Cooper (non S) Modifications specific to the MINI Cooper (R50).
Who here has blown their Midlands?
Old 01-22-2007, 04:20 PM
115hp's Avatar
115hp
115hp is offline
I believe that converting from the Midlands to the Getrag is too difficult/costly, although it can be done. The dealer will replace the Midlands with another Midlands, and it will be a reconditioned gearbox, since new ones are all gone. It is my understanding that these reconditioned transmissions are not uprated, they are not fixing them with improved parts, except maybe the seal.
Here's a link to a post from MiniMania UK:
http://www.mini2.com/forum/mini-coop...ox#post2785361
  #27
Old 01-24-2007, 04:11 PM
phillyunderworld's Avatar
phillyunderworld
phillyunderworld is offline
me!
  #28
Old 01-24-2007, 04:21 PM
dave's Avatar
dave
dave is offline
pug poo picker-upper
I know octane guy went through two (possibly 3) of the midlands transmissions.
  #29
Old 01-25-2007, 04:02 AM
AliceCooperWA's Avatar
AliceCooperWA
AliceCooperWA is offline
When we picked up our MC, it had bad sincros. The dealership replaced that along with a cracked windshield as part of the purchase deal. As far as I know, the car was always owned here in south florida. It had 45k miles when we got it. Now I'm at 93k and driving the hell out of it. I have no problems from 1 through 5, but I have major issues with reverse. Sometimes it wants to go in, sometimes it doesn't. A lot of times, I have to let the car move a little before I can get it in reverse.
I think it's the luck of the draw.
  #30
Old 01-25-2007, 02:57 PM
goin440's Avatar
goin440
goin440 is offline
Originally Posted by Ranzo
Turns out I lost drive on the differential wheel due to the outer rings seperating...
With your mods (plugs, wires, intake, throttle body, header, high flow cat, exhaust, and ecu) This suprises me.
If I recall though... you were tring to do burn outs or something... along the lines of high rpm dumps... practicing launches maybe. (I remember too much.... )
Sometimes it wants to go in, sometimes it doesn't. A lot of times, I have to let the car move a little before I can get it in...
Ditto... sometimes 1st is tricky or 1-2, but mostly the same as you with reverse. I believe this is a sycho issue though.
  #31
Old 01-26-2007, 11:32 AM
isellem's Avatar
isellem
isellem is offline
the issue with reverse is actually not an issue.
Coopers do not have synchros for reverse gear.
Try this next time you need to get to second gear.
(assuming you are in first gear)
come to a complete stop with the clutch in and the car in first.
Put the gear lever into neutral.
release clutch.
push clutch back in
select reverse.
voila.. this should eleviate your problem!
Hopefully this helps... and hopefully you arleady aren't doing this
  #32
Old 01-27-2007, 11:51 AM
AliceCooperWA
Well, at least that makes me worry less about an impending tranny failure. It may be something to do with my clutch though. I never had that happen before my release bearing melted and broke. Afterwards, with a new clutch, she just hasn't been the same. There's the reverse problem...and also once the clutch gets really hot (ie. stuck in stop and go rush hour traffic) it gets really stiff and feels a bit sticky like the pedal doesn't quite want to come back out. I think something got bent or something...doesn't make any sense to me.
  #33
Old 02-12-2007, 02:47 PM
txwerks's Avatar
txwerks
txwerks is offline
Welp, our "uprated" tranny for our Cooper arrived today from MINIMania UK... It's sitting in the garage, along with a lightweight UUC flywheel and SPEC Stage III clutch kit. We're planning on install the 1st weekend in March.
I can't tell you how much I'm looking forward to not holding the car in 2nd gear through fast sweepers at the autocross...
  #34
Old 02-12-2007, 02:54 PM
03Indigo's Avatar
03Indigo
03Indigo is offline
User Title's are Silly
nice!!!!! I have been keeping my eye on the MMUK option. I wish MM here in the US offered the same option, to reduce cost, etc. Between the trans, shipping, core charge, it would be a hard sell to the wife
I am hoping it will still be an option in a couple of years....that would be exactly what I would want, along with the upgraded clutch and flywheel.
  #35
Old 02-14-2007, 10:47 AM
Docwatson's Avatar
Docwatson
Docwatson is offline
Mine tossed a tranny two weeks ago. I bought an extended warranty on it (purchased used) and it is covering the costs. $4K for parts labor and fluids. Should be back on the road by this weekend. 84K miles and it worked fine one minute then the next it wouldn't move.
  #36
Old 02-14-2007, 04:20 PM
resmini's Avatar
resmini
resmini is offline
Just curious, do you live in a cold weather area?
  #37
Old 02-14-2007, 08:25 PM
txwerks's Avatar
txwerks
txwerks is offline
That'd be Texas for me and Docwatson... although it's pretty cold here right now!
  #38
Old 02-15-2007, 05:53 AM
Bajanmini's Avatar
Bajanmini
Bajanmini is offline
Ive been through one in the early stages and live in the caribbean record low temp is about 68 deg so i'd say you cant blame it on cold weather!!
  #39
Old 02-15-2007, 06:14 AM
Docwatson's Avatar
Docwatson
Agreed although typically its not cold here. Even at 20 degrees I'm sure it doesn't come close to what you guys have to deal with in some area's of the country. Although maybe we could blame it on extreme HEAT
  #40
Old 02-15-2007, 08:54 AM
resmini's Avatar
resmini
resmini is offline
Sounds like a place I'd like to be.
  #41
Old 03-02-2007, 01:39 PM
txwerks's Avatar
txwerks
txwerks is offline
The new tranny chronicles begins tomorrow... we're pulling out the old, busted Midlands and installing the new one.
I'll take craploads of pics and post a write-up!
(I feel like I've been spending ALL my time under cars lately - we just finished R&R work on the rearend of the e30 track/AX car last night. 2.5 days of thrashing to install rear trailing arm adjusters (incl welding), painting, installing new urethane bushings, new guibo, center support bearing, tranny output seal, etc.)
  #42
Old 03-02-2007, 06:42 PM
115hp's Avatar
115hp
115hp is offline
If you don't mind me asking, how much for an uprated tranny (and how much was the shipping)? I've tried to get info from MiniMania, but haven't had much luck. I'd like to buy the improved parts kit so that I'll have it on hand for the big day!
  #43
Old 03-02-2007, 07:07 PM
03Indigo's Avatar
03Indigo
03Indigo is offline
+1 on having a less expensive option for us here in the US. I wonder why MM here in the US does not offer the UK trans?
  #44
Old 03-02-2007, 07:54 PM
txwerks's Avatar
txwerks
txwerks is offline
Total ended up being about $2600 USD shipped, including export taxes and shipping, IIRC.
You can find rebuilt Midlands in the States for about the same - but, they use all original guts and seals...
  #45
Old 03-02-2007, 09:03 PM
115hp's Avatar
115hp
115hp is offline
I'd take an original Midlands only if it was free under warranty, otherwise I'd get an uprated box.
Do you get to keep your old one or do you have to ship it back?
  #46
Old 03-03-2007, 08:23 AM
txwerks's Avatar
txwerks
txwerks is offline
In this case, I am keeping the old one... I'm going to rebuild it myself with internals from MINI Mania UK at some point in the future and keep it as a spare!
And, if Quaife ever releases their LSD for the Cooper with their final drive, I'll put that in the backup unit...
  #47
Old 03-03-2007, 01:15 PM
goin440's Avatar
goin440
goin440 is offline
Who makes this one? @ MiniMania
  #48
Old 03-12-2007, 08:41 AM
redfusion's Avatar
redfusion
redfusion is offline
Did you get it replaced at MINI with the aftermarket warranty?
  #49
Old 10-31-2007, 11:49 AM
ncdave's Avatar
ncdave
ncdave is offline
I will probably be on my third Midlands unit which is a shame since I really do like the feel of the thing. The first went at 41K miles and was repalced under warranty. The second one is exhibiting all of the symptoms at 68K miles that the first one did: difficulty getting into gear (forget about reverse!) and I set to bring it in. I fully suspect that a third one will be installed, luckily under warranty as well since it has been udner two years since it was replaced. There's still a ways to go to equal the number of windscreens though.
  #50
Old 11-01-2007, 09:21 AM
R50 Paul's Avatar
R50 Paul
R50 Paul is offline
80K.....knock on wood......had the clutch replaced at 60k and the output shaft seal replaced.....mebbe mine was put together right???
Quick Reply: Who here has blown their Midlands?
