Just like the paint, except they only have a life of 3 years.
Well, maybe most.
The ones on my early 04 are about 41/2 years old and they look great. I does depend on how they are cared for and exposed to. Like most things, your mileage may vary.
Be careful running off and treating them like paint. It depends on what kind and who made them. If they are OEM and have black on them forget about polishing as it will come off. If they are white then you are good to go. Even the stripes that Mike sold with the black pins on a white back ground are prone to fading if you polish the black part. Tape the pins off.
Well, maybe most.
And may I add that if your car is going to spend a lot of time parked out in the sun, you should be diligent about keeping the car well-sealed with a good wax/sealant that has uv protection. Otherwise, when your stripes do have to come off for some reason you may have a distinct color difference between the striped part and the rest of the bonnet.
__________________ '04 MCS "Blue Meanie" / WMW 15% pulley / one-ball exhaust / DDM intake / H-Sport 19 mm anti-sway bar / JCW plugs / Kingsborne wires / magnetic drain plugs / Speedy wheels / Hawk pads + ATI rotors / Craven ST defenders / Whalen shift knob / Scan Gauge II / Gominigo 3rd brake light / Powerflex LCA bushings / WMW street tune / TSW jack points / Ian Cull v. 7 auto-up switch
May I add that it's good to tape the edges no matter what the color ? I can ? Thanks.
That's because if you use a buffer on them, the rotation of the pad against the edge of the vinyl can lift it up, even if not noticeable with the naked (or clothed) eye. Then, tiny particles can get in under there and then you start having issues.
yah, just treat it like paint. i Amigo'ed and Best of Show'ed mine the other day. looks great.
did you polish the bonnet stripe with pc 7424 or pc 7336 to apply amigo on? cuz i plan to polish mini this weekend and am not sure if i should amigo with pc on bonnet strip properly.
btw, it will be my first time polishing and buffing with pc.
Don't risk it... tape the edges.
oops, you already answer my question when i asked kenchan about amigo'ed it. so use blue tape. no problem.
