MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > MINIs in General > Detailing 101
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Swift vs H Sport
by putttn
0 Replies, 13 Views
Advertisement
Thread Tools Search this Thread
Old 03-28-2007, 07:58 PM
rwkeating rwkeating is offline
Gallery
Washing the underneath part of you car?
Now that winter is over, I'd like to wash the salt and junk off from underneath of my MCS I was thinking of going to the local self wash place and spraying the bottom with their foam soap and rinsing it off. They have this broom looking thing (can't imagine who would use that on their finish) and I thought of using that on the bottom of the car after applying the foam soap.
What do you recommend? I like the "broom thing" idea, but I don't want to snag anything under the car and rip it off (brake lines, fuel lines, wires ...) I don't know what's under there that could get snagged.
Old 03-28-2007, 08:20 PM
mcdbrendan's Avatar
mcdbrendan mcdbrendan is offline
Gallery
I would think that the brush would be ok underneath the car, just be really careful, and try not to scrub at the joints or anything that has a lubricant or seal, as it could rupture the seal.
Old 03-28-2007, 08:53 PM
Morris9982 Morris9982 is offline
Gallery
Salt readily dissolves with water. If you want to just do an easy job, use the hose in your driveway (if you have one) or use the spray in the car wash. I'm not sure I'd attempt to use the brush as there are too many things it could affect.
Old 03-28-2007, 09:19 PM
BRGPA BRGPA is offline
Gallery
I've actually used an oscillating lawn sprinkler under mine- heard about doing that years ago. I set it at a fairly low pressure and let it work back and forth for a while, then move it to another section. It rinses very well and gets the job done.
Old 03-29-2007, 05:16 AM
mcdbrendan's Avatar
Gallery
I too have used sprinklers on my Jeep after mudding. That is a great way to get it done.
Old 03-29-2007, 06:47 AM
S Curvz's Avatar
S Curvz S Curvz is offline
Send a message via AIM to S Curvz
Gallery
Quote:
Get R done.
I too have used this on my Jeep...But never thoguth about doing it with the mini. Hum....
03 MSC BRG/W
97 Jeep Wrangler. Sold
Old 03-29-2007, 06:55 AM
Loony2N Loony2N is offline
Gallery
Sprinkler sounds like a good idea. But, about the brush... come on, the MINI isn't a delicate vase or anything. Anything underneath had better be secure. If you are going to use a brush, it should be fine, as long as you aren't scraping away like you are trying to remove tar.
<a href=http://www.northamericanmotoring.com/gallery/data/500/thumbs/P73001161.JPG target=_blank><a href=http://www.northamericanmotoring.com/gallery/data/500/thumbs/P73001161.JPG</a> target=_blank>http://www.northamericanmotoring.com...001161.JPG</a></a>BlooMeeni - 2004 Mini Copper, Auto A/C, HK Stereo, Leather, 5sp.
Old 03-29-2007, 07:02 AM
mcdbrendan's Avatar
Gallery
Quote:
Originally Posted by S Curvz View Post
Get R done.
Haha. No I am not a redneck, but God didn't grace Ohio with rocks (that's why I climb on plastic ones) so some fun off camber stuff and getting stuck int he mud is about all I can do.
Old 03-29-2007, 08:06 AM
S Curvz's Avatar
Gallery
I understand. SW ohio has some nice areas to go play.
03 MSC BRG/W
Old 03-29-2007, 06:12 PM
erickvonzipper's Avatar
erickvonzipper erickvonzipper is offline
Send a message via AIM to erickvonzipper
Gallery
I jacked the car up, and sprayed the underside with my Mr. Clean soap gun, and then hosed it off. Whatever water sprayer you use, don't use the jet setting.
Zip
<a href=http://www.northamericanmotoring.com/forums/signaturepics/sigpic16898_13.gif target=_blank>http://www.northamericanmotoring.com...ic16898_13.gif</a>
www.usminiclub.com Obie: my '05 MINI Cooper - Jet Black, Premium and Sport packages, chrome side vents with white/clear repeaters, M7 STPs, K&N 57i intake, Megan Racing MINI Cooper cat-back exhaust, TSW engine damper, Alta 19mm anti-sway bar, Ian Cull anti-nanny circuit.
Old 03-29-2007, 07:26 PM
kenchan's Avatar
kenchan kenchan is offline
Gallery
i just take a water hose at full blast and just wash with normal water
pressure. i dont really wash the actual carriage. i wash the suspension
parts, fender arches (on my commuters, that is), parts of the frame
exposed to the wheels, etc.
Old 03-29-2007, 09:17 PM
Tmitty Tmitty is offline
Gallery
Great ideas. I've used the sprinkler idea for many years...it works. Another idea is to put your car on jack stands rotate the tires and wash the wheel wells and the backs of the wheels at the same time.
Old 03-30-2007, 08:35 AM
Greatbear's Avatar
Greatbear Greatbear is offline
Moderator :: Performance Mods
Send a message via Yahoo to Greatbear
Gallery
I use a 'water broom' attached to a pressure washer at lowered pressure to clean the undercarriage of cars. A water broom is essentially a bar with several fan-spray nozzles that rides on wheels and is meant for cleaning floors and decks. Modifying it a bit to invert the wheels and change the angle results in a nice, low 'scrubber' that does a surprising job of clearing out crud from under cars.
http://home.comcast.net/~greatbear/gbnamsig4.jpg
JCW Intake|15% Alta|Milltek Catback|17x7.5 SSR Comps|215/45-17 GS-D3s|Much More
MMC #28|Motoring ID RAGE666
Old 03-30-2007, 08:37 AM
S Curvz's Avatar
Gallery
That is a cool idea.
03 MSC BRG/W
Old 03-30-2007, 10:04 AM
mitchman's Avatar
mitchman mitchman is offline
Gallery
I just wanted to point out the nomally the actual "underside" of the car doesn't get that dirty. It's the wheel wells and suspension parts that get it the worst.
I jack up the car and remove the wheels (you can just do one side at a time). Then clean everything up with a bucket of soapy water and a sponge or brush (or both). The underside of the shock mounts get especialy dirty. If you want to make it real nice you can spray the black plastic wheel wells with foaming tire cleaner/protectant when you're done. It's quick and easy, but it doens't last that long.
Don't forget to clean the plastic area between the wheels (where the plastic jack points are). The front tires throw junk straight back and fill this area with mud and crap.
I have Leda shocks with the adjusters exposed to the elements, so I really try to keep this area clean.
_____________________________
2006 MCS HB/W Setup for G-Stock autocross Sand & Sage Sports Car Club
Leda double adjustable shocks with remote reservoirs, SSR wheels, 22.5mm front bar
Old 03-30-2007, 10:33 AM
Greatbear's Avatar
Gallery
You think the underside of the car gets dirty, you should pull the piece of trim below the rear window off and have a peek inside.
This also goes for the areas under the wheel arches and rocker panel trim.
Old 11-22-2007, 06:29 PM
ofioliti's Avatar
ofioliti ofioliti is online now
Gallery
Greatbear, which piece of trim is that? The one that houses the license plate light?
http://i94.photobucket.com/albums/l116/ofioliti/NAM%20sig/Presentation1.jpg
'04 MCS "Blue Meanie" / WMW 15% pulley / one-ball exhaust / DDM intake / H-Sport 19 mm anti-sway bar / JCW plugs / Kingsborne wires / magnetic drain plugs / Speedy wheels / Hawk pads + ATI rotors / Craven ST defenders / Whalen shift knob / Scan Gauge II / Gominigo 3rd brake light / Powerflex LCA bushings / WMW street tune / TSW jack points / Ian Cull v. 7 auto-up switch
Old 11-22-2007, 08:31 PM
MLPearson79's Avatar
MLPearson79 MLPearson79 is offline
Moderator
Gallery
Garage
I think he means the beltline between the glass and the paint. It pops off and it's way gross under there.
Old 11-22-2007, 09:10 PM
ofioliti's Avatar
Gallery
Quote:
Oh my; gotta check that out. Thanks!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
