Just ordered the Zaino Triplets
All in one, clear seal and grand finale clear seal.
Should I "Dawn" the car before i put it on?
__________________ "Smudge"MCS/A BRG/B DSC B Roof & Stripes 17" Web-spokes Perf R Fog Lamps Chrome Line Int & Ext English Oak Chrome Mirror Caps #1,2,3JCW Drilled Rotors Chrome Bonnet Scoop Cooper S HD Radio Hi-Fi xenon lamps Concieved 05/05/07 Born 29/05/2007 Delivered 06/05/2007 "Follow your heart not your Credit Score" Motoring ID# MPH139
Yes, you should Dawn and clay if this is the first time you are applying wax/sealant. Check out the Zaino website for instructions. After Dawn and clay, you can apply your All In One.
I used the AIO the other day and was very happy with the results.
__________________ '04 MCS "Blue Meanie" / WMW 15% pulley / one-ball exhaust / DDM intake / H-Sport 19 mm anti-sway bar / JCW plugs / Kingsborne wires / magnetic drain plugs / Speedy wheels / Hawk pads + ATI rotors / Craven ST defenders / Whalen shift knob / Scan Gauge II / Gominigo 3rd brake light / Powerflex LCA bushings / WMW street tune / TSW jack points / Ian Cull v. 7 auto-up switch
^^^Yup what he said. Zaino does not recommend that you dawn wash every time you are going to wax though, just the first time, unless it has been a long time between waxing, but that you clay every time before waxing. I have used the triplets, and they work great, but as the directions say, use very little of the Clear Seal, or it won't dry for a long time. Like days, don't ask how I know this
I'm not going to clay, at least not this time, everything has to be done on the street, with no hose, but I will drive out to our local jet wash which is 15 miles away and dawn and power rinse.
But one day I will clay I promise
I'm not going to clay, at least not this time, everything has to be done on the street, with no hose...
Even a rookie like me has learned to clay and has seen (and felt) what an amazing difference it can make. You don't need a hose, just your clay and QD. For the time you're investing in a Dawn wash and a three step finish, claying shouldn't add that much more work. Think about what your MINI wants and deserves.
(OMG, I've only begun learning about this stuff and I'm becoming obsessive!)
Okay... So go wash the car with Dawn. Come home and QD it then CLAY, CLAY, and CLAY. You won't regret it. IMO, it's better to only do a couple of sections of the car but do everything correctly than try to do everything but only half as good. Can you C-L-A-Y?
2006 HB/W JCW (Jan Cooper Works)
West Coast MINI
sorry to confuse things more but I would opt for doing the claying step while at the DYI car wash or somewhere with a hose....if you drive home the 15miles to your house from the car wash and clay there there probably will be dirt and grit on your car which would get ground into it as you clay...claying should be done on a perfectly grit-free cleaned car
