MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > MINIs in General > Detailing 101
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post Hello to eveyone from...
3 Replies, 86 Views
Go to first new post My lifted mini is done!
by Moby911
37 Replies, 749 Views
Go to first new post 09 JCW Clubbie
4 Replies, 107 Views
Advertisement
Thread Tools Search this Thread
Old 01-21-2007, 05:21 PM
AeroJammin's Avatar
AeroJammin AeroJammin is offline
Gallery
Has anyone else recently used the Dark Silver Touch Up Paint?
So after accumulating a few rock chips, I finally decided to use the Dark Silver touch up paint I bought in November. Upon first filling in the chips I noticed that the touch up was a quite a bit darker than the DS from the factory. I figured that this was just the way it looked wet and waited for the stuff to dry before applying the clear coat. When I checked on it I found that the color of the touch up was still dark and now dry. I didn't apply the clear coat because I am afraid that it will prevent me from fixing the color mismatch.
My questions are...has anyone else used the DS touch up paint? If so, was adding the clear coat necessary to lighten the DS paint? Did I get mislabelled paint? What do I do now?
I'll try to get some pics tomorrow and maybe then I'll be able to see if the touch up is DS, BRG, or Astro Black
Thanks in advance for any help
Oh yeah I am using the OEM touch up paint and clear coat.
<~Confused Aero
Late Build 2006 Dark Silver / Black MCSc --Pure Stock
Old 01-21-2007, 05:41 PM
mcdbrendan's Avatar
mcdbrendan mcdbrendan is offline
Gallery
This is common, so no need to worry about a mistake. The touch up paint is darker probably due t some sun-fade of the original paint.
Old 01-21-2007, 05:49 PM
AliceCooperWA AliceCooperWA is offline
Gallery
I have the opposite problem. My LY MC had the bonnet repainted at some point before I became the owner. The bonnet is a small amount darker than the rest of the car (not noticeable unless looking for it). When I went to fill in the chips, the touch up paint was lighter than the hood. That was when I noticed that the touch up paint matched the rest of the car, but not the bonnet.
Old 01-21-2007, 08:00 PM
kenchan's Avatar
kenchan kenchan is offline
Gallery
metallics are hard to match because the flakes need to be positioned the
same way to get the same color... usually it is not possible with touch up
paint. you can, however, get the best out of the touch up if you put
a dab in a plastic cup (yogurt cup), then use a toothpick with the tip tapped
flat, and pick and choose the part of that dab with the closest color match
to your paint. you can play with the metallics on the car for 10-12seconds
before the paint starts to get too thick. it's really trial and error.
if error, just wipe off with a cloth and try again. the thin excess that
dries around your touchup from you wiping it will come off when you
use some ScratchX or any fine polish at the end.
if you add clear it will not change the color. it will just make it glossy.
i tend to just mix 50/50 of the gloss into the touchup and do a one-time
app.
Old 01-22-2007, 12:31 AM
Cactusflier's Avatar
Cactusflier Cactusflier is offline
Gallery
I have used it on a two month old car. No sun fading. It does go on darker then it should. Clear coat does not help. I have found the the paint seems to separate it's colors almost immediately on the supplied brush. I instead used the corner of a paper towel rolled or twisted to a point and dabbed a bit of paint on it and transferred it to a small chip and gotten a perfect color match that way. For small chips, this method is working for me.
2006 MCSa Dark Silver, Silver roof and mirrors.
15% Alta Pulley, Milltek Catback, JCW CAI w/K&N Filter, JCW Strut Tower Bar, H&R 19mm Rear Swaybar, KW V1 Coilovers, 17" Konig Feathers, Aero Sideskirts, DICE ipod interface.
Old 01-22-2007, 06:12 AM
AntiqueCarNut's Avatar
AntiqueCarNut AntiqueCarNut is offline
Gallery
Interesting - the DS touch-up paint I have is much lighter than the paint on the car.
For my Honda Gold Wing motorcycle (Candy Orange metallic) I have touch-up paint pens from Color-rite. There's a metallic base coat, a color translucent top coat and then a clear coat. This matches much better than the dealer touch-up paint. This may be a good option for the MINI.
Another choice to consider is paint from www.paintscratch.com.
'06 MCS DS/S 6-sp LSD/Pkg1+2+3/HK audio/Blitzsafe+XM+iPod/Mikey's BT kit/Arc Armrest/Whalen SM/Redline leather boots/RSpeed RSB/JCW Suspension/M7 STB+OCC/DDM HDI/15% Pulley/Kngsbrne Wires/V-1 Radar/Ian's Auto-up+Fog
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
