MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > MINIs in General > Classic Mini Talk
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post GP 1456 For Sale
by anitan1
25 Replies, 763 Views
Go to first new post "Those Waiting for a 2012"...
by Vapok
1,979 Replies, 54,096 Views
Advertisement
Thread Tools Search this Thread
Old 08-07-2010, 10:44 AM
r20bmw r20bmw is offline
Gallery
Loose Flywheel
I think I have found my mysterious noise. I pulled the engine and all looks good with the new release bearing but when I grabbed the flywheel I can rotate it about 1/4 of an inch each direction. I can also move it a little laterally. I tightened the center bolt but still have the slack and can feel it pick up the slack on the primary gear. Any suggestions on how to fix this?
Old 08-07-2010, 02:20 PM
MINIdave's Avatar
MINIdave MINIdave is offline
Gallery
Dpepends on what's wrong......are you sure the bolt is all the way in, not just tight?
Were the threads on the bolt damaged at all? How about the threads in the crank?
A local club member had a strange noise in his clutch area too, and when we pulled the flywheel discovered a bolt with damaged threads, making me think it backed out a bit then galled, as it felt tight when he tried to remove it. Right now he's going to run a bottom tap of the right size (5/8-16?) into the crank and try to clean up the threads to make sure the bolt is going in all the way - oh and he bought a new flywheel bolt and retaining washer too.
'09 LB/LB Clubman S
'69 Jaguar XK-E
'04 Audi Allroad Twin-Turbo
MMC#580
Let's Go Clubbin!
Old 08-08-2010, 03:14 PM
Gallery
When I installed the flywheel previously, I put in a new bolt and retaining washer. When I pulled it this time and noticed the loose flywheel, I tried to tighten the bolt and got about a quarter of an inch on it with max torque. I am in process of pulling the flywheel but it is is really stuck. Just stripped my puller and have to get a new one tomorrow. I am hoping that I have not screwed the crank. Once I get the flywheel off I will post what I find. I will also geta tap and try that.
Old 08-10-2010, 12:56 PM
Gallery
This one is hard to believe, I removed the FW and then the pressure plate. What I found was unreal, there was a bolt that backed out of the pressure plate and was floating around the clutch disk springs. I think I found the noise. See attached photos. Loc Tite will be my best friend on this one.
Butch
Old 08-10-2010, 04:03 PM
MINIdave's Avatar
Gallery
Very interesting.....
We found some threads from a bolt lodged in one of the springs on our local club member's car, we think they came from the flywheel bolt, now I'm not so sure.
Thanks for posting what you found, I'm going to link this thread to our club member.....
'09 LB/LB Clubman S
'69 Jaguar XK-E
MMC#580
Let's Go Clubbin!
Old 08-10-2010, 05:34 PM
mk1leg mk1leg is offline
Gallery
That looks like a Verto type fly wheel and plate..........you may need to use a very fine emery paper and some lapping in paste on the end of the crank..........
Old 08-11-2010, 07:01 AM
Gallery
I should also add that I checked and all the bolts holding the flywheen on the crank flange were loose. It appears that someone before me put in a new clutch/FW and no lock tite. I did find that the threads were messed up on the one that got loose so I am in the hunt today for a die or new bolt.
I plan to take some emory cloth to the end of the crank. This engine was built by Speedwell in England and I think the crank had these rough spots when they installed it. My wife is English so I can say, you know how the english built some things. If you ever have a couple hours to laugh, give me a call and I will tell you about an adjustable hidraulic suspension system they installed. 64 wires to 4 switches and no solder.
Thanks to everyone for the replies.
Butch
Old 09-09-2010, 12:18 AM
truckboy's Avatar
truckboy truckboy is offline
Gallery
What seems to have happen is the shaft that is splines has stripped. This occurs when it is stressed or well used. Replacement is necessary.
Old 09-09-2010, 04:47 AM
Bug Magnet Bug Magnet is offline
Gallery
thread?
I doubt that this European car has any 5/8-16 (SAE) bolts in it.
Surely it is METRIC !
Check carefully as you don't want to ruin the threads on a crankshaft...
BM
Old 09-09-2010, 05:51 AM
Gallery
loose flywheel
I am not sure what shaft you are referring to that has splines that may have stripped. Could you explain? I did pull the flywheel again and found that the end float in the primary gear was above the max tolerance and I put in a new C ring that brought it below the max tolerance and I also replaced the clutch shaft that had a lot of play. Started the engine and the noise is now almost unnoticable. Still when I press in the clutch, the noise goes away. Since I have a newly rebuilt tranny and was very careful with the end float on the idler gear, I feel like the noise is related to the clutch in some way. I am going to drive it and see if anything fly apart, then I will know where the problem lies. I checked with multiple mini folks and have been told that the crank thread is a 5/8 16 and the tap cost about $36. Leave it to the English.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
