hey i have a 2004 mini cooper (non s) and im going to put a turbo in it. i dont mind running 6 lbs of boost, but i would love to run about 12 or 15. this, as you can imagine, is way beyond the limits of the stock mini cooper engine. what i need to know is....
1. what parts of the engine does forced induction mess with (all parts plz)
contact jan at RMW
and usualy it needs a piston change to lower the compression ration.
far as i know the stock cranks are pretty tough.
however the stock head is like trying to breath thru a coffee stir
Search function be your friend... not a new subject...
Short version: Just about everything needs to be replaced and it's not worth the effort... there's a reason why few vendors have even bothered with turbo kits for the R50.
Jan will build you a turbo motor that will out-perform an S... but a) it's basically an turbo-only R53 motor, and b) your pockets had better be deeeeeep.
Of course, stating this rarely prevents a long, drawn out arguement from starting... right about... now...
__________________ "Market research is bunk... the public don't know what they want, it is my job to tell them" - Sir Alec Issigonis
The point is that the low/moderate boost set-ups have proven to be more trouble than they're worth - power gain : amount of work/expense... you basically end up with a car with less power than a stock S that's a PITA to tune (a confused ECU is never happy).
After much reading over the past... 5+ years... the best bang for the buck for increasing the HP of a Cooper is: cat-back, good intake, Jan-tune... do some suspension mods and enjoy the car for what it is.
But go for it anyway... not my car...
