MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > MINIs in General > Classic Mini Talk
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Go to first new post "Those Waiting for a 2012"...
by Vapok
1,980 Replies, 54,228 Views
Go to first new post Hot or Not (Fuses)
by oPossum
64 Replies, 17,508 Views
Advertisement
Thread Tools Search this Thread
Old 07-30-2010, 09:09 AM
r20bmw r20bmw is offline
Gallery
Vintage mini mysterious noise
Morning all. I have a vintage mini 1275 cc. Recently had the tranny rebuilt and all new drop gears. Car was running fine for about 100 miles ( lucky me). The car developed a noise when depressing the clutch and figured it was the release bearing so just finished replacing it. Now I have a noise that appears to be coming from the bell housing area. At idle you can hear the noise, sounds kind of like a metal chattering. With the car in neutral and sitting in the garage I hear the noise at idle, accelerate a few hundred R's and the noise quietens down as I accelerate to the noise gets real loud. Real chattering. I used the old extension to the case to try and find the location and it appears to be coming more from the clutch side of the flywheel and not the engine side, hoping to eliminate drop gear problem. Any help would be greatly appreciated.
Old 08-03-2010, 08:39 AM
miniroll miniroll is offline
Gallery
Did you checked the spacing of the primary gear when you install the drop gears? I did have a noise like what you have explained but mine turned out I didn't locktite the bolts for the clutch to the flywheel......and they slowly backed out
Old 08-03-2010, 09:00 AM
MINIdave's Avatar
MINIdave MINIdave is offline
Gallery
Also check the center flywheel bolt. One of our club members had a similar noise and found the bolt had backed out a little then galled, making him think it was tight when it wasn't.
Also, did you get the horseshoe shaped clip in properly? Turn the crankshaft till the open side of the clip faces down, then it doesn't fall out when you slide the flywheel assy over it.
'09 LB/LB Clubman S
'69 Jaguar XK-E
'04 Audi Allroad Twin-Turbo
MMC#580
Let's Go Clubbin!
Old 08-04-2010, 12:39 PM
Gallery
I did check the tolearance with the Primary gear and installed the correct shim. I did install the horseshoe clip correctly. I installed a new flywheel bolt and locking tab and torqued to specifications but I will recheck when I pull the engine this time. I did not remove the clutch from the flywheel but will also check the bolts again. I get the noise with the clutch depressed or not which leads to seem like something on the clutch side of the flywheel. I figured with the clutch depressed then the drop gears are disengaged and nothing in that area or the tranny would be spinning to cause the noise. If the flywheel were loose, it seems as though the noise would go away at higher RPM due to centrifugal force (just a guess here). I did not have the noise prior to replacing the release bearing which is real strange. Just wondering what I could have screwed up replacing the bearing. This an A+ with Verto clutch. Thanks for the input, I will post the finding once I figure it out. Any more advice would be appreciated.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
