Just a curiosity - has anyone swapped a completely different engine into a MINI? Something from a VW or a Honda or ??
Not thinking to do anything, just curious - the VW forums have folks cross swapping engines a lot though in that case it's generally within the same "family" ie a VAG product.
I saw an article in the latest MC2 magazine of one with a Turbine engine in it. I didn't read the article though, but it looks like the engine is mounted in the back.
Put a V6 3.2L SHO motor in it . One of the coolest intakes of all time. And, they're absolutely bulletproof for forever. (as long as you change the rod bearings).
First post!
here is the 3.2SOHC engine from??? i doubt it would fit mind you.
I would think a 1.8T motor would swap pretty (easy)...
that was my thought, but then you are only getting 180-225bhp from a stock engine, then you have to start tuning, you can get over 300 out the stock bottom end, but thats with alot of mods.
now asuming its going to cost roughly the same to mod the VAG engine as it is the mini its going to cost you alot more to run a 1.8 turbo.
if you want a bigger engine speak to RMW n here. theyare coming out with the 2.0 ltr stroker soon and that should answer everyones questions about power!
