM
Gallery
After clearing the CEL. After a few miles of driving i keep getting the CEL with the codes: P2243 - 02 Bank Sensor 1 (Reference Voltage Circuit/Open) and P0130 02 Sensor Circuit Malfuntion (Bank 1 Sensor 1)....Anyone know any possible solutions in what can be causing this problem? ( I started getting the CELs after the tube came off)
Old 04-22-2008, 10:01 PM
th3118 th3118 is offline
Coordinator :: Dynamic MiNi Collective
Gallery
I would start by reconnecting the ECU connectors. Take them off, look for bent or pushed out pins. Reconnect and try it again.
Old 04-22-2008, 10:15 PM
Vendor
Gallery
If the tube came off, the CEL will remain for 10-15 start cycles. Have you actually cleared the codes using a code scan / reset tool? If not the codes will keep coming back.
Let us know!
Old 04-22-2008, 11:04 PM
Gallery
Wow, Adam hard worker I see helping customers at midnight Nice to see Altas always there for you regardless of the time .I cleared it around 3-4 times in the past 2 days but everytime I clear it, it seems like it takes longer for it to come back on, since you mentioned cycle I am thinking after a certain amount of times it'll clear up permanently. I also bumped into this
Quote:
Originally Posted by joey1320 View Post
disconnect the battery from the car.
do a battery reset- touch both connectors that go to the battery posts with with a wrench for a minute.
let battery sit disconnected for 1/2 hour.
reconnect battery.
check to see if code is gone.
if not then do it all over again and let the battery sit longer. maybe an hour.
Should I give it a shot? Im using a OBDII BR-CAN TOOL at home and I used the one that Advance Auto Parts supply. Its night at the moment but will check for those bent or pushed out pins. I unplugged the ECU for tomorrow to see if the CEL will show up. ( I am going to feel sad and lonely without me ECU for one day )
Old 04-23-2008, 04:04 PM
Gallery
Anyone? I dont really want to drive an hour to go to the dealership if its something that is minor.
Old 04-23-2008, 07:42 PM
MotorMouth MotorMouth is offline
Gallery
which generation harness do you have?
Laser Blue/White MCS delivered 3/8/07. Off lease 5/17/09.
Tigger - 2009 JCW delivered 4/27/09, FMIC, boost gauge, Striped and tinted
Alta AccessPORT tune - 267wtq & 219whp
MINI #3 - 2011 White Silver/Black MCS. Delivered 5/11/11. All glass tinted;bobcat pads;OZ Ultra Leggeras;205/50/16 Starspecs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
