My bathtub area is getting a little funky, so i'm trying to figure out if there's an easy way to clean it. I figured if I have all this detailing supplies why not use them for the house anyways, I need some help figuring out what products to use.
I was thinking of using my porter cable dual action with Klasse all-in-one. Since it's a very good cleaner that leaves a little protective coating, I figured it would work well. I mainly want to use it for the tiles and the sides of the tub, definitely not bottom since I don't want to crack my head.
with this said, are there good waxes/sealants that would be able to stand up to the shampoo and soap used in the shower? Also, does Klasse sound like a good choice or should I go with something cheaper and easier to come by, some meguiars cleaner? Specifics needed as I don't use meguairs besides waxes. I also have some poorboy's that i'm trying to use up so I can switch to a different polish/swirl remover, so i could also use that. Any input is appreciated.
Mine:
LaB/B MCS, leatherette, anthracite liner, LSD, Xenon, MFSW, rear fog, 6 speed, Piano Black, S-Winders with all season tires, white indicators + osram bulbs, V1
Well first of all you don't need/want to use a wax in your shower. The wax will make it slick. You fall down. Go boom. And you don't need a sealant. It's a shower, not a show car or granite countertop.
You go to a grocery store and go to the cleaning section. You buy some tub cleaning gel, dampen the shower and then apply elbow grease with a clean cloth/rag. Sure you'd love to be able to use your detailing chemicals to clean your shower, but it isn't necessary.
If you keep up with cleaning your shower it won't be much of a chore next time.
Here I have some real expertise. Weekly cleaning is the key. If you have a fiberglass tub and surround or even tile I highly recommend Comet Bathroom Cleaner (not the powdered cleanser). I spray it on let it sit a bit, scrub with a microfiber cloth or no scratch sponge and rinse. Repeat as needed to remove scum and hard water stains. You'll need some ventilation if you need several applications. Also it would be good to wear some gloves. The cleaner leaves your shower clean and shiny!
Living my dream....to own a MINI! MMC#402
i get to do shower rooms and tubs myself... i use those off-the-shelf
cleaners for breaking down calcium, also some cleaners with bleach, and
finally some disinfectant in some areas.
i can recommend Rainx on shower doors. does keep it clean for a
few weeks.
otherwise, the best way to keep showering areas clean is to not get it
dirty in the first place... just wash minimum once every other week.
Tub stripes: traditional, offset, or "viper style".
Discuss....
~Matt Cook | Dublin, Ohio | '92 Classic Mini Sprite: "Fiona" + Purple Haze 2005 MCS Cabrio: "Dawn". See old MODs from "Nano" HERE - post #166 - many with How-to links!
well first of all of course, I would purchase the official 2 buckets on wheels with Grit Guard for only I think $120. Then the lambswool mitt for another $15 would be prudent. A proper claying would be good if the bath tub is ceramic, but if fiberglas, then clay might be damaging so a Dawn wash followed by the NXT car wash might work. But then you will need the waffle weave microfiber drying towel and a couple of regular microfiber cloths for detailing around the faucet regions.
Mr. Clean Magic Sponge (or generic equiv) will do wonders on the bathtub, without the need for cleaners.
Traditionally you need two cleaners and some elbow grease: a bleach-based mildew remover (tile cleaner), and another that does lime/hard water/soap scum. Rinse between using each cleaner as if they combine they form a oxygen-replacing gas that can suffocate you.
Once clean I try to use the daily after-shower sprayers. Which, if you can manage to do so after the last shower each morning, seem to keep it clean for a long time.
In all seriousness, we actually clay our sinks all the time! I can't say it works better than other, more dedicated bathroom/kitchen cleaners, but it's fun to clay! It almost makes cleaning the sinks feel like a hobby instead of a chore... almost.
As bad as it sounds, my mom is usually responsible for cleaning the bathtub. However, she's been quite busy and isn't too particular to doing the best job. I don't blame her though, she is a VERY busy lady.
anyways, I guess I don't see why I would have to put in all that elbow greases if I have a porter cable. Also, the smell of the car cleaning stuff is just so much better, so I'd be less of a chore if I didn't have to deal with harsh chemicals.
As for the sealant or something of that nature, I am interested since my mom usually does it, so if I could get something to last longer, she would have an easier time doing it when she does. Sure I could take the responsibility of cleaning it, but i'm kind of lazy and I have other chores I'm responsible for in the house.
background info:
ceramic tub
tiled walls
curtain, no shower door
Mine:
I know this thread's a little old, but I have to chime in since I actually have used AIO on my fiberglass shower surround. I don't think it protected it from hard water and soap scum, but it was a fun idea nevertheless.
By the way, put some white vinegar in a spray bottle, mist it onto soap-scummy walls, rub it with damp sponge and rinse. Does a great job, doesn't use chemicals and it's almost free.
A car is safe in a garage, but that is not what cars are for.
_____________________________ 2006 MCS HB/W Setup for G-Stock autocross Sand & Sage Sports Car Club Leda double adjustable shocks with remote reservoirs, SSR wheels, 22.5mm front bar
