Rock Chips
Yep it works. Depending on what you want the finish to look like.
It's a solid product, covers the spot and blended well on my dark silver.
However, if your front looks like it was peppered by buckshot, you may want to paint the from end.
I think between the original owner and myself my front bumper and hood were painted like 3 times. Lol.
I'll pass on a tip a body shop man gave me years ago that some people might not know. When using touch up paint don't use the brush that usually comes with the paint but instead use a tooth pick (or something similar). With the tip put paint inside the chipped area but do not let the paint lap over onto good paint. Fill the indent only. After it has dried, do it again. After that has dried buff, polish and wax.
I use Langka also. You actually only need the Blob eliminator, which is available on Amazon for 1/2 the price of the full kit (the other bottles in the kit are isopropyl alcohol and sealant. Not worth another $20). I use it with factory touch up paint and I do NOT use the clear. If you use the clear, you will need to wet sand to level.
For me, the process is very time consuming, because I like to fill in the chips with layers, doing a layer each day until I'm satisfied with the outcome.
I use Langka too
and practice makes perfect .....
a couple of hints
NEVER apply the t/up paint with the bottle brush ... go to a craft store and get a VERY fine, decent quality paint brush. 00 or smaller. You'll have MUCH better control of the paint. AND get some thinner or 'spirits' .... many times the t/up paint is WAY too thick to apply carefully (esp factory stuff). Put a blob of paint with the bottle brush on a 'pallet' - a glass microscope slide is great but a piece of smooth plastic works too (steal a small makeup mirror from the Mrs) - then add a small drop of thinner to get a more workable product
IME the 'dealer' t/up is crud.. I've used these guys for many years with always a perfect color match and paint that flowed rather than the glop I described above . . .
http://www.automotivetouchup.com/index1.htm
(they also make 'paint pens' but I've never had good luck with these .... like a bottle brush they tend to over apply the paint .. and dry out too fast for me)
And I DO apply the clear .... just don't fill color up to the flush level ... leave room for the clear then use the LANGKA. But like I said it takes some practice. The base color is pretty 'soft' - hardness and gloss comes from the clear. ..... OR a trick is to MIX the base color and the clear in about equal amounts ... then thin .. apply ... and use LAN' per instructions
a couple of hints
Interior/Exterior Filler neck/gas cap insert piece, paint peeling for the 8th time now?!
Systemlord
09-19-2015 02:57 PM
