MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > MINIs in General > Detailing 101
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Hello - Great site!
3 Replies, 35 Views
Advertisement
Thread Tools Search this Thread
Old 03-30-2007, 05:58 PM
Funk_Flex's Avatar
Funk_Flex Funk_Flex is offline
Send a message via AIM to Funk_Flex
Gallery
Wet sanding and polishing
My car recently got a stone chip on the leading edge of the roof. I applied some touch up paint with a toothpick. Then when it dried, I smoothed out the blob with a small piece of 2,000 grit sandpaper on a tip of a pencil eraser. I made sure the area was always wet with water.
I hand polished it out with some 3M compound made for 1,500 grit or finer but I still see some swirls. I cleaned up the area and tried Meguire's Scratch X and Griot's hand polish but it made little or no difference.
Did I miss a step or should try something else.
Old 03-30-2007, 08:41 PM
kenchan's Avatar
kenchan kenchan is offline
Gallery
1500 grit is pretty coarse. you need to keep at it with the
ScratchX on a cotton pad.
Old 03-30-2007, 08:54 PM
jjtricket's Avatar
jjtricket jjtricket is offline
Gallery
After wet sanding, 3M compounding, then 3M polish or swirl remover.
Old 03-31-2007, 12:41 AM
OctaneGuy's Avatar
OctaneGuy OctaneGuy is offline
Send a message via AIM to OctaneGuy Send a message via Yahoo to OctaneGuy Send a message via Skype™ to OctaneGuy
Gallery
Garage
When wetsanding, you should always soak your papers in car wash solution overnight. Then when you're working, you should be constantly flooding the surface with this soap/water solution. Depending on what I'm doing, I'll start with 2500 grit and I know I can remove the sanding marks with a rotary buffer, foam cutting pad, and Meguiars M84 compound without much effort.
ScratchX is extremely fine. You probably need something a bit more aggressive. On the Meguiar's aggressiveness scale--ScratchX is very similar to M82 or Swirl Remover 2.0 which I believe is around a 2 or 3. M84 is around a 10. You can see that to remove even 2500 grit sanding marks that you still need to get fairly aggressive.
As I've always said here on this forum, wet sanding isn't for the inexperienced. If you risk trying it on your paint without practicing on a non essential test panel, any mistakes you make could be costly.
Are you seeing swirls in the touched up area or in the paint surrounding the touchup?
Richard
5548 E. La Palma Ave., Anaheim, CA 92807 866 707 9292
Looking for Prima?? Buy Prima at ShowCarSupplies.com
11% off everyday discount code: MINI11NAM
2010 Midnight Black MCCSa
Old 03-31-2007, 06:27 AM
kenchan's Avatar
Gallery
thus take scratchx and take your time...
if he really knew wat he was doing or had experience, he wouldnt be asking here.
Old 03-31-2007, 05:26 PM
thulchatt's Avatar
thulchatt thulchatt is offline
Gallery
First, if OctaneGuy gives advice listen. (see above)
Second, when wet sanding start with lower number and work higher. I start with 1000 or 1500 and move to 2000 and if needed 2500. I started doing wet sanding well before seeing OG posts so I stay with what I know. I use 3M fine cut rubbing compound to get the haze from sanding out. I do this by hand so that I don't get agressive (it also makes me sand less the next time).
Third, maybe it should be first, don't start wet sanding on a car you care much about. Always learn on a car you can live with mistakes on. You will make mistakes.
Now that you have started just take your time. I can do more, but can't undo.
[SIGPIC][/SIGPIC]
Old 03-31-2007, 06:01 PM
kenchan's Avatar
Gallery
Quote:
alright you brainwashed ______ <= you fill in.
Old 04-01-2007, 10:29 AM
Funk_Flex's Avatar
Gallery
The swirls are mostly around the touched up area. The funny thing is, I did the same thing on the bonnet but I see no swirl marks. It's even funnier b/c I have the clear bra and the chip was right above bra . I'm wondering if white shows swirls marks better. My car is Hyper Blue BTW.
Old 04-01-2007, 02:46 PM
thulchatt's Avatar
Gallery
Quote:
Could be.
However, everything from Richard that I have done has turned out great.
By the way, how long does it take to wash two brain cells?
[SIGPIC][/SIGPIC]
Old 04-01-2007, 02:48 PM
kenchan's Avatar
Gallery
Old 04-02-2007, 10:55 AM
WannaMini_ WannaMini_ is offline
Gallery
I really like this product - it works great!
www.langka.com
HOME!!!
'10 CR/B MCS "Snape", black 16" bridge spokes, SS, DTC, Xenons, racing stripes
and nothing else!
'04 IB/W MCS "Dobby" - sold :(
Old 04-02-2007, 11:52 AM
kenchan's Avatar
Gallery
ScratchX or the tooth pick?
Old 04-02-2007, 12:05 PM
OctaneGuy's Avatar
Gallery
Garage
I've never been happy with Langka and I really dislike their marketing. They have a video of a young girl applying touchup paint and saying something to the effect, it's so easy even a young girl can do it. Yet, then she disappears and an adult is then shown removing the blob with Langka. The point being that you don't need skills to apply touch up when you have Langka, you just need skills when removing it!
I consider Langka akin to wet sanding with molassas. It's sticky, extremely smelly, requires skill, yet works like nothing else. I like to use it for removing touchup and smears during a bad application. But I've rarely been successful at ending up with the kind of repair I desire.
Don't get me wrong, Langka has allowed me to do some fantastic touchups--I repaired an M3 scratch that ended up looking like a faint paint drip, the repair was almost imperceptible, but that was under extreme stress and many many hours of work to get it right. The stress was because I unintentionally caused the damage, and if I didn't repair it, I was going to have to spring for a repaint, and that was going to cost an arm and a leg-so Langka HAD to work. lol.
In order to get this kind of repair, it was done using Langa and I still wetsanded and polished to remove some fine scratches instilled by the fabric I used to smooth down the paint.
Maybe I just need more practice.
Quote:
www.langka.com
Old 04-02-2007, 12:17 PM
kenchan's Avatar
Gallery
^^ i think you just need more rest.
Old 04-02-2007, 12:21 PM
OctaneGuy's Avatar
Gallery
Garage
That too.
I attended a detailing conference this weekend. At the last minute they also hired me to videotape it---originally I thought I'd go there for just a little bit as an attendee, but if I'm videotaping, I'd have to stay the whole event, plus not be late getting there, . Ended up shooting for 10 hours with 4 hours of sleep the night before--packing and getting ready. The conference was over an hour away in each direction...needless to say, sleep sounds really good right now...
All this was coming off of two 16+ hour details earlier in the week. LOL
Old 04-02-2007, 12:27 PM
kenchan's Avatar
Gallery
That too.
you now wat, my energy pours out when im detailing...probably at the
6th hour mark im pretty much drained. dont know how the hell you do
16+ hr jobs. you are either super fit or you're letting your son do all
the dirty work while you sit back and sip on some drink. i think it's
the latter!!
Old 04-02-2007, 05:12 PM
MiniMaybee MiniMaybee is offline
Former President MINI5280
Gallery
I've used Langka with great success. It fills in the entire chip so it is smooth to the touch. I think the trick is to 1. not let the touch-up paint dry too much (2 hours max) and 2. let the chemical do most of the work. I fill the chip with the paint, come back in 2 hours and then dab some of the chemical on and let it soak for 1 or 2 minutes. Then with a plastic card wrapped with an old t-shirt I just smooth out the paint blob until it is slightly under flush. Then on with the clearcoat, let dry for 2 hours and repeat. This time I make sure the clearcoat is flush when I stop smoothing. Then polish and wax as needed.
OG's right though - smells of rotted rabbit, and it can make you a little woozy if you do not vent properly.
Old 04-02-2007, 05:15 PM
kenchan's Avatar
Gallery
hummm... so if you had like 20 chips, you will be 'well done' buy like the
3rd one. :impatient
Old 04-02-2007, 05:21 PM
Gallery
I do not endorse the use of Langka as a recreational drug.
Old 04-02-2007, 05:26 PM
kenchan's Avatar
Gallery
Quote:
as I do not endorse Hydro as a drink.
Old 04-03-2007, 07:05 AM
S Curvz's Avatar
S Curvz S Curvz is offline
Send a message via AIM to S Curvz
Gallery
... or you're letting your son do all
the latter!!
So thats how the G and MINI got done...ken i am starting to understand your ways. You switch to Hydro becauase even a child could do it.
03 MSC BRG/W
97 Jeep Wrangler. Sold
Old 04-04-2007, 06:54 AM
kenchan's Avatar
Gallery
Quote:
hey now, i don't make my 2yr old hydro my commuters while im working on
my hobby cars. although i know in his face he wants to 'help'
dad.
Old 04-04-2007, 06:55 AM
kenchan's Avatar
Gallery
we're back to freezing temps... hope no one ordered any supplies.
Old 04-04-2007, 07:47 AM
S Curvz's Avatar
Gallery
dad.
Still not convined...
03 MSC BRG/W
Old 04-04-2007, 11:34 AM
kenchan's Avatar
Gallery
i think octaneguy's son's picture is baked into your brain.
(the one where his son is claybarring a MINI). lol!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
