Pics: 19" Wheels on Countryman.
#203
Thanks! Those are indeed white Rocky Mounts! They're great trays, and I love that they come in colors to match/contrast. You can even buy just the tray part to change up the colors if you want. Way better than the Yakima ForkLift trays I had on my R56.
#204
I've got the blue Euro Pitchforks on mine...
#205
Here is a rare thing indeed, a picture of a Countryman with the Neuspeed RSE10's in Silver. I couldn't find any on the web when I was wheel shopping, so I took the plunge a bit blind. Really tough choice. The RSE14 has an awesome spoke pattern, but I wanted to silver to go with all my chrome trim, and something a bit different. These are a bit lighter than the 14's too. Brake upgrade soon, since they are so visible now.
NM RSE10 Silver 19" X 8.0" ET45
245/40 R19 Continental ExtremeContact DW
#206
#210
#211
#212
Those gun metal grey ones look so perfect on your car. I have a white/red roof JWCM with the 18's black/silver accents and love the look of your wheels...I going back and forth between the two colors as you did...
#215
So I am looking at getting a set up 19x8.5 rims and think it would be best with stock suspension to run 235x40x19 tires or maybe a 45? Will they both fit, I want to fill the fender well but not rub. These are the wheels I am looking at?https://www.tirerack.com/wheels/Whee...+Sport+Package
#216
Nice job, luv the stance on your PM..yeah, it's the nicest PM I've seen on NAM. Very clean and tight! Funny, I have a similar look on my CM, black and chrome...but I have 18 BBS LM replicas instead of 19s. Have you had any rubbing issues with the 19s? I recently lowered it via H&R springs and like the look of the extra negative camber. However, to save my winter tires I had it aligned and put back to spec.
#218
<CALayer: 0x17e3cdd0>
#220
The wheels on my countryman are 17x8.5 ET40. Tires are 235/50/17 (diameter is even larger than OEM specs). OEM sport suspension, which is a bit lower than the regular suspension. No rubbing whatsoever.
19x8 ET40 with 235/40/19 tires should fit nicely (diameter is only 0.1" larger than mine).
Tire design does have an impact on rubbing issues though.
EDIT: I just noticed that preme123 stated that he wanted to pair the wheels with some (presumably aftermarket) lowering springs as well. Depending on how low you go, there definitely is a chance that 19x8 ET40 with 235/40/19 tires would rub. So yeah, MarioKart likely would be correct in this instance.
#222
Color / Size
hey Rywan, those look incredible! i'm in the market for a countryman myself and am aching to get my hands on it and these wheels. what size and color are those? i've seen "pressed black" and "crystal mirror" something in those Waltz S7's and its just hard to tell from pictures...
#223
245/35/19 19x7.5 45et lowered 2" mQubed Motorsport, Manic Tuning Dealer
#224
Thanks in advance.
#225
Hey D510. I sent you a PM. Have some questions about your setup but didn't want to hijack the thread. Gimme a shout!
