Giving away lifted R60 Countryman Wheels/Tires
Hello North American Motoring,
I just recently upgraded my wheel & tire setup on my lifted R60 and I am looking to give away my old wheels. The old set are Steel Rims (ProComp 5x120mm 16x8's) and 225/70r16 tires (29" Treadwright Puma Retread's) and I have a total of 5. These will only work with the 2" lift kit and a little modification.
The old wheels are in good shape, balanced and running straight. There are only small scratches to the wheels, and the tires are at about 20% or less. 1 tire is at 100% and the wheel is perfect, it was my spare and was never taken on the road, only left in the trunk in case of a flat.
I live near Richmond, VA and these are currently in storage. If you are interested, I can meet you nearby and we can work out arrangements so you can have the set.
I have loved these tires for the last year, but I really wanted to upgrade to an aluminum setup for the lighter weight and the better visuals.
Let me know if you're interested, here is a pic of the tires from when I went offroading in the snow last winter.
Thanks,
Thanks,
Honestly, i use a 1" spacer on the wheels with longer lug nuts to fit. I have pulled out the wheel well shroud, and I had to do some modifications to the inner wheel well metal to flatten it out as the tires were rubbing prior.
If you're just looking to keep a 26" tire and have the rims, I can't verify if this is possible, but it's a maybe. I would say you will still have to do some kind of modification necessary to fit this.
quickcoop
09-21-2018 03:40 PM
ultrahuck
03-25-2016 11:16 AM
Tires, Wheels & Brakes
03-17-2016 03:25 PM
