MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > MINIs in General > Detailing 101
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post R56 Modified Intake
17 Replies, 801 Views
Go to first new post "Those Waiting for a 2012"...
by Vapok
1,975 Replies, 53,517 Views
Go to first new post OK we all own MINIs but...
by airmini
1,179 Replies, 58,610 Views
Advertisement
Thread Tools Search this Thread
Old 07-26-2004, 01:41 AM
Panganiban Panganiban is offline
Gallery
Noticed something after washing...
Hey guys...washed the Coop today and I noticed that after washing the rotors had the color of rust on them . Is this normal or something that I should be concerned about? I read somewhere on here that after washing the car, I should take it out for a spin and use the breaks so it doesn't rust. Did that and for the most part most of it of was gone, except for the edges of the rotor.
What do you guys think?
Old 07-26-2004, 01:59 AM
911Fan 911Fan is offline
Gallery
The rust colored substance you saw was rust. It's no big deal, all rotors do this (except the super expensive composite ones).
So don't worry about it. The next time you drive it and apply the brakes, the thin layer of rust will disappear.
Old 07-26-2004, 02:27 AM
minihune's Avatar
minihune minihune is offline
Moderating in Moderation
Gallery
This is very common with any rotor and certainly a normal thing especially after it rains. The rotors are made of steel and rust is supposed to happen.
Each rotor can be split up into three areas.
1) The flat disc that contacts the brake pads- this is where you probably noticed the rust and it can start happening right away-(a red or brown oxide coating on iron or steel caused by the action of oxygen and moisture).
2) The center hub section or hat- which on stock rotors is usually painted grey and not going to rust until the paint is worn off.
3) The edge of the disc which lies between the two outer and inner flat surfaces- this does rust but it is OK and there isn't much to be done although I have seen people paint it.
Rotors that have zinc or other plating will resist rust for a short time until the rotor heats up with heavy braking such as at the track and then rust will occur. With street driving usually the plating will hold up longer.
I have Zimmerman Cross drilled rotors and the hats always rust. I usually take off the wheels about 3 or 4 times a year and clean up everything with wheel cleaner sprays, liquid metal compound cleaner or if needed I use a little naval jelly on the rust and rinse it off. Usually it stays clean for a month.
Whenever the rust is on the disc itself if you just use the brakes the rust will wear off and that is fine. You can do that anytime, doesn't have to be right after washing your car.
http://www.northamericanmotoring.com/forums/sigtemp/SigLJ0z2K.jpg
#43 Street Modified (SM) Class SCCA Hawaii Region
2005-2009 Solo Run Off and Points Champion (Hawaii)(2nd 2006 Points)
2005-2008 Overall PAX: 8th 2006, 7th 2007, Tied 10th 2008.
2010-2011 Modified FWD RallyCross (Points Champion)
http://www.sccahawaii.org/pics2008/s.../img_38944.jpg
Old 07-26-2004, 05:49 AM
gokartride gokartride is offline
Gallery
No problem
As mentioned above, the rust is no problem. It's normal and it would mostly, if not completely, dissappear if you just drove around the block. Its nice when you can just breath I sigh of relief on things like this....
Old 07-26-2004, 07:17 AM
AlanB AlanB is offline
Gallery
Gee, I get that on my rotors too and we don't have rust here in the desert!
Old 07-26-2004, 10:23 AM
BradB's Avatar
BradB BradB is offline
Gallery
I paint the hubs and edges of the rotors with high heat paint. Since they are now coated they do not rust. The surface of the rotors, which are bare steel, will always rust when wet but instantly clean up again when scored up with the pads. The painted surfaces (hubs and calipers) are also much easier to maintain since dirt and brake dust to not stick to them as easily now.
This pic is of my new EBC rotor before it's first use. The galvanized coating was still fresh and unscored. Now they are shiny silver.
Bloomquist Garage!
'04 PW Mini Cooper S....Gone but still here in spirit!
My Other Rides.
Old 07-26-2004, 11:47 AM
Gallery
Thanks guys!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
