Drivetrain Air Intake Modifications
#26
MAF is prior to the turbo. Well at least it is on my International diesel engine in my Ford Superduty.
K&N makes an aftermarket for that rig too however the OEM filters particles so minute that no other company can match it.
Guys who have added aftermarket air filters to their trucks stand a substantial chance of dusting their turbos.
I'd suggest an aftermarket exhaust system especially one where you can swap the kitty in and out with a test pipe if you want to hear the tubo.
The engine would breath better as well. Not sure if such an exhaust system is made for the CM though. Probably not.
When the kitty is removed from my diesel the turbo whistle sounds like an F-16 on the tarmac. Pretty kewl. I also get more power, less turbo lag and the engine roars like a lion. That's with a Banks 4" turbo back dual exhaust system.
Hobie
Hobie
#27
I'm all for people installing CAIs for sound, fun of it and looks. I was only commenting that replacing the air filter system may not have the desired hp benefit and oil filters have advantages and drawbacks.
My personal experience (sample size of me) would be to stick with dry filters... I've had both... simple and cheap to replace.
Note: a previous poster had the heat sheild/hp comment..
#28
I was just trying to see if any engine gurus had any negative experience with the KN oiled filters. I myself had a 300zx that the MAF was ruined due to oil buildup from a KN filter. Was hoping to pass the info along to those that weren't as savvy.
A test pipe or catalytic converter delete pipe would be a super cheap and easy mod depending on the location of the cat. My 2010 camaro ss(RIP) had 4 cats that were on a bended tube(similar to headers) so a fabricated pipe was a PITA to try and make.
#29
when I was looking into a similar set up for my Infiniti what I read was....
1. The K&N will let more air pass through (less resistance), but this also lets more and larger particles pass through.
2. the oil used to coat the K&N will be sucked into the system to some degree and may lead to problems.
Those 2 things led me to just say no and look for other ways to up hp, and get better sound and aesthetics.
#30
Finally able to start getting around to modifying my MINI, and decided to start with the air intake. Went with the stuff from VIP Custom Parts, and have to say it looks pretty good.
You can read about the install at my blog here.
Thanks again!
(I'm loving all the singing my CM does now, BTW )
#31
I just wanted to say thanks to threar for the write-up on his blog... I got my VIP CAI installed yesterday and the instructions they include with it are not terribly useful if you've never done such an install before and your post really helped fill in the gaps.
Thanks again!
Thanks again!
#32
1: What is that LOWER tube (mind you, I don't have my CSM yet) doing there? Is that the original air intake routing? Why leave it there if it's just a tube being bored, OR does it ram the air more effectively into the cone filter?
2: I think I just answered my own question, but....If you have air sucking into the filter in the engine bay, won't that suck in HOT air, unless you have a solid airbox there?
3: Where does the air come from, and has anyone done any mods to get cooler air inside the intake? (I've seen some intake tubes in wheelwells, sealed from the inside of the bay, and some just sucking up hot bay air)
4: Is the plate/box shown just a plate, I might want to make a carbon fiber one if I do this mod.
Thanks!
#33
Nice install. Now the questions
Thanks!
Thanks!
2: While I don't have a temp guage in there, I suspect you're getting a mixture of hot and cold air there. The idea is to increase the overall available air.
3: I was contemplating some mods for this as well, but haven't come up with anything yet. A proper CAI is likely to come in not too long (if not available already).
4: It is just a plate. So going CF would be good. Keep in mind that this plate gets extremely hot, so whatever option you go make sure it stays safe.
#34
I will be setting up a temp recording system one day and seeing what temps are what. Especially around the turbo. I know I can use material that has a service temp of 500f (I think 400f for aero primary structures) so a SIMPLE shape should be easy. Else I think the best CF prepreg I have is service rated to 375f. I'm sure the inside doesn't get THAT hot, since there are nylon and other lower grade plastics in the engine bay. Maybe I'll just put a hoodscoop above it, and block off the rest of the filter
#35
Installed the Air Intake from VIP today... Pretty straight and simple...nice product and nice swoooosh sounds. Can really hear the turbo now. Also bought and installed the the heat shield from VIP. That actually took a liitle more work/mods as the plastic cover with Mini logo isn't made to go on after the shield is installed. Didn't like the look without the cover, so just slimmed down the plastic and all looks good and fits great. Now only if I had the correct signal/parking lights to swap out for the ambers would of been a perfect day.
#38
I dont see a CAI as being much of a big deal here because any heat negated will be double-negated (posited?) by heat added back in off passing through the turbo. Your intercooler is the big factor here, I am installing 2 - 7" ducted fans tomorrow to see what effects (positive, or none?) they will provide on maintaining airflow and temp. When the outside temp is high 40s to low 50sF I see about a 3F measured rise from the ambient to intake temp, as seen by the ECU. When its in the 80s, I have seen as much as 19F without boost action, and upwards of 30F after a good 10 - 12PSI pull. My controls arrangement is ultimately going to be based on outside temp, the presence of boost (boost switch) and if I can figure it out, a 2 channel delta controller that will measure ambient vs intake and switch on over 10F delta. Right now I have the temp switch installed with a bulb in the intake tract and the press switch will be next. That could also be wired for alcohol injection, may do that project in the spring (financially mostly for the delay there).
The last relay will be a delay-off, that will keep the fans running for 5 min after the ignition deactivates, to purge the hot engine bay air out through the hood louvers I installed last month.
#39
#40
From what I have seen somewhere, there is not much of a temp difference when going faster than 20mph. I don't know the accuracy of this, but I have never really measured it. It would be a good thing to figure this out. I do agree that one needs to block the engine bay completely, but the air intake tube is right at the cone filter as well, providing cool air to that area. Will post when I can measure.
#47
the VIP intake is pretty expensive for how simple it is. imagine how much a sealed performance CAI would cost. i'm thinking well over $500.00. i like the bov sound!! i think a true CAI would make the motor as quiet as the stock intake. i may go VIP, but i'm holding out for as long as i can for any other options.
#49
I have one of these on my 2009 MCS hardtop and love it.
http://ddmworks.com/mini/cooper_s/r56/engine/ris.html
I've used it since MOTD 2011 and just took it off last weekend to get the car ready for trade when my '12 CMS comes in (hopefully a few weeks). The ram air box under the bonnet really cleans up the engine bay (imho) and the spooling sound from the bov is sweet!
#50
An idea for getting cold air into the CM filter is to use a filter like the Ractive one with the full heat shield. I had one on my old Mekur XR4TI. Had this filter to the MAF then a 4"-2" adapter to a hose going down behind the bumper.
Our CMS already has the cold air plumbed right in just need a nice aluminum 180 bend, hook one end to the cold air pipe and the other to the filter. Depending on the intake manifold clearance.
