MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > 2nd Generation MINIs > Modifications > Cooper (non S)
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post MINI's on TV!!!
133 Replies, 4,428 Views
Advertisement
Thread Tools Search this Thread
Old 04-04-2009, 09:49 PM
pw4's Avatar
pw4 pw4 is offline
Gallery
Actual measurements! Performance gain with CAI & ECU
I've just had my ECU tuned, now that it can be done on R56 Coopers. Previously I had taken performance measurements before-&-after fitting a CAI, so now I've added the ECU measurements:
http://www.northamericanmotoring.com...um_summary.pdf
Summary: 13% improvement at high revs, 7% a mid revs, 9% at low revs.
Still nowhere near Cooper S quick of course - but not Cooper S money either. (And MCS gets its acceleration from lower gearing as well as the turbo.)
Please take the info just as a guide - how it worked on one particular car - especially as mine is Euro spec (or similar), not USA spec.
What the numbers don't show is that the car feels very much stronger above about 5000rpm with the ECU (compared with just the CAI). It also feels quite a bit more lively and responsive in the 3000-4000rpm range. On the downside, torque steer is noticeable now.
Overall, I'm delighted with the change. As standard the car always felt a bit flat, and that's been fixed. There is an integrity now in the match of performance and handling which I'm happy with. In terms of fun factor, rather than outright performance, I think I might even prefer this balance to a MCS?! (But then I've always valued handling, steering and braking over power. )
Anyway, I hope it's helpful info.
FYI the CAI is K&N, ECU tuning is by PowerChip - and I've no affiliation with either, just a happy customer.
pw4
R56: K-Mac camber, JCW brakes, K&N CAI, Hella 1000s, sunroof, wood,...
R56 LCI: Alta rear bar & gauges; JCW brakes, gearknob & dash; LSD; 17" RJR wheels; sunroof; Lyle wraps; stripes; Hella 500 & FF500 lights,...
Chili Red Owners Club #642
Old 04-07-2009, 05:16 AM
SSr56 SSr56 is offline
Gallery
How's that ECU tune working out for you? I was thinking of getting it done myself, but i wonder if the dealership will be able to see it and void my warranty.
Old 04-07-2009, 08:06 AM
pw4's Avatar
pw4 pw4 is offline
Gallery
Quote:
I'm very pleased with it - with the CAI, good value for a worthwhile improvement IMO.
PowerChip claim it's not detectable. The ECU tune just changes tuning settings - just numbers in a software table on the standard ECU hardware. My car has been to the dealer once since it was done, and they ran their normal range of diagnostics, and no comment was made. Having said that, my dealer could be more flexible than some - I know there are some other modified MINIs which go there too, and my CAI and camber kits are pretty obvious and they've passed without comment. So I guess a legalistic dealer could have an issue, if they did detect it somehow. (But smarter dealers should realise that if they support mods, people are more likely to buy JCW gear from them - like I just did! )
The more likely issue is the dealer re-flashing the ECU (I had a car which went through at least 4 versions of ECU software in normal dealer upgrades!) and undoing the PowerChip settings, so you need to check what arrangements PowerChip can make to redo the ECU tune. I live in a city where they have an office, and I just have to drop in and they'll reapply it - takes 15 minutes or so via the diagnostic port.
I hope that all helps?
pw4
Old 04-07-2009, 08:42 AM
Gallery
Does the sport button still work as usual? Or do you not even need to use it with the tune
Old 04-07-2009, 09:03 AM
IzzyG IzzyG is offline
Gallery
So this is for a non-S R56? I'm wondering if it'll work on a R55 non-S as well.
Old 04-07-2009, 09:10 AM
Bigshot Bigshot is offline
Gallery
I don't believe it will work on US spec cars.
Old 04-07-2009, 05:21 PM
pw4's Avatar
pw4 pw4 is offline
Gallery
Quote:
Because the R55 non-S engine is the Series 1 engine, there have been plenty of places around for quite some time which can do the ECU tuning. I know PowerChip have done them, but there's nothing unique there. What is new is being able to do the R56 engine. (Ignore this - it's wrong. See later comment in this thread for correction.
Quote:
Accessing the mapping tables should still work - it's via the standard diagnostic port. I can believe the actual settings would be a bit different (which is why I emphasised Euro spec on my measurements). Best to check with the US offices of PowerChip, or others that I presume now can do the tuning.
Yes, it still works. It changes the steering (so no difference there) and the sharpness of throttle response. They tell me there are 3 engine mapping tables, one for standard, one for the Sport button and a third when you're in reverse gear (much less responsive, to make reversing easier). They adjust the first two.
For the record, I did all my timings with the Sport button off, thinking it would make no difference - because I was on full throttle up to and through the starting speed, throttle response wasn't a factor. But now that I think about it, I should see if they tweaked the tables differently. Thanks for prompting the idea.
pw4
Old 04-08-2009, 05:46 AM
OWG's Avatar
OWG OWG is offline
Gallery
R55 and R56 are the same vehicle from the b pillar forward. Same engine, same ECU.
MC Clubman|SS/SS/Black|Hot Chocolate Lounge Leather|English Oak|Convenience|Cold Weather|15" 5 Star Spooler|MFSW|NAV|PDC
Production Week 23 2008 - Delivery #33 Ordered 3/28, Born 6/11, Arrived FEDORA 6/26, At dealer 7/3, Delivered 7/12
Old 04-08-2009, 06:10 AM
pw4's Avatar
pw4 pw4 is offline
Gallery
Oops - sorry, my bad. I was getting my model designations mixed up. Yes, it will be the same on the R55. (And R57).
pw4
Old 10-09-2009, 05:59 PM
jproz jproz is offline
Gallery
Just want to revive this thread. Anyone else had fun with these guys?
I really love cars:http://www.flickr.com/photos/4376222...7622624393352/
Old 10-09-2009, 07:44 PM
Oxybluecoop's Avatar
Oxybluecoop Oxybluecoop is offline
Send a message via MSN to Oxybluecoop
Gallery
Old 10-09-2009, 07:47 PM
Gallery
Thanks for the URL but I wasn't looking for another company ... I was looking for others with the Powerchip tune.
Old 10-10-2009, 04:46 PM
drewstermalloy drewstermalloy is online now
Send a message via AIM to drewstermalloy
Gallery
I'm going to go with UPsolute after I get my headers and exhaust.
Chad, do you mind telling me how much you paid for the tune?
2009 JCW FOR SALE ***PRICE DROP***
http://www.northamericanmotoring.com...ory-jcw&cat=20
Old 10-10-2009, 05:58 PM
Gallery
The cost was $500.
Old 10-11-2009, 03:45 PM
lacning74 lacning74 is offline
Gallery
Quote:
Originally Posted by OXYBLUECOOP View Post
The cost was $500.
Pricing is a pleasant surprise, especialy since Powerchip is a grand. Very tempting. Thanks for the link.
R56 MCa, PS/PS, DSC, front/rear fogs, alarm, K&N drop-in filter, modified intake silencer, white sidemarkers, LED dome, 3rd brakelight pulser, Escort 9500ix, Laser Interceptor, JL TR-CXi front speakers, BASS600 sub, back-up camera/rear wiper delete, security/dashcam, carputer/touchscreen
Old 10-11-2009, 11:14 PM
Gallery
The cost was $500.
Wow! Not bad at all!!
Old 10-11-2009, 11:17 PM
Gallery
Noticed this in your Sig too:
Quote:
M7 Oil catch can-AC delete-Sprint Booster
As in air conditioning delete?
Old 10-11-2009, 11:44 PM
Gallery
I replaced the belt with a MINI First belt(without AC) from the UK. The compressor is there but not connected.
Old 10-12-2009, 06:12 PM
mubex mubex is offline
Gallery
Oxy ,
how much whp you gain with all modifications..?
at this moment you have more power than R53 Stock?
Old 10-13-2009, 01:07 AM
Gallery
Quote:
Originally Posted by mubex View Post
Oxy ,
I was at 148 crank hp(up from 128) on the last Dynapack. Now that's with an auto tranny and drivetrain loss is significant with my current wheels. Don't think I can squeeze any more out of this N12 engine with the dual VANOS. This November I'll be swapping it out with an MCS JCW Stage 1.
-Chad
Old 10-13-2009, 03:28 PM
Gallery
-Chad
Wow. I would love to have more kick on the highway.
Old 10-13-2009, 03:30 PM
Gallery
-Chad
Damnnnn. That's not bad at all. I remember a thread on here a few months ago talking about how nobody has gotten up to 140 with the MC yet.
Old 10-13-2009, 06:41 PM
Gallery
-Chad
148.... how much $$?
MC use the same trans of MCS?
Old 04-23-2011, 01:12 AM
clayvt's Avatar
clayvt clayvt is offline
Gallery
Little thread revive, has anybody else gotten the upsolute? How was installation? Would look at doing this with obx headers and the new VIP exhaust.
Old 04-30-2011, 07:11 PM
DOC4444 DOC4444 is offline
Gallery
Yes, any US R56 Justa owners running an Upsolute tune?
Please provide details.
DOC
2010 Cooper Hardtop TSW XBrace Hotchkiss 22mm Rear Bar NM Torque Arm Mount Insert Front Bilstein HDs IE Fixed Front Camber Plates (1.4 Deg Negative Camber front, 1.0 Deg Negative, rear) M-7 Front Strut Plates Yokohama ENVigors 195-55-16 (NON-runflats) ScanGauge II Sprint Booster
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
