MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Welcome to North American Motoring, the North American MINI Community of owners and enthusiasts!
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and photo galleries. By joining our free community you will have access to post topics, communicate privately with other MINI enthusiasts (PM), respond to polls, upload your own photo gallery and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact our support team.
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Drivetrain (Cooper S)
Not a member? Register now!
Welcome to North American Motoring !
» Main Menu
Upgrade Garage
» Latest Main Topics
SUCCESS! Rear view mirror...
RMW REMOTE TUNING FOR R56...
Production week 43 (2009),...
I didn't cut the bump stops...
The most fun production car...
low brake power
205 too wide for snow?
Free Classic Mini...
My Mini Gets Morning Sickness
NM Springs
Advertisement
Vendor
 Aftermarket vendors
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 11-17-2007, 11:48 AM
k-huevo k-huevo is offline
Gallery
Custom Header
Four years ago I viewed a HyTech header that set the standard for any header comparison in my mind. HyTech was too busy to develop a MINI specific model so I gave up on them. A few years later Bob (SpiderX) shows a photo of a custom built header that has the features I’ve been looking for. I kept that picture in the back of my head until I was ready, and as fate would have it, custom fabricator Juston Poole (404-625-1882) was also ready, with tested prototypes and units in use, plus a willingness to begin production.
I muck with the established working design and Juston is accommodating; my ideas cause at least one installation issue and my propensity for jinxing products causes more install hic-ups, but the important part is what works, and this header works. Notice the unique sequential cylinder pairing taking advantage of the MINI’s unique firing order.
D-shaped flange ports with correctly centered primaries, unlike some other headers I've seen.
The workmanship is outstanding. Although merge angles are not critical for the MCS, added effort has been applied to the merging collectors on this build.
An extra bung for wide band use is a part of this package. I’ll let Juston speak for the importance of throat diameters; a venturi can also be seen here.
A high flow cat and V-band flange.
The lengthened primary and secondary tubes require moving the pre-cat O2 sensor down about six inches. Cutting the upper engine harness wire sheath frees up an extra 7.5 inches of sensor wire length.
The header heat shield needed massaging and trimming to fit the header’s power hump shape. Heavy handed work with a hammer caused small cracks to grow into larger ones. Holes drilled at the end of the cracks stops them from going further, straps help support the shield preventing further stress, and assist maintaining space above the primary tubes.
My request for an accordion style flex section increased overall length from the original design.
Had I been aware of the ramifications, I would have done a few things differently like having V-band flanges on the end of the cat and on a transition section, but one must move on to things one has control over. To fit the OEM cat back, a section of the exhaust’s pipe is cut out and a coupler used.
On the road the effect on performance was/is noticeable. From 3,600 rpm torque was pronounced and the motor really came on the pipe above 4,000 rpm all the way to the top. However, anything below 2,000 was flat dead, fortunately that only effected school zones and stop light-to-stop light situations. The power delivery reminded me of a motorcycle motor I had built by a drag racing shop; apply throttle, pause, then, bam. As a side benefit, the exhaust’s sound was wonderfully rich and round like a larger displacement motor; I loved the idle note (and still do).
After living with the header for a while, I realized a resonator was needed. It wasn’t full throttle under load that was bothersome; it was a 2,300 rpm angry buzz. Also, a secondary resonance hovered around the 2,800 rpm area; the hopeful solution, Flowmaster Hushpower II.
After installing, the entire power and driving experience changed. I am so pleased with what that short resonator provided. Power delivery returned to a linear state and the motor gained low-end torque. Part of the power return may be from improving transitional diameters, but I also believe there is some real magic in that Flowmaster piece. The offending resonance wasn’t eliminated, but it sounds off in the distance now rather than engulfing the cabin and the noise duration is clipped short.
I’ve been counseled in the past about the importance of a properly designed header in extracting the most out of a modified head (Endyn’s in my case), and I minimized its role, because after all the OEM part performs adequately. I am now a believer.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: Custom Header k-huevo All other MINI parts and items for Sale (archive) 36 06-07-2008 03:08 PM
Has anyone built there own custom exaust with a performance header? ClintTheMiniOwner Drivetrain (Cooper S) 10 05-07-2007 08:44 AM
ALta header or custom tune ? fullcollapse40 Drivetrain (Cooper S) 2 04-17-2007 06:09 AM
Custom header for the SpiderX SpiderX Drivetrain (Cooper S) 29 12-01-2006 07:17 PM
Custom Header astrochex Southern California 0 11-11-2004 01:54 PM
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
Search Engine Friendly URLs by vBSEO 3.2.0
