MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > MINIs in General > Detailing 101
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post 09 JCW Clubbie
3 Replies, 107 Views
Go to first new post The Peerage of the Pepper...
by BoCRon
2,700 Replies, 238,680 Views
Go to first new post I'm New - I Scored!
12 Replies, 285 Views
Advertisement
Thread Tools Search this Thread
Old 05-28-2005, 08:55 PM
apexer apexer is offline
Gallery
New Zaino Z-2 Pro. Whats your evaluation?
I just finished re-applying Zaino for the first time this season. I had about 5 coats of Z-2 on from last winter so, thought I would start fresh. Frankly, the old stuff still looked great but, its a long weekend so thought "What the hell". First I washed with Z-7 (2 caps) and one cap of dawn. Then clay barred with Z-7 as lubricant. While I'm sure it did make some difference, it was almost a waste of time. When using the clay bar I didn't feel any drag as you do when the bar is doing its thing. Felt smooth when I started, and smooth when I was done.
Next, 2 coats of Z-5... worked great, same as when I last used it in the fall of 04. Now its time to mix the Z-2 Pro. Right away I noticed the Z-2 had an oily feel and was thicker than I remembered. Rather than using the cotton pad that came with the kit, I remembered BradB's post awhile back saying he liked the foam pads for applying zaino so, I was using the foam pad for the first time. The Z-2 went on easy but, with the old stuff, the trick was to use so little on the cotton pad that you had a hard time telling where you stopped. With the new Z-2Pro, it left a light film that was actually helpful in seeing where you had been. I tried to use less and less but, the foam pad did such a good job that you could still see that faint film. At first, I wasn't sure if this was do to using the foam pad or the new formulation of the Z-2 Pro.
Removal was as easy as ever. NO RESIDUE NO CHALKING and a deep wet look. I did two coats today. Think tomorrow I hit it with a quick Z-6 then another coat (or two) of Z-2 Pro.
Bottom line... I like the Z-2 Pro better than the old Z-2. Actually easier to apply, just as easy to remove and no residue
BTW: You'll not beable to rinse the bottle with only hot water anymore. The new Z-2 Pro doesn't seem to be water soluble. I had to use Dawn to clean out the bottle and foam applicator.
04 MCS,CR/W,Anthracite,P-BLeather,15% AltaPulley,+2%AltaCrank,MTH,AltaCAI,IK-22plugs,DT-TB,NologyWires,Alta Oil CC,Magnaflow,EBC Greens,Stoptech SS BrakeLines,Ate fluid,H-Sport Comp.Rear Bar,Kosie K-1 TS Wheels(17X7 in white)w/Star Spec Tires,Momo LeatherShiftKnob,Euro Shelf,Zaino. MMC#150 - CROC#48http://www.thompsonsmithdesign.com/w.../CROC-icon.JPG
Old 05-29-2005, 07:38 PM
minicoopermike minicoopermike is offline
Gallery
Much improved Z-2!
I just came in from de-Zainoing my MINI after applying a coat of Z-2 Pro late this afternoon followed up with some new Z-8 Grand Finale. I've used it a couple of times already and I really like it - TWO . In conjunction with ZFX, it works really well. Like you said no residue, it seems to cure much faster than the regular Z-2, and feels easier to remove .
09 Clubman JCW Horizon Blue/Silver/Hot Chocolate - Premium, Cold, Xenons, White Turns, Silver Dash, Black Doors, Chili Red Mirrors
06 Cooper S JCW Checkmate...SOLD
03 Cooper S JCW...SOLD
02 Cooper...SOLD
Old 05-29-2005, 08:12 PM
BradB's Avatar
BradB BradB is offline
Gallery
Quote:
Originally Posted by apexer
BTW: You'll not be able to rinse the bottle with only hot water anymore. The new Z-2 Pro doesn't seem to be water soluble. I had to use Dawn to clean out the bottle and foam applicator.
The new Z2 Pro now has a higher solvent content in it (although it's probably still the lowest in the industry) so what you noticed is correct.
The fastest way to wash out your bottles with a little denatured alcohol. Two shakes and they are sparkling clean!
Bloomquist Garage!
'04 PW Mini Cooper S....Gone but still here in spirit!
My Other Rides.
Old 05-29-2005, 11:35 PM
hugh hugh is offline
Gallery
I'm not clear on using ZFX with Z2 Pro.
Zaino recommends ZFX/Z2 for initial application, but can Z2 be used without ZFX for 2nd, 3rd, etc applications?
I Zaino'd for the first time on my new '05 blk/blk today. Looks great!
Washed with Dawn, did 2 apps of ZFX/Z5, one ZFX/Z2Pro/Z6. 2 hrs later, another ZFX/Z2 Pro/Z6. Don't mind paying $15 for a bottle of Z2, but ZFX @ $20 for that tiny vial could get pretty expensive !!!
Old 05-30-2005, 06:42 AM
Tarzan's Avatar
Tarzan Tarzan is offline
Gallery
Xfx
ZFX is a fast-curing agent. You can use any of the wax products (Z-5, Z-2, Z-2Pro) by themselves if you are applying just one coat, or waiting a day between each multiple coat.
If you add the ZFX, you only have to wait 30 minutes between coats, allowing you to layer many times in one afternoon.
Mixed ZFX must be used within 6 hours, and you should re-shake the bottle for a minute periodically.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
