MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Welcome to North American Motoring, the North American MINI Community of owners and enthusiasts!
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and photo galleries. By joining our free community you will have access to post topics, communicate privately with other MINI enthusiasts (PM), respond to polls, upload your own photo gallery and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact our support team.
Go Back   North American Motoring > MINIs in General > Classic Mini Talk
Not a member? Register now!
Welcome to North American Motoring !
» Main Menu
Upgrade Garage
» Latest Main Topics
Not So Good Vibrations
I phone / Smart phone
iPhone 3G snap-in adapter...
Cruddy Reverse Light Still A...
Cold start chatter
Looking for pics of modded...
Power steering problem on 2nd...
Can I add iPhone/Bluetoot...
Windows are possessed
Clutch not covered under...
Advertisement
Vendor
 Aftermarket vendors
Thread Tools Display Modes
Old 07-02-2009, 01:37 PM
AFireInMINI AFireInMINI is offline
Gallery
Brakes locking up
I've been trying to get my '61 Austin Mini out this year and on the first drive my front left brake locked up. I was in need of new calipers so I replaced the ones on the front wheels. After replacing the caliper I bled the system and adjust the brakes. All wheels are stopping good, but the left front still will not release pressure after pushing brake pedal.
My car still has the drum style brake on all 4 wheels.
Anyone have any idea why this is happening and how to fix it. I would love to put some miles on the car this summer. Thanks
Old 07-02-2009, 02:25 PM
Capt_bj Capt_bj is offline
Gallery
First thought would be to replace the spring in the drum as its function is to pull the shoes back when the pedal is released.
But, this spring is really not very strong and if the brakes are holding strong pressure then I suspect the shoes must be binding so I'd be looking for anyplace the shoe could be catching. Some thoughts are
the back plate is rusted and there's something there catching the shoe - take everything off, wire brush then paint with a heat resis' paint.
or
the drum is SO worn that the shoe is dropping into a groove and somehow is actually getting hung up.....solution is new drums and shoes
or - and this is really where you should start - is everything assembled correctly????? If not, there may be restricted movement just for that reason. First time I pulled my rear drums apart I found one side all screwed up assembly wise and it sure explained why I seemed to have no rear brakes (to the point the e-brake could not hold the car AT ALL)
digging deeper into brain cells suggests a blocked brake line that's allowing fluid to go thru under pressure but not return....a one way valve caused by blockage - but you saw nothing wierd when bleeding huh?
just random thoughts .... I'd take apart - de-rust and re-coat.
Capt BJ '79; 02 S {02 - 09}, 07 S
Old 07-02-2009, 03:39 PM
Minimad Minimad is offline
Gallery
You say you replace "calipers", yet you say you have drum brakes on a 4 wheels? Calipers are disc brakes. Wheel cylinders are drum brakes.
I'll assume the latter is true and you replaced "wheel cylinders" which were leaking or seized in the out position causing the lockup.
Nothing mechanical will cause the pressure to stay in the cylinder. BJ is on to something with the flexible rubber lines. Sometimes these lines deteriorate/break inside and can become blocked. That may cause pressure to be held once applied. Check them. If they are several years old, they should be replaced anyway....
Old 07-02-2009, 03:47 PM
Gallery
I stand corrected I replaced the wheel cylinders. Thanks Minimad & Capt_bj for the info. I will try you ideas. Thanks
Old 07-02-2009, 03:50 PM
Gallery
drum brake guys called 'em "master cylinders" didn't they?
whoops - time post cross -
Old 07-03-2009, 12:01 AM
Spank Spank is offline
Gallery
my money is on a bad flexible brake line. if you removed and reinstalled wheel cylinders on it, you may have it twisted as well. You don't want it to look spiraled at all when the wheel cylinder is installed- it should make a nice gradual J going from subframe to brake slave.
--Spank
Old 07-03-2009, 12:02 AM
Gallery
Also, use DOT4 rather than DOT3-- DOT3 will cause the rubber to deteriorate in the lines/cylinders.
I Like Castrol LMA (White with red/green)or Valvoline synthetic (silver can)
Old 07-03-2009, 05:04 AM
Crashton's Avatar
Crashton Crashton is offline
Gallery
Quote:
--Spank
This is a good possibility. It also is quite possible the line has collapsed internally. When they do they will let the brake fluid move the wheel cyl, but will not let the fluid release once you let off the brake. If you crack the breeder open & can turn the wheel that pretty much tells you. With the age of your Mini I would replace all of the rubber flex lines.
Chuck~ Proud member...OLD FART MOTORING CLUB
______2006 MCS HB/W 66,000 miles of fun!!!
Old 07-03-2009, 09:02 AM
jeffm5150's Avatar
jeffm5150 jeffm5150 is offline
Gallery
I had a similar incident about a month ago, although I've got front disc brakes with braided SS lines. An automotive guru of mine suggested replacing all of the brake fluid because it could have gotten moisture in the line, which will boil and vaporize at a lower temp than the brake fluid, resulting in a locked up brake until the fluid cools down. Not sure if that's what's going on for my Mini, but I thought I'd throw it out there.
I haven't done anything yet, as I'm replacing my entire front brake system.
Jeff
Blue's Gallery @ http://desertwave.com/gallery2/main.php?g2_itemId=5582
Gravity - it's not just a good idea, it's the Law
Old 07-04-2009, 04:37 PM
Gallery
Thanks for the added information. I have ordered new brake lines and will try DOT 4 fluid. Thanks again
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
R56 brakes = R53 JCW brakes? synigod Drivetrain (Cooper S) 128 06-04-2009 12:04 AM
My remote(s) stopped locking and Un-locking my doors bergie07 1st Gear 2 04-01-2008 04:15 AM
WTB: Front Brakes from R56/R53 JCW Brakes jonnieoh Want to Buy - All Other Items (archive) 0 03-27-2008 03:16 PM
WTB: R56 Stock Brakes or JCW Brakes Guest Want to Buy - All Other Items (archive) 0 03-22-2008 12:07 PM
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
Search Engine Friendly URLs by vBSEO 3.2.0
