MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 1st Generation MINIs > Modifications > Cooper (non S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post My lifted mini is done!
by Moby911
38 Replies, 850 Views
Go to first new post NM Engineering torque arm...
103 Replies, 9,298 Views
Go to first new post Head Unit Upgrade
11 Replies, 1,714 Views
Advertisement
Thread Tools Search this Thread
Old 07-23-2009, 11:00 PM
Gzirra Gzirra is offline
Gallery
Power upgrade suggestions for a stock '05 Cabrio??
I'm looking to get some more power from my 05 Cooper Cabrio - I regularly drive from Phoenix to Flagstaff... The altitude climb leaves me wanting a little more oomph to make it up some of the bigger hills with some passing ability.
I'm your average shade-tree mechanic not afraid to get dirty, as long as standard tools are all that's required.
Any recommendations in the sub $1500 range to get the best HP bang for my buck that I can do myself? I'm open to do exhaust, computer chips, possibly even a turbo or supercharger, but those might be pushing the edge in both $$ and abilities.
Old 07-23-2009, 11:38 PM
Dr Obnxs's Avatar
Dr Obnxs Dr Obnxs is offline
Vendor
Gallery
Put on a head...
and get a tune. Probably an exhaust as well, but that will tank your budget...
There's not a lot to do with the stock Cooper motor....
Matt
FES Auto= Worlds Best Shiftlight-Ian Cull Auto-Up-Auto Sportplus - R52 Top Commander
but wait, there's more! InvisiLens - Bav Tech SW - High Current Relay Module-
'02 CR/W S, Bunch of fun mods... '08 NFR/S Clubbie, close to bone-stock...
Dr Obnxs' Musings: a blog about cars, energy, technology and more....
Old 07-24-2009, 12:49 AM
MrCooperS's Avatar
MrCooperS MrCooperS is offline
Marketplace Moderator
Gallery
Garage
Trade it in and use the 1500 towards a MINI Cooper S.
///MINI Cooper S
Old 07-24-2009, 01:36 AM
rjtrout2000 rjtrout2000 is offline
Gallery
I would do the intake/exhaust route. Then, with the extra $ I would get a rear sway bar! That would be a nice little package
Old 07-24-2009, 05:18 AM
jc8899311 jc8899311 is offline
Gallery
hmm ditch your runflat and get some nice set of summer tire
Old 07-24-2009, 08:19 AM
AutoXCooper.com's Avatar
AutoXCooper.com AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
Gallery
Matt
This will tank your budget and only make you want more power.
Quote:
good point here.
Quote:
While the aftermarket guys can show power gains on dyno with CAI and catbacks they are not so much so that you can really feel it in with your butt dyno.
An ECU tune on the stock motor will help get the power you have to the wheels better due to changes in power management.
A TSW Damper will also get what you have to the ground better.
If it's got the CVT you are very limited. If manual just keep the RPM's above 3500 when climbing or passing.
I drive a non-S and you can make it move but it takes some work.
Old 07-24-2009, 07:49 PM
MINIGURU@WAY MOTOR WORKS MINIGURU@WAY MOTOR WORKS is offline
Vendor
Gallery
Start with the our Way/DDM intake, For a Cooper it's big bang for the buck. You'll def. notice a difference. And for those that say you there isn't real improvement read the reviews here Every customer I've installed one on has been totally satisfied and actually felt the improvement.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old 07-25-2009, 10:48 AM
nickbmw nickbmw is offline
Gallery
In my opinion, the Midland gearing is killing the car, and since we are talking for a low power n/a engine, it is a major issue. The Getrag 5 speed of the facelift is much much better in terms of gearing, but lucks the feeling. 3rd gear shows 160kmh at the speedo, 100mph...!!!
Cosworth hybrid head-custom intake manifold-RMW 12:1 pistons-Kent cam-Piper decat header-Fidanza flywheel-Supersprint cat back-high flow injectors-KW MINI Challenge suspension-IE rear camber arms-BMP/Promini brace-Powerflex bushes everywhere-Alta 19mm rear sway bar-Goodridge brake lines-DBA Gold drilled/slotted front rotors-Hawk HPS pads-Sparco Sprint buckets-Sparco harnesses-R56 undertrays-R56 Challenge diffusers
Old 07-25-2009, 11:55 AM
rkw rkw is offline
Gallery
Quote:
I have an '06 Cooper cabrio and haven't had a problem with climbing as long as I shift down and rev up. Do you have manual or auto transmission? It will be tough maximizing the performance through the CVT automatic.
Of the drivetrain mods in my car, the one that made the biggest difference, by far, was a custom ECU tune. I also have intake and exhaust. I have an RMW tune but Mynes is in your area.
Old 07-25-2009, 12:32 PM
lotsie lotsie is offline
Gallery
Quote:
Mark
Old 07-25-2009, 06:56 PM
chadtoolio chadtoolio is offline
Gallery
Umm...even though I have one, how will a Engine dampner get you more power or "new found power" like your ad states?
Quote:
good point here.
Supercharger delete mod,Toolio's P/P head matched to OBX header, ARP head studs, Crower Camshaft, "S" throttle body and intake with Silicone tube, Milltek Catback, Engine Dampner, JCW Software,Eibach Springs and S-bars, IE Adj. Camber plates, Alta Rear CA, SS brake lines,Super Blue BF,Flik Wheels,M7 STB, Louvered hood for air intake
Old 07-25-2009, 09:04 PM
Gallery
Hi Chad, I don't understand the question. But I'll take a stab at it.
The TSW Damper reduces the movement of the motor under load and helps get more power to the trans and wheels that is lost in motor movement without the damper. It's not more HP, but my customers tell me it feels like they got more HP, when in fact they are just now using what they had better.
Old 07-26-2009, 05:21 AM
Gallery
I think it's a decent mod...it just doesn't do anything for more power for passing like the OP was after. $75-150
Neither does tires, but since it removes some of the rotational mass, it certainly can help with accelleration. So I agree with ditching the runflats and getting some more grippy treads. $320-600
Cold air intake: there is some very good research and even do it your self mods for those done by itamanuel and nickbmw. I have done my own, but it probably isn't DIY by definition and involves putting louvers in the hood(some for looks, some for function). You could look for used ones to canabalize and make a custom one to save costs. $50-250
You may check on the Crower camshafts that Khuevo is working on with Nitromini, I have one in mine and picked up a couple of HP(3-4) and torque, but my car is heavily modified so your results could differ and I believe that they have put a camshaft in another JustaCooper that you may ask him about.
$250
Not that it helps HP either, but a lighter flywheel will let the car increase the revs quicker so you could also increase speed quicker, again less rotating mass. $1000-$1200
Header, only a couple of HP in it self......I put mine on in combination with a ported and polished head, so my results will differ. This was my biggest gain by far in the HP department and IIRC it was about 10-12 hp, can't remember the torque. $1600 and up depending on what head you go with.
Turn off the AC man....Don't need no stinking AC $free
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
