I've got a few convertable detailing jobs coming up and I was wondering if Mystique would do the trick with cleaning the convertable soft tops. I have 303 fabric cleaner as well, so I was planning to "spot treat" with that if needed. However, if Mystique wouldn't do the trick, what would? I am thinking about just biting the bullet and ordering Renovo Cleaner and Ultra-Proofer and just hold on to them for future details... Any ideas?
I have used both 303 & RaggTopp cleaners. They both seem pretty equal. Last weekend I used the Renovo protectant for the 1st time (after cleaning with some leftover RaggTopp) & I really liked the control I had over the brush-on application of the Renovo
Tact is for people who aren't witty enough to be sarcastic...
Brendan, if you use 303 or Raggtopp cleaners you will need to reapply a waterproofer. I just use water to rinse my top unless I wish to strip the sealer off and reseal.
Mystique will really gum up the canvas so I avoid getting any on the top when washing the MINI.
+1
Water only for normal wash
303 cleaner only IF you plan to reapply protectant
reapplying any of the spray-on protectants is a most-of-the-day process with multiple coats, drying between each, and using sheets to mask off the rest of the car. Or use a brush on protectant...
I'm Paul, The car is Blimey--- BlimeyCabrio's Blog--- 2006 MCSCa w/lotsa mods and Union Jacks
Ten-time Dragon Veteran - Occasional Trackrat - Extreme Twisty Addict - Rhymers Ferry Road Fanatic
Alright guys. Some good and bad news... The good news, I got another detailing job, convertable. Bad news... I got another detailing job, convertable, this weekend. I want to clean the top well, but don't have time to order from DP. What should I do??? I will just use water I guess, and it's only a weekend driver, so I don't think it will be too bad, but what else can I do to clean it up a bit??? Anything on the local shelves that will help (no detailing stores around here, just Autozones, Walmarts, and Targets...
I haven't used raggtop - so I'm not going to be much help there. With 303, you apply, let it sit in the sun for about an hour, then reapply, then another hour and your're done. But you want to mask off EVERYTHING except the fabric top, cause overspray on the paint sux - I use old bedsheets and actually open the top partially, put the sheet between the top and the windows and windshield, then close everything up. Then mask/cover around the back...
