dude, you guys get some wicked snow up there.....im in Ohio, and our winters are considered pretty "strong" but ours is just starting up.....this will be the third winter that my little guy hauls through
Now you gotta keep track and tell us the "lowest" the OBC tell you this winter. Ours finally had the little thing make a noise and blink since it go down to 22!
It hit -27C (-16.6F) one morning this week. And that was the day after the storm. The storm hit with temps that were at the freezing mark, so everything was covered in ice, before the snow started.
This will be Poco's 3rd winter. I have never had a better winter car
I pulled out of my driveway on the day of the storm, so my neighbor could blow the snow out. No problem, just me and the 4x4s out that day
Got lots of thumbs up from them as we blasted through some heavy wet drifts.
you are using pirelli snowcontrols right? How are you liking them after that one foot of snow? They are supposed to be shipped to my door soon
RallyMINI, the Pirelli's work great. I pulled out of my driveway, with snow up to the axles, no problem. Just turn off any traction control you have off, you do need to spin the wheels some. Took a few runs at the road, back up, go again, back up go again. But I was out motoring before the plows came through.
They perform VERY well on snow packed roads, lots of control, and braking is also very good.
Nothing short of studded tires works great on ice, but I feel under control on icy roads.
I commute 100 miles everyday on dry pavement, well unless it is snowing, and the Pirille's are great in temps below 40F. No road noise either
Happy I have mine. I'm sure you will be impressed with them
I put the Pirelli Snow Controls on last winter,.....they're great. So they were on one season. I will soon be putting them on again down here in Massachusetts....I'm not sure if I should put them on the same wheels as last winter, or if I should rotate them front to back...any sugestions?
(I know that for tire rotation of regular non-winter tires on the MINI there are two schools of thought...rotate frequently or no rotation at all) (I'm choosing the no rotation at all on my regular tires so when the fronts wear out, then I'll rotate and put the new ones on the rear...so I'm not sure if I should do the same for these Snow Controls)
All I can say is Burrrrrrrrrrrr....and dang, your car looks great! I'm afraid I wouldn't be THAT dedicated to having a clean car in your weather conditions. You do good work!!
Donna
__________________ Founding Members - DC METRO MINIs
02' CR/W MCS (gone to MINI heaven - burned up)
08' LB MCS Clubman - Mike's Daily Driver - Merlin
67' Morris Minor Traveller - Donna's Daily Driver - Roxy
I think there are two basic camps to mini tire rotation. Often/each season front to back, then replace the whole set when they are worn, or Leave them, when the fronts wear get two new tires for the back and move the backs to the front. So it's basically deciding if you want to stay with the same tires and buy two at a time, or buying tires 4 at a time which would be a better choice if you intend to switch to a different tire model.
I have been trying to get to the wand wash for a week, but it's been snowing like 1" to 2" a day, just enough to keep the streets from clearing and to make sure my car would get dirty between the wand wash and home. It warmed up to 22F today so I washed outside even though it was snowing, I just had to get that salt spray off. I had to move inside to dry though, as things kinda froze to the car. Really wishing I'd put a floor drain in when I built the shop...
same here... when the ground's wet you know u cant touch the wash because the moment you step back out there its gonna be dirty!
its been a week since i wash my car... and the back is becoming black again....
