245/40r19 Tires
245/40r19 Tires
Hi all. I recently purchased a 2013 Mini Countryman S All4 and am looking to upgrade the wheels. I have stock suspension. I am currently considering two options:
1. 245/40r19 tire on 19x8.5 +45 offset rim
2. 225/40r19 tire on 19x8.5 +45 offset rim
I'd prefer to go with option 1, but I have a suspicion that it will not fit with stock suspension. Has anyone here tried that combo? Did it fit?
If not, then can anyone confirm that option 2 will fit on stock suspension?
I've searched the forum a bit, but couldn't find definitive answers. Any guidance would be much appreciated.
Thanks in advance.
Thanks in advance.
If you have the OEM regular suspension, both sizes should fit with no problem.
I have the OEM sport suspension, which is lower than the OEM regular suspension. I used to run NM Eng RSe14 wheels (19x8.0 +45mm) with 245/40/19 Sumitomo HTRZIII tires, and the rear rubbed very slightly on large freeway dips.
I'm selling the RSe14 wheels, BTW. =)
Did u ever these?
Did you ever get these? Pics? Did u do the 45 offset?
Thanks in advance.
Thanks in advance.
