Sign in using an external account
Welcome to North American Motoring !
Welcome to
North American Motoring ,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community,
at no cost , you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please
join our community today !
» Main Menu
» Latest Main Topics
03-14-2009, 04:47 AM
Gallery
Aftermarket intake manifold
Do you know if anyone makes a better intake manifold for the MC, and if so who?
03-14-2009, 08:34 AM
Gallery
How about something like this (I know I've seen better pictures, but can only
find this one right now).
Cristo .... and his trusty BRG/BRG MC
Bliksem MMC #186
03-14-2009, 08:54 AM
Gallery
That loks wicked but isn't it with individual throttle bodies? I was actually searching for something on the style of the OEM piece but better designed and possibly a bit larger to allow more air into the engine, without going to the ITBs.
03-14-2009, 09:02 AM
Gallery
Johnny's Auto Clinic
San Pedro, California
03-14-2009, 10:55 AM
Gallery
Thanks Johnny, that looks a bit more like what I'm searching for.
That car is an S though, would that intake manifold fit a Non-S Cooper?
03-14-2009, 11:24 AM
Gallery
It can be made with the plenum above or below the runners just give him a call...
03-14-2009, 11:29 AM
Gallery
i am thinking about porting and coating std item...
03-14-2009, 12:40 PM
Gallery
I think porting the standard item is not possible, because it is plastic.
Cosworth hybrid head-custom intake manifold-RMW 12:1 pistons-Kent cam-Piper decat header-Fidanza flywheel-Supersprint cat back-high flow injectors-KW MINI Challenge suspension-IE rear camber arms-BMP/Promini brace-Powerflex bushes everywhere-Alta 19mm rear sway bar-Goodridge brake lines-DBA Gold drilled/slotted front rotors-Hawk HPS pads-Sparco Sprint buckets-Sparco harnesses-R56 undertrays-R56 Challenge diffusers
03-14-2009, 01:39 PM
Gallery
Those long runners & plenum on the OEM intake are probably helping the low-mid range power. I could see short runners on a high revving N/A race engine.
Coating to reduce temps sounds interesting. Do the plastic runners get hot enough to effect the incoming air density?
04-04-2009, 02:51 AM
Gallery
2004 Mini Cooper: Sports Package, Yellow & Black
MODS: K&N SR intake, Cross drill & Slotted Rotors, EBC yellow stuff pads, Strut tower brace, No back seat, No spare, OBX header, High flow cat, Muffler Delete, 2003 6 speed, Stage 2 clutch, 12lb Fidanza lightweight flywheel.
SOON: Springs
Later: Power ... Turbo?
04-04-2009, 04:07 AM
Gallery
Thanks laggy, that one seems for the S though.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
